the one singing...duh...
Danny's 4door Calypso 24v car
s52 swap adds 40 lbs. to any photo. Since this is the second time you've swapped this engine, be glad you are down 10 lbs.Comment
So, I got the car running, romped around the industrial park for a while, then drove it home from the shop. Then it cut out after I took it for a spin around the block and now won't start. I have fuel, and I have spark. It just won't start. Engine ran fine in my gray car and the only things I did were the water pump and the valve cover gasket.
Ideas?
Ecu? Check the oil for coolant? Somewhere, a ground might not be connected? Something is loose and its probably anneasy fix. Check and make sure all sensors are properly hooked up in their harness connection counterparts.
I donno man, I have faith in you.world renown Harry Potter expert
sigpicComment
No oil in coolant, haven't checked the ECU, I'll go grab a 413 tomorrow to confirm. Ground are all adjusted. I pulled out the injectors and am soaking them in injector cleaner/fresh gas over night in an attempt to clean them out.
FPR? Maybe you're getting fuel, but not enough?
Long shot, but another idea.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
