Hokejka e30 m50 turbo build
  • hokejka
    • Jun 2014
    • 271
    #91
    Originally posted by ian e30 318is
    Honestly I would save yourself the headache and time and just buy a new one. It's nice to have the peace of mind. Anyways good luck and can't wait to see the finished product! This is a bad ass e30 so far!
    If its any help, I also just noticed my battery light has never come on. Making me think that the bulb doesn't work. If it doesn't work would that make sense why its not charging? / burning up? the electricity has nowhere to go since the exciter isn't allowing power to go through?
    • hokejka
      • Jun 2014
      • 271
      #92
      Switched battery light even though it didn't seem burnt out. Bttery light now works. Got alternator checked. No more noise. And it IS charging. everything passed. Car still wants to stall during shifts and when it tries to recover idle bounces all over the place. Thought it could be Air temp sensor so I checked for pinches and its getting current just fine. Any ideas?
      • hokejka
        • Jun 2014
        • 271
        #93
        took icv out and cleaned it. check it in ignition. it vibrates like it should. not sure how i can tell if it works well or not but everything was sealed well and clean when i took it apart. ide be surprised if this changed anything. i will epoxy all the pieces putting it back together to prevent any possible to prevent any possible boost leak
        • Dj Syco
          • 382
          #94
          I'm glad to see my old E30 being treated right. Actually tearing up a bit reading this.
          • hokejka
            • Jun 2014
            • 271
            #95
            No way, did you sell it to ken or kenan?
            • hokejka
              • Jun 2014
              • 271
              #96
              Been busy with school and work so haven't posted on forums much.
              Took the 245/40s off and replaced them with Toyo Proxes r1rs 245/35/17. I clear 95% now. The 245/40s rubbed too much.
              Cooling system redone. With new Tank, hoses, mishimoto, and spal puller.
              New blank front + rear rotors and hawk hp+ pads all around
              New smoked headlights + corner markers + Morimoto 6000k HIDs
              New Odometer gears and brushed aluminum rings around gauges:
              Center Caps done
              Rear Bearings Done
              ICV cleaned and better secured for boost
              Exhaust tips in. Will get it welded soon.
              • hokejka
                • Jun 2014
                • 271
                #97
                Was over the draw through tune. Went to TRM and got a blow through tune with their high flow MAF and 60lb injectors. I live about 5 hours away so I was able to drive over and get it dynode at their shop instead of sending remote tunes back and forth. I was thoroughly impressed with their shop and help. Put down 290whp/290wtq at 10 psi. Finally able to enjoy the car.
                • hokejka
                  • Jun 2014
                  • 271
                  #98
                  Some Pics
                  • sayed ali
                    • 762
                    #99
                    very nice
                    M20B28 Turbo
                    My Build Thread
                    http://www.r3vlimited.com/board/showthread.php?t=255839
                    • hokejka
                      • Jun 2014
                      • 271
                      #100
                      Little photoshoot:
                      • efficient
                        • Feb 2012
                        • 3312
                        #101
                        nice
                        • Peterkaczynski
                          • Nov 2008
                          • 2587
                          #102
                          awesome work dude
                          e24 e9 e30
                          IG: peterkaczynski
                          • dirtbag30
                            • Apr 2013
                            • 678
                            #103
                            so lovely.
                            i have no idea what i am doing with my life
                            • hokejka
                              • Jun 2014
                              • 271
                              #104
                              Car is being painted in the next month. still looking for side skirts until then. considering doing new front and rear valences as well. lot coming up
                              • Dj Syco
                                • 382
                                #105
                                sold it to kenan. Tried to buy it back once, but couldn't come up with the cash at the moment. Can't wait to see what you do with it next.
                                this is what it looked like when I owned it.
                                Do you by chance have the old ACS wheel that was on it?
