cameras ready prepare to flash
  • s14brent
    • Mar 2014
    • 571
    #421
    Soo I did have that leak somewhere in the AC system I wanted to address eventually. I will be keeping the lines/components to try and mock up in the future with a m54 ac bracket. For now, the out of sight/out of mind thing kinda took over. So I didn't know how big of a POS mishimoto was by throwing in a magnetic SAE bolt into a m12x1.5 tapped radiator drain. I also knew I wanted to change those god awful red coolant hoses that came with my swap.
    ^ mishi drain plug Left, M12x1.5 magnetic drain plug I had on the shelf (brand new).
    ^ I had these whiteline swaybar lateral lock kits from one of my old s-chassis. Threw some loctite on the bolts, hopefully this helps, if not, well it was kind of a free mod.
    I also think the -AN coolant block drain was weeping. It was frustrating because it was never a lot, but there was some signs of coolant leaking from that area.
    ^ Brand new coolant block drain plug installed.
    ^ a/c pile
    of course the radiator hoses I had were stepped from 38mm to 36mm. I have no idea why but thankfully I had a mishimoto 38mm coolant temp adapter laying around. I didnt take pics but I had to drill and tap it for a ground. I also had an aluminum thermostat housing in storage that I wanted to kind of test out. The idea was to tap the housing for the coolant temp sensor so I didn't have to cut up the new hose. I was also appalled by the casting on the housing so I decided to clean it up a bit. Placement really only felt safe on the bottom of the housing -which I don't love. Especially if I need a new thermostat gasket and housing gasket, it seems like a huge pain to do twice. So I actually didn't trust it in the end. so chop chop!
    ^I don't LOVE that.....i wanted to eliminate the use of the temp adapter. It works for now though, and I should have replaced the coolant temp sensor. I've always kind of second guessed it as it's slow to get to temp vs the stock gauge.
    ^ For some reason, the spal fan was hitting the waterpump pulley bolts at startup. I have the other spal still up front on a relay/switch for the AC condenser so I removed the radiator mounted spal and installed an old aluminum rad shroud that I had now that I have the clearance with AC out.
    there was quite a gap between the shroud and the radiator, and I decided to seal it up with alum ducting tape.
    that's pretty much it. Unfortunately the drift event I was preparing the car for on Feb 12th got cancelled. I MAY go to the next auto-x on the 19th to just run the car. The next drift event is March 12th, but March is currently looking SLAMMED on the work calendar. I pretty much knocked out the to-do list that I had accumulated. I just want to drive it now!
    89 325i 4dr s52
    02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
    21' Toyota Tacoma TRD OR 4x4 6 speed Manual
    • moatilliatta
      • 6152
      #422
      is the fan a pusher?
      @Zakspeed_US
      • s14brent
        • Mar 2014
        • 571
        #423
        the one that got damaged? I think it actually might be but i reversed the polarity since it was a straight blade spal. the pusher up front is a slightly higher cfm "low profile" pusher @ 1604cfm (vs the damaged one @ 1298cfm). I'm not sure if that's going to be good enough for vegas heat. I was actually just looking at the 16" curved blade pusher fan which is rated slightly higher at 1959cfm and should fit when I remove the condenser. Got any other recommendations?
        edit: I could try to stuff a slim 14" spal into the 16" opening but I think it puts the high point of the fan right in front of the wp pulley. the low profile 14" puller is rated at 1038 cfm and it's technically all wired up already for plug and play, just need to make new brackets which wouldn't be hard to do at all....vs if i go with the 16" curved blade pusher up front, I'd probably never put AC back in the car, and possibly have to reweld the oil cooler brackets (possibly) BUT it gives me the option to upgrade the radiator in the future without more fitment/clearance issues. - will just have to find out this summer if more cooling is necessary I suppose, I'll just have to enjoy this weather while it lasts!
        89 325i 4dr s52
        • s14brent
          • Mar 2014
          • 571
          #424
          I was happy with my roll bar from Ben Simpson. Makes using factory seatbelts tough.
          also....did you mean ben sipson/bayside fab?
          89 325i 4dr s52
          • s14brent
            • Mar 2014
            • 571
            #425
            so i signed up for the local auto-x on the 19th. Decided for the time being i'd rather have a puller mounted and that having the fan shroud in place without a proper fan setup was probably a worse idea living in las vegas. I ordered a 14" spal low profile and mounted it up using my old brackets with a few new mounting holes and hardware. The 14" fan clears the waterpump bolts a lot easier but i did lose 260cfm by going with the safer-smaller size. I guess that can essentially be regained if I decide to upgrade the spal hooked up to the ac circuit. < that's a summer problem...no more thinking about that for now. Also I think the 14" will probably overall be the better fitment when I have the need to upgrade radiators. Thinking of going CSF eventually and I know the 14" is used more often on the thicker cores.
            I have had some issues with my vdo coolant temp gauge. When the stock gauge is at the half mark it still reads like the bottom mark on the vdo gauge which is like 100 degrees iirc. unfortunately this new temp sensor did not fix the issue, however at least its not all mangled like the old. I'll try to run a new wire from the sending unit to the gauge another day. There really can't be too many things left before I just find some new gauges if I have too!
            Figured I would get rid of my old crusty coolant reservoir and replaced it with this culvers' e30 coolant tank. It comes with a 13psi radiator cap so I went ahead and tried to match it with my 1.2bar GermanAutoSolutions cap and picked up this 16psi moroso cap. (says 14-18 on the cap??).
            rebled the coolant system and confirmed both fans work as intended. Pretty much ready for the auto-x and if time permits....vegasdrift/IFO on March 12th.
            Figured the only thing really loose inside my engine compartment is my diagnostic port. I bought a racegerman e30 c101 holder. I decided to not put it far, and just threw some rivnuts into the battery tray side engine harness cover.
            Hopefully auto-x tech inspector doesn't have any complaints. I have been trying to address every single comment tech inspectors make at each event one at a time and this thing should hopefully pass with no issues!
            -- sidenote: I have been shopping around for sedan rollbars. I'm leaning towards a bolt in cage with doorbars from a local fabricator who's done a bunch of local drift cars (including competition cars) and a couple time-attack cars. It might be a summer upgrade since I don't plan to drive once it gets absolutely miserable out. I figured a bolt-in should be good enough for what I'm doing, and is easier for me to chassis swap if I have to in the future! Also will need at least 1 good harness setup so I'm adding that to costs. But it's going to cost more than the other bolt-in solutions, hopefully with better tolerances and overall-fit. Really bummed kinematic discontinued their rollbars, Bayside only makes coupe fitment, the other cheaper choice left would be Kirk and I'm not sure if i'd be happy with it in the end!
            edit* I ended up using a thicker gauge ground wire for my vdo coolant temp sensor. It seems to have fixed the vdo coolant gauge issues for now. I'll keep an eye on temps next drive if not at the auto-x!
            89 325i 4dr s52
            • s14brent
              • Mar 2014
              • 571
              #426
              so conflicted after auto-x today. It was impossible not to break the rear end loose and i was straightening out as quick as possible. I'm on street tires still, mis-matched at that - but in good shape/plenty of tread. I really wonder if 215/45 RT660's would be enough to stop that (i definitely want to have a 2nd try at the auto-x again.) I had the fronts at about 28-30psi and the rears all the way down to 26psi (hot), and rear dampening all the way soft. Almost every turn-in i'd break loose and try to immediately straighten out (worrying i'd be flagged or yelled at for "drifting"), but the organizers were definitely not pleased (understandably for insurance purposes i'm guessing) but they were cool and kind of noticed I was trying to straighten out ASAP. I do miss grip driving from time to time but the car is setup totally backwards for that right now. I was thinking 215/45 RT660's because at least I wouldn't have clearance issues as they are barely bigger than the 205's i run for drifting. Really shouldn't matter as I'm not competitive in any of these events because I'll miss more than half of them anyways! I thought hankook rs4's came in more 16" sizes in the past, there's not a lot offered in that size it seems. Also, its a pretty expensive pill to swallow if I try to juggle auto-x & drift events, esp in tires & alignments alone. I'll see how next drift event turns out and make a decision shortly after. Like if I notch my camber plates for current camber 4.27° and maybe another notch at like 2.25° to make it easy to go back and forth. Maybe firehawks or the older rt615's would be the more budget friendly choice. I'd eventually like to take this onto the road course here, but they rarely throw events there (maybe 2-4 events a year - either scca open track day or speedventures - so it's hard to plan for especially since speedventures is usually a 2 day weekend event. but* it would be beneficial for me to keep a set of grippies on hand so I can pick and choose what events I could make. Dry erase board in the garage is going to be full of tire psi/alignment specs i'm guessing lol.
              Overall, super happy with the car's feel. no weird noises/rattles, temps were good on/off track and on the freeway (will have to keep an eye on temps during hotter months). Motor felt healthy, kaaz diff felt nice and predictable, the stock lsd unit might be better for auto-x, this one bites hard. No real complaints besides the lack of overall grip LOL.
              I was in the second run group (worked the first) and at about lunch time I threw a CEL. Figured I'd call it a day right there because I was feeling a bit dehydrated anyways. I made a joke to my friend with the miata "it's probably something stupid like an o2 sensor". I will replace it, but I'm also thinking maybe i should throw a o2 extender on there, i dug through this thread and it looked like I replaced it in Sept. 2016.
              oh and also someone posted this pic of me from 2weeks ago when i rolled through that car meet with my r8 buddy.
              89 325i 4dr s52
              • Chilezen
                I weld cats
                • Dec 2013
                • 1940
                #427
                I may be able to help you with this if we can put you on the schedule.. I built cages down is SoCal / Riverside. We have a full cage kit for an E30, we have a bolt in for an E36, but no bolt in for an E30 lol. If you're able to bring the car down, we can use your car to build a new kit. Take a look at my forum thread and let me know!
                Currently building a badass coffee table
                Random stuff on insta @kevanromero
                • s14brent
                  • Mar 2014
                  • 571
                  #428
                  awesome. i sent you a pm on instagram since I check that way more often than here.
                  89 325i 4dr s52
                  • s14brent
                    • Mar 2014
                    • 571
                    #429
                    got sent a couple snaps from the auto-x. I really like how it looks under load. ride height is set where I need it to be. I want to go back out there again, but I also am being a tight wad which doesn't really help (rt660's in 215/45/16 seem to be the route i want to go). But its tax time, and i'm expecting to owe quite a bit (contractor life).
                    got my new o2 sensor installed. nothing sus going on in this pic.
                    Trying my best to make the next vegasdrift/IFO event on March 12th. Makes more sense to go to a drift event since that's what the car's setup for right! I have to be working at the pac12 finals the night before so I'm not sure if I'll actually be able to make it out with an adequate amount of sleep. who needs sleep right?
                    89 325i 4dr s52
                    • s14brent
                      • Mar 2014
                      • 571
                      #430
                      Made it to the event on the 12th!
                      getting gas pre-event. gauge said i had 3/4 but i felt that couldnt be right.....filled up 10gallons. I really need to swap my fuel level sending unit one of these days!
                      kind of fail on the media side, only got two pics post event.
                      here's some from the pits
                      buddy of mine who drifts a red m50 swapped e30 sent me those photos from the pit and this awesome cell phone clip he shot at the end of the day. I'm super pumped to see how the car looked like from the outside, front sway bar definitely got rid of a lot of the body roll. Definitely feels more violent inside the car than out, looks really tame actually which just means I need to start sending it harder when i'm comfortable. An old track buddy of mine showed up in his 600hp ls swapped mustang and was babying it following me...kind of funny - maybe the lap or two before that video i was like "why is there sooo much tire smoke behind me?" >notices mustang friend and kinda got instant nervous LOL
                      very happy with the mods that were done between the last few events. I absolutely love the seat even how ridiculous it appears. in the 2nd video i'm solid. not as much side to side play compared to the old bucket seat. Overall, the car feels much more solid and predictable. was actually chucking the wheel a few times with very little concern - which was amazing progress since last drift event. I'm actually not super happy with my cooling still. was nearing approx 215 degrees after 4 hot laps. cool down was probably 5-10min or so. I'm going to actually try out the ebay 3row everyone else runs. I thought the mishimoto would have had a longer run. I'm just not happy with results as it was only 71 degrees that day in vegas, basically it would DIE in summers here. I'll also try to mount the fan not directly on the radiator this time around also, i'm not sure if that's going to work out or not. Really not happy about doing it a 3rd time so quickly, I also ordered a e34 fan shroud to test fit, new ngk spark plugs and oil change stuff. Might quite possibly order another 16" puller if i have to, but I'll mock everything up first before making that decision. I'll need to order more tires as well, but I don't plan to drift in the summertime this year (june/july are for sure not happening).
                      89 325i 4dr s52
                      • econti
                        • May 2014
                        • 1151
                        #431
                        What fan do you have? My E36 with ebay OEM rad never even tries to get hot in Aussie summer drifting, with a 2000cfm Spal 16" and a shroud.
                        • s14brent
                          • Mar 2014
                          • 571
                          #432
                          That's the thing, my e36 m3 never had issues as well. I'm currently running a mishimoto rad w/14" slim spal on it and I still have the ac condenser up front with a 16" spal. I plan on removing the condenser and putting in an 3 row aluminum and trying to get a shroud setup - will have to decide which spal fits better (14/16") and make new mounts for both. I always used clutch fans on my sr20's (s13/s14) and never had issues with a koyo copper - only slightly frustrating. I'm also using 80 degree thermostat and a stewart pump.
                          89 325i 4dr s52
                          • s14brent
                            • Mar 2014
                            • 571
                            #433
                            kind of annoyed i never knew about powerflex' 8mm offset radiator mounts (PFF5-4652). So i found out i broke one of the plastic radiator mounts (R side) and i think that was causing the shifting and rubbing of the e-fans (already rubbed the new 14" spal). anyways, ordered up some parts for some normal between track day maintenance.
                            before:
                            after:
                            removed the front end so i could take out the ac condenser and install the larger 16" spal pusher (1959 cfm)
                            pusher clears the oil cooler but i did add a little more clearance after this just in case.
                            Decided to do some normal routine maintenance.....still not done btw, just ran out of time. I dropped off 4 wheels to get some cheap 205/45/16 (accelera phi-r's) drift spares. I'll be picking them up in the AM and getting back to work on the maintenance list.
                            not sure why i ran the ngk ZGR5A's when I did the swap, but I went back to the BKR6EQUP this time around. it's not really rich, and not lean either, i've just never had my plugs so....brown. I used these plugs on my e36 m3 so i'm not sure why I'd run zgr5a's unless i was just sent the wrong ones the first time around and didn't notice?
                            decided to flush brake fluid since the last time I did that was when the clutch master was swapped (post swap)
                            front L bleeder valve was clogged for some reason. I rebuilt all the calipers and included new bleeder valves on all corners (before initial installation/not long ago), made a mess, not sure why it was so corroded but everything is fine now.
                            last time i took my skid plate off I tried to clearance it a bit to avoid making a mess during oil changes. It didn't really help. Still made a mess. I actually might pull it tomorrow to change out the oil level sensor O-ring before refilling the engine.
                            Last event I took out a cone and broke a couple clips that mount the IS front lip. Waiting on a few of those to come in before i remount the front valance/bumper.
                            ^ you can see the front lip dragging in this pic
                            The kaaz fluid will be replaced after next event. (i'm still not sure if i'm going to try and change diff ratio's yet, I'd love to just hold off for now). Not sure if i'm going to use MOTUL 90PA or torco RGO w/type F friction modifier. Not many mineral based lsd fluids out there, but I might go with motul since I am very familiar with them with my moto's.
                            I'm thinking about a couple things next. I'll just list them out
                            -sunroof cartridge delete (dtmfiberwerkz) for roll bar prep
                            -3.64 ring and pinion but i have a 3.73 on shelf but it might seem a bit...much
                            -roll bar preferably with door bars is still a go! (kinda leaning toward a custom weld-in setup with it tied into rear strut tower reinforcements)
                            -50 shot nitrous with msd window switch from like 3300-5000 rpm's only
                            -Link ECU G4X obd1 plug and play for prep for power adders
                            - koyo or mishi x-line radiator. bigger is better right?
                            89 325i 4dr s52
                            • s14brent
                              • Mar 2014
                              • 571
                              #434
                              Part 2: finally finished up the little maintenance work needed.
                              Replaced fuel filter (bosch) and cut to fit a fresh bit of fuel line for the 180 degree bend. I'll probably replace these more often and inspect the tank on a later date. I know the car sits for quite a bit even though the mileage is low since the last change. Maybe the Stabil fuel stabilizer and octane booster aren't the best things to be throwing in there. I'll order the oem hose next filter change, I forgot to order one and it will be a week for the local dealer to get one (same if i bought from fcp).
                              I also took the time to replace the oil level sensor O-Ring. I had to remove the skid plate to access this sensor.
                              I had a local shop throw on some cheap tires for drift spares. I also have an old take-off on the single 16x8 +0 to keep in the trunk as an emergency spare. Super excited for the next drift day, not sure if I can make it on the 8th for the next vegasdrift, I work on the 7th late at night and again in the evening on that Saturday. At least I'll be prepared I suppose.
                              I got 7 new clips (from local bmw parts dept.)for the IS front lip.
                              Threw on the 16x8 +16 GTA's in the rear with the 25mm spacer still on (-9 offset total in rear). I also threw the amber turn signal lenses back in. It's nice to have somewhat matching wheels on the car again.
                              The car sounds happier, fresh oil & new plugs for the win
                              89 325i 4dr s52
                              • s14brent
                                • Mar 2014
                                • 571
                                #435
                                Figured I was going to pull the sunroof cartridge out of the car eventually for more head room, and prep for roll bar. The factory headliner cloth was starting to sag in a few spots anyways so I decided to prep it a bit sooner than anticipated.
                                I gained about 1"-1.25" of head clearance and I'm going to guess about 50lbs off the roof.
                                I made sure to leave some material under the fold and keep the spot welded areas in tact near the X-brace for extra support.
                                decently heavy pile of metal from the cartridge cut out, the rails and cables weren't in the greatest condition and went straight into the trash bin so those aren't pictured.
                                Pretty happy how clean it came out. - so much room for activities
                                -- the only shitty part is i'm still waiting for the sunroof delete panel. My mistake, I thought I would weld on some tabs to the stock panel, but it turns out theres some surface rust on it, and I don't think it's worth skinning unfortunately. The panel is pretty heavy (14lbs apparently), fiberglass is only 3lb's, I just need to wait for manufacturing time.
                                As for cooling, well I went back to a 16" spal (ordered a new one) after all this time. I did mount it toward the bottom (L side) of the radiator this time around though (better clearance now that AC stuff is gone)
                                as viewed from the top L
                                as viewed from top R
                                I still don't think my problems will get magically better, I just know I was better off with this setup last summer and i'd rather have the larger surface area +260 cfm vs the 14". So now, 1959 cfm pusher and 1298 cfm puller vs 1604 cfm pusher/1038 cfm puller. Also there is still good enough clearance between fan motor and waterpump bolts, and ac belt ribs on the crank pulley. If I were building the s52, this would be a good reason to get an ATI damper I guess!
                                89 325i 4dr s52
