Your car has come a long way! Keep it up.
Abit's 318iA m20b30 + pssycat cam and more...
Originally posted by abit View Postthanks.
*Calipers together with brake caliper supports is from Ford Mondeo MK3 (about 2000-2007 years, they are the same for all engines)
*Brake discs is from audi a3, i think It was 1.8t model who has 288mm rotors, you should just redrill bolt pattern, because audi has 5x100 pcd, easy job.
supports etc will bolt on, just some minor modifications have to be done to disc brake dust protection and you maybe will need some small spacers between hub and caliper support.
I'm assuming since the Audi A3 has a 57.1mm centre bore, they bolt right on once the bolt pattern is redrilled?Originally posted by priapismMy girl don't know shit, but she bakes a mean cupcake.Originally posted by shamesonUsually it's best not to know how much money you have into your e30
Originally posted by Northern View PostDo those Ford calipers bolt on without an adapter?
....discs, center centering bore also should be machined (as I remember BMW has ~1mm larger centering diameter, so -1mm should be machined off), and of course re-drill bolt pattern, yes.
ok, one shorty :D
finally tuned up my engine management with #402 ecu, now car runs sooo good....actually ran
some random shot before we installed all gadgets for tuning :D
had so much good time rolling down the streets with full throttle, dayummn :D
one more shot with other bangers :D
yeah https://instagram.com/mundieriss/
and then, so much fuuuck, hit rear underneath of car so bad, that it bend my exhaust from round to flat and exhaust banged right in my fuel tank, breaking the fuel cells connecting pipe, so fuel started leaking straight on hoot exhaust, so much luck that it didn't catch fire, dammn, so now I need to repaid my tank.
stay tuned :)
fck yeah, fuel tank is repaired, and we roll again :D
first, bought IX body plastics, test fitted ....mm, when I bought them, I thought that these arches will make my wheel arches bit wider, but I realized that IX arches just makes wheel arch lower, fail :D... so already trying to sell them :D
next, fuel tank
it was quite rusty there and a hit from exhaust was heavy enough to crack tank
and how it looks now
then met one of my mates, with his Swedish turbobrick ;D
and then, finally, real testing and fun :D
ok, enough... :D resume, car now is much more powerful sliding it around the corners than last year, and i love it :D
see yaaa....
Great build! I've read it about 4 times, lol. Finally subscribing. Also is it weird that I think I liked it more with miss colored bumpers and fenders?My Garage
Feedback
Instagram: Stone.Hopkins
Sooo, what's new...actually nothing much :D
Car is running good and no big faults has been observed..
repaired bent exhaust...
then bought and installed fiberglass Is front lip..
also bought some yokohama slicks, so I don't turn my good front tires in trash on track, when we go drifting etc, so mounted slicks @ front and of course...testing :D
let's kill them all :devil: :D
chillin'
and then the biggie, decided that my zinno is not that shiny anymore how it was after repaint, so...lets polish that bitch up :D
first sanding with sandpapers.. matte :D
getting closer :devil:
meanwhile tuned up my second car, my musclecar
It took about 4 loooong evenings to make it done, dayumm, that was tough..
after some time, plastidip painted front wheels to see how they would look black, aaand trashed some more tires :D
and then made some fog in forest :D
but the biggie...
some pics of autumn photoshoot
enjoy
...of course some smokeeeey :D
yeahLast edited by abit; 10-20-2015, 01:27 PM.
Originally posted by Sade View PostAwesome job that color save...Was you sand hole car and what paper you was using, like 1000, or 1200??
i would get an adjustable cam gear and set it at 4degrees advanced if possible, it should make more torque below 3500rpm so its not "cammy" like catcams always seem to beLast edited by digger; 11-27-2015, 03:27 PM.89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
