January 2022 Car of the Month: mjweimer
  • 2mAn
    Señior Mod
    • 21038
    ***Editors Note: Let’s start the new year strong! This car somehow was missed in my constant perusing of the forums, but luckily we were able to not only kick start fixing a great thread, but also get to feature it here because it’s absolutely well deserved. Congrats and let’s get another solid year of E30s to feature! ***
    1990 325iS
    Color:
    Alpine white
    Interior color:
    Crimson Red leather
    Engine:
    M52b28
    Aluminum block Z3 engine - refreshed at 114k
    Head machining by Kevin at Head Solutions
    S52 intake/exhaust cams
    AKG engine mounts
    E34 oil pan/pick-up with VAC baffle
    M50 Intake manifold and throttle body
    Turner Motorsport manifold conversion
    Early E39 fuel rail
    Dbilas airbox
    OBD2 tune and wiring harness mods by Markert Motorwerks
    E30 325td mechanical fan/clutch
    Driveline:
    ZF 320 transmission
    Valeo single mass flywheel conversion
    3.15 Torsen limited slip differential
    325e big guibo driveshaft
    Rogue transmission mounts
    Exhaust:
    Stock OBD2 stainless manifolds
    Syncro Designwerks downpipe
    Custom 2.5” exhaust including a Flowmaster 2220125 catalytic converter
    Stromung muffler custom made by Scott with a single 2.5” inlet
    Suspension/Steering:
    Stock strut housings modified with M3 swaybar tabs
    H&R sport springs
    Bilstein B8 dampers front and rear
    E46 M3 upper rear mounts with MZ3 reinforcement plates
    E30 M3 front and rear swaybars
    NOS BMW solid rubber rear diff mount bushing
    Lemforder Front control arms with E30 M3 offset bushings
    Lemforder subframe and trailing arm bushings, Sachs strut bearings
    Z3 steering rack, custom lines
    Strut housings, subframes, backing plates, swaybars and spring tops powdercoated gloss black
    Brakes:
    E83 brake booster and master cylinder
    2002 brake fluid reservoir
    Ate re-man front calipers with Zimmermann rotors
    NOS BMW rear calipers with Zimmermann rotors
    Re-built e-brake assemblies with Ate hardware and shoes
    Techna-fit stainless steel brake lines
    Hawk Ceramic compound brake pads F+R
    Wheels/Tires:
    15” Nogaro Euroweaves (including spare)
    Yokohama Advan V701 - 205/55/15
    Exterior modifications:
    Full glass-out respray with 2-stage PPG paint
    Smooth front valence with fog-lamp blanks and 318i center vent blank
    Genuine Reiger lower lip
    Euro bumper trim front and rear
    Dapper lighting LED low beams and NOS Cibie H1 high beams
    Smoked front indicator lenses
    LED license plate lamps
    E30 M3 sport evolution outer and inner grilles
    E30 M3/E30 touring roof mount antenna
    Fiamm air horns
    Ultra Racing strut brace
    Red46 skid plate
    Interior modifications:
    M-tech 1 380mm steering wheel with E26 center emblem
    Early under-dash panel and trim
    E30 M3 clone cluster with digital voltmeter by E30 Clusters
    BMW illuminated one-piece shift boot/knob
    Euro non-OBC center panel
    Clarion FZ-102E head unit
    Alpine SPR-50C separates front with tweeters mounted in factory housings, stock rear premium, new wiring to head unit.
    Re-covered rear speaker deck
    E82 front rubber floor mats
    Story behind the car:
    This car was delivered in the State of New York to its first owner in November of 1990. It was eventually traded in with 56k miles and sold at auction, landing in Indiana with a new owner in May of 1996. Less than two months and two-thousand miles later the new owner stuffed it into a ditch. The car was declared a total loss by insurance and ended up at Zionsville Autosport. Dwight and his crew fixed the damage and then sold the car in September of 1996 to an enthusiast in the area. About 1999 or so I eventually met this new enthusiast owner through the BMWCCA and we became friends.
    Fast forward to October of 2015 and my friend is looking to downsize his collection of cars and move to Florida. He can’t find a buyer and wants me to end up with the car. At first I hesitated…but eventually caved when I went to look at the car and realized it was really solid. At this point the car had 140kmiles and was still in great shape though suffering from several years of inactivity. My initial plan was to clean it up, do the usual maintenance; timing belt, filter, fluids, etc. and then drive it to see what else needed work. At this point things went a bit sideways.
    About a month after getting the E30 in the garage, another friend ended up with a wrecked 1997 Z3 2.8 he was hoping to use as a parts car for his ’01 Z3 project. This wrecked Z3 had nothing he needed so he offered it up to me. Again at first I hesitated…and then started getting some bad ideas. I bought the Z3 and proceeded to part it out with an idea to do an engine swap.
    Thanks to the R3v community, I was able to learn all about the bits and pieces needed to start a 24v swap and it began...I called it the Rolling Wreck simply because this car should never have survived and was now getting the heart of a mangled Z3. The late Pete McHenry was my inspiration for all of this….years ago at Gateway Tech (an annual BMW CCA event in St. Louis) he showed up with an E30 M3 into which he had swapped a 2.9 liter aluminum block stroker engine build from a mish-mash of M5x/S5x parts. He and I talked a lot about his build and after a short drive I wanted to build a copy…but I was a new homeowner and had zero funds. I never forgot that experience and when all these parts fell into place years later I was finally able to build something similar.
    I’ve been around this car in one way or another for 22 years and plan to hold on to it for many more.
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • 808ETA
    • Nov 2018
    • 436
    Beautiful car and so clean! Congratulations!
    sigpic84 325e
    • rudy
      • Jan 2021
      • 75
      Well deserved COTM! Matt’s contributions to R3V through his car and knowledge are something I greatly appreciate. Great build.
      • AWDBOB
        hooptie connoisseur
        • Aug 2013
        • 4508
        woohooo!! So glad to see this thing featured. Seeing mj's work in person is just next level. Such a deserving feature!
        • mike.bmw
          • Dec 2015
          • 1777
          AWESOME! Congrats!
          • mjweimer
            • Dec 2015
            • 648
            Thanks everyone, appreciate the kind words. This project would have been much easier and would likely been much different had I stayed M20 powered but no regrets. I am loving the M52 swap, reminds me a lot of my old E36 M3 with all the goodness of the E30 chassis.
            • econti
              • May 2014
              • 1152
              Clean and mean, that's just beautiful. Perfect colour combo
              • lukeADE335i
                • Apr 2013
                • 1389
                Well done! The car looks great, and love the subtlety of it.
                My e30: OEM+ with M30B35
                • getouth
                  • Jan 2010
                  • 3343
                  This thing is legit beautiful!
                  FEEDBACK:
                  http://www.r3vlimited.com/board/showthread.php?t=316212
                  BMWCCA #398608
                  IG @yagayo38
                  "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                  • ethirtydavid
                    • Jan 2008
                    • 2331
                    nice car the swap looks great
                    • Northern
                      I like cupcakes & sh!tboxes
                      • 5284
                      such a clean car
                      Originally posted by priapism
                      Originally posted by shameson
                      • DEV0 E30
                        • Oct 2004
                        • 8904
                        Very nice!
                        • mjweimer
                          • Dec 2015
                          • 648
                          Thanks for all the positive comments. I am patiently waiting for all of the ice/snow/salt to go away so I can get this back out for a drive....
