The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • Dj Buttchug
    • Jun 2010
    • 7648
    #751
    The intake runners are almost a direct shot to the M42 head. Only a slight adjustment will be needed to make it fit correctly. The first manifold I made had several problems. The thickness of material used was the main reason for cracking. Metal was just too thin. The sizing was also an issue. Too big to get a correct and stable idle. IAT temp sensor often was heat soaked due to location as well as other things. The positives with using this VW mani include running the factory VW IAT sensor as well as having plenty of vacuum ports to use for BOV and boost control. It will clean up a lot of the engine bay on this side and it should work better. The sizing should also help with tuning the idle. It wasn't bad with the old setup but it wasn't perfect. Ill update again once the intake is finished.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Dj Buttchug
      • Jun 2010
      • 7648
      #752
      A few photos of the progress on the intake. Nothing special just over priced aluminum and alot of time with a dremel.
      Ig:ryno_pzk
      • Dj Buttchug
        • Jun 2010
        • 7648
        #753
        ​Intake runners will be cut down another 2 to 2.5 inches or so to fit in the engine bay correctly. Nothing welded together yet just test fitting the design as of now. Depending on my level of motivation I may have it ready to mount back on the engine by the end of this week. The IAT sensor switch from a GM style to the OEM VW will take some doing. The OHM readings at room temp are slightly different on the GM sensor than the VW so I am thinking of a plan to get this to work with MS1. Possibly some calibration or maybe I am over thinking it and itll work...
        Ig:ryno_pzk
        • econti
          • May 2014
          • 1119
          #754
          Plenum volume looks small to the naked eye, is it calculated?
          • Dj Buttchug
            • Jun 2010
            • 7648
            #755
            To a certain degree it is. After researching some I found lots of conflicting info on size and design. NA to turbo engines all different info. Most info saying volume should be double the size of engine displacement. Also, lower compression ratios come into play and with this engine @ 8.5:1 it was hard to know which advice to take. Ended up choosing the plenum from a 1.8 turbo VW. It is significantly smaller than my last design but hopefully much stronger and better design for a more stable idle.
            Ig:ryno_pzk
            • e30m3s54turbo
              • Jun 2010
              • 3228
              #756
              I’m glad you have your beast. I’m looking for up dates…I have owned e36 m3 in the past. I will always refer to e30 bmw to drive.
              • Dj Buttchug
                • Jun 2010
                • 7648
                #757
                End result of hack job VW intake. Turned out much better than expected.
                Ig:ryno_pzk
                • Dj Buttchug
                  • Jun 2010
                  • 7648
                  #758
                  Some time ago my timing case developed a pretty decent oil leak right at the profile gasket seam on the passenger side. It was small at first but has gotten worse. I put it off because its a complete bitch to fix correctly.
                  FML.
                  Despite my engine ground cable kit I've still got some pretty decent electrolysis going on. Pisses me off a little bit because I have so much money invested in this engine. There is new pitting around my water pump inlet and some small areas around the profile gasket. Not sure how to handle that yet. Engine now has just over 5k miles since it was build. Possibly this is happening because the car isnt driven enough.
                  Ig:ryno_pzk
                  • Dj Buttchug
                    • Jun 2010
                    • 7648
                    #759
                    Finished this shitbag of a job. No leaks now. Thanks I love it. New intake on and working. Appreciate the donation Audi.
                    Ig:ryno_pzk
                    • ccsdo5
                      • Mar 2013
                      • 707
                      #760
                      Damn, I haven't been here in a while. Some real "danger to manifold" stuff. Nice work making the audi manifold work. I've actually seen people use 1.8T manifolds before in the M42 fb group.
                      -Dee
                      5-lugged turbo 318is Barn car
                      IG: @deebelmont
                      • downforce22
                        • Aug 2009
                        • 3192
                        #761
                        Looks great, need more video of it
                        • 2mAn
                          Señior Mod
                          • 20351
                          #762
                          Still shocked how well the 20v intake looks on there.
                          Simon
                          Current Cars:
                          -1966 Lotus Elan
                          -1986 German Car
                          -2006 Volkswagen Jetta TDI
                          Make R3V Great Again -2020
                          • Dj Buttchug
                            • Jun 2010
                            • 7648
                            #763
                            More to come on this here soon. Moving away from MS1 going to Haltec... My old MS board has shit the bed finally.
                            Ig:ryno_pzk
                            • ccsdo5
                              • Mar 2013
                              • 707
                              #764
                              probably a good move. I'm surprised it went that long though. My MS2V3 still going strong somehow I've been thinking about going to a link ecu...
                              -Dee
                              IG: @deebelmont
                              • Dj Buttchug
                                • Jun 2010
                                • 7648
                                #765
                                I am running Link G4x on my E34. It is an amazing product. Would recommend 10/10. I am still on the fence between Holley Terminator X, Haltech or max ECU for this car. I don't want to build a harness but it looks as if I will have to no matter...
                                Ig:ryno_pzk
