New Member - 1989 325ix and Evo
  • fresh_TD
    • Aug 2013
    • 2457
    Originally posted by anonymous alias
    nice to see another ix
    [ATTACH]75890[/ATTACH]
    and yes check the floor board underneath the carpet just to see what's there, it may fine down there...this is what turned out to be under the rug in my ix
    rear passenger:
    [ATTACH]75891[/ATTACH]
    front passenger:
    [ATTACH]75892[/ATTACH]
    front driver
    [ATTACH]75893[/ATTACH]
    hope u enjoy the car
    this makes me want to go and rip out my rug out right now..lol I'll probably do it this weekend to double check I don't have any issues down there..
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • anonymous alias
      • Jun 2013
      • 66
      hopefully urs is not as serious as mine.
      • nomansland92
        • 1657
        How did your floors end up turning out?
        IX being restored here
        Ix turbo build here
        • anonymous alias
          • Jun 2013
          • 66
          Haven't got them repaired yet. I'm getting some mechanical work done first. There's a whole in the exhaust that makes driving a bit of a doosie, brakes n shocks, amongst other things are my priority. I'll be getting it cut n welded out next month. I'll be sure to keep u updated.
          • AWDBOB
            • Aug 2013
            • 4397
            I somehow missed the fact that the rear upper spring perches are completely rusted through the frame. I have the spring perches on our parts car, but this definitely killed my motivation.
            • nomansland92
              • 1657
              Originally posted by AWDBOB
              I somehow missed the fact that the rear upper spring perches are completely rusted through the frame. I have the spring perches on our parts car, but this definitely ruined this definitely put my motivation to a standstill.
              Had the same problem on my ix, cut and fab is about all you can do but make it strong! I might have a few pictures of how I did mine where.
              Ix turbo build here
              • AWDBOB
                • Aug 2013
                • 4397
                How long did that end up taking you? I suppose I could tack it up myself, but I'd rather have someone more experienced with structural welding do the job.
                Update:
                Put the Auto trans in. My helper (Father) failed to seat the converter correctly and didn't say anything until after I turned the crank for the flywheel bolts and the motor didn't turn over.
                Took the trans out, fixed converter (after subconsciously knowing the pump was toast), reinstalled everything. Went for test drive. No bueno.
                Took the trans back out AGAIN, swapped the pump with an extra trans I have, and she's waiting to go back in, hopefully for the last time.
                Put my new fogs and turn signal lights in, pulled the front bumper (cracked) and the grills (faded) to begin the restoration process on those two guys.
                .....long day.
                • nomansland92
                  • 1657
                  Took me all day, I reboxed the frame with 1/8 steel iirc. I just used round stock to make that nipple to hold the spring in place.
                  Like you mentioned it is structural so if you don't feel comfortable then I'd suggest taking it to a professional.
                  Only pictures I could find on my phone
                  Ix turbo build here
                  • freeride53
                    • 11972
                    Yikes! On the perch sounds sketch.
                    1983 Peugeot 505 STI
                    1992 Volvo 240 Wagon
                      • 34839
                      I actually believe that the rubber spring pads cause rust. it traps moisture and debris between the pad and the body.
                      years back I removed my spring pads on the top, but left the ones on the bottom. The top was still perfect/clean, but the bottom started to rust! go figure. you'd think it would be metal/metal contact that would rust, but nope.. couldn't even tell!
                      • AWDBOB
                        • Aug 2013
                        • 4397
                        That sounds about right! Good to know, too. I 'spose I'll experiment by leaving the top piece off when I get around to fixing it.
                        Getting a welder next week to start learning, so I'm thinking I'll repair it myself once I get more experience under my belt with my own machine.
                        Also, a stock cat is crazy expensive. Any other options for making a mid pipe? I have a new aftermarket catback, but want to put a cat in the midpipe to quite it down so I'm not fully straight piped.
                        • fresh_TD
                          • Aug 2013
                          • 2457
                          You can get something like a universal magnaflow cat and throw it in there if you're concerned about price or source one from your local junkyard/pull apart
                          Sent from my GS4 Active
                          • AWDBOB
                            • Aug 2013
                            • 4397
                            I can't seem to find a Magnaflow cat with the dual inlets and outlets. I did, however, find this one, which I will probably pick up and throw on.
                            • fresh_TD
                              • Aug 2013
                              • 2457
                              http://www.ebay.com/itm/Walker-Super...41bbe8&vxp=mtr
                              Yea, I'd say pull the trigger
                              • ///Bimmerfan
                                • Dec 2008
                                • 730
                                Nice ix and evo!
