Danny's 4door Calypso 24v car
  • 87e30
    • Jul 2008
    • 5676
    #421
    Did you stomp test?
    I just hate everyone.
    No need for discretion.
    • samiam3356
      • Jul 2009
      • 1901
      #422
      Thats crazy then. Rotating engine tells the DME to power the fuel pump. Air, Fuel, Fire= explosion if timed correctly.
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
      • toointoxicated60
        • Sep 2009
        • 355
        #423
        Im with sam. Bad CPS
        • Danny
          • 14216
          #424
          Originally posted by 87e30
          Did you stomp test?
          Yeah, code 1444: no faults :|
          I have to disagree guys. I mean, if it was the CPS I wouldn't be getting spark. The issue is that there is no 12v at the fuse box.
          • Danny
            • 14216
            #425
            Fixed the fuel pump issue, so we have fuel.
            Have spark, at least outside of the motor.
            Injectors are firing.
            Compression is low, but even. with 6 cranks it has 90 psi, throw some oil in and it goes up to 150.
            I think we have everything we should.
            • Danny
              • 14216
              #426
              Nobody?
              • Vince30
                • 2318
                #427
                In some cases a bad cps would go to a defult were it would fire until it senses ignition and the engine can time it from there, I don't know if bmw did that but I would not rule out cps because you have spark.
                  • 37833
                  #428
                  From everything I have seem there will be no spark if CPS is bad. That being said, try another one if you have access to it. :)
                  Grover Beach, California
                  BimmerHeads.com
                  • phreshkid
                    • 4655
                    #429
                    No power to the fuse box? Now that is just weird.
                    • Dj Buttchug
                      • Jun 2010
                      • 7688
                      #430
                      bad ground somewhere... wtf thats all i can think of
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • Danny
                        • 14216
                        #431
                        I figured out the fuse box, like I said. Fuel pump is working now. It just isn't lighting off. I'm going to let all the fuel air out of the cylinders over night, then change the oil, try again tomorrow.
                        • phreshkid
                          • 4655
                          #432
                          I'd come over and help if I wasn't so damn far, even though I'm really not too far.
                          • MR.LUGO
                            • 905
                            #433
                            Maybe check cap/rotor/wires.. my .02
                            Got all da Alpine bitches mad cuz my main bitch Calypso.
                            • Danny
                              • 14216
                              #434
                              S50. It has coil on plug.
                              I should probably throw some new plugs in there though.
                              And thanks Ryan, but there is only so much I can do. I think this is starting to get a little above my level.
                              • Jean
                                • 18228
                                #435
                                So what was the fuel issue you fixed?
