The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • Dj Buttchug
    • Jun 2010
    • 7637
    #706
    Originally posted by econti
    Note that Nuke Performance make a rail for them that is supposedly drop in
    This is true and I have one. The only issue to resolve is mounting it properly. I am working on some custom brackets to make it work.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • econti
      • May 2014
      • 1098
      #707
      They don't drop in? That's a pisser. Was thinking of getting one myself
      • Dj Buttchug
        • Jun 2010
        • 7637
        #708
        It drops in but there is no way to secure the rail to the intake so its just free ballin. Is this how they normally install fuel rails? I feel like a good about of boost will pop the injectors and the rail right out of the intake runners if you don't have it bolted down somehow
        Ig:ryno_pzk
        • econti
          • May 2014
          • 1098
          #709
          Yeah nah that's not normal, is a good reason why OEM is bolted down.
          That honestly surprises me, I thought Nuke were a good brand
          • whodwho
            • Jun 2008
            • 1547
            #710
            They don't seem to supply brackets, bmwandhonda had to build brackets for his touring ITB build as well
            My M20 Frankenbuild(s)
            4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
            • Dj Buttchug
              • Jun 2010
              • 7637
              #711
              lots of work to be done
              Ig:ryno_pzk
              • Dj Buttchug
                • Jun 2010
                • 7637
                #712
                Installed 3 Bar GM map Sensor. Previous settings were at 2.5 Bar which isn't enough. This means the whole tune is off btw. So now I have to re adjust everything.
                Ig:ryno_pzk
                • e30m3s54turbo
                  • Jun 2010
                  • 3205
                  #713
                  I like the hard work you put in to it!:up:
                  • Jaker
                    • Oct 2013
                    • 234
                    #714
                    I might have missed it. How much boost are you running? That 2.5bar sensor is good for 22-23lbs of boost.
                    • Dj Buttchug
                      • Jun 2010
                      • 7637
                      #715
                      running 22.
                      The 2.5 bar actually isn't. Map sensors only operate at about 80% or so of total rated BAR so it would only accurately measure 16-18 psi.
                      Ig:ryno_pzk
                      • Jaker
                        • Oct 2013
                        • 234
                        #716
                        I've used the Motorola 2.5BAR sensor before and it accurately read to 23psi.
                        • Dj Buttchug
                          • Jun 2010
                          • 7637
                          #717
                          possibly so but this one I have is not working correctly so that's why I opted to a higher rated one.
                          Ig:ryno_pzk
                          • Dj Buttchug
                            • Jun 2010
                            • 7637
                            #718
                            New fuel system installed and working well. What a complete bitch it was to mount the Nuke rail. I fabricated 3 different brackets from scratch before finally coming up with a box shape style that worked right.
                            Ig:ryno_pzk
                            • Schnitzer318is
                              • Jan 2008
                              • 2057
                              #719
                              Looking good.
                              Side note, you remember the pitch/thread size on the studs you're using for the valve cover? That's how BMW should have done it. I had to Helicoil at least half of mine because the PO stripped the threading in the head from over tightening.
                              "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                              91 318is Turbo Sold
                              87 325 Daily driver Sold
                              06 4.8is X5
                              06 Mtec X3
                              05 4.4i X5 Sold
                              92 325ic Sold & Re-purchased
                              90 325i Sold
                              97 328is Sold
                              01 323ci Sold
                              92 325i Sold
                              83 528e Totaled
                              98 328i Sold
                              93 325i Sold
                              • Dj Buttchug
                                • Jun 2010
                                • 7637
                                #720
                                M8x1.0 I believe. My studs are a little tall but yes totally agree. It is so much easier this way. Better clamping force on the VC as well because the OEM rubber grommets just don't hold up long.
                                Ig:ryno_pzk
