cameras ready prepare to flash
  • s14brent
    • Mar 2014
    • 573
    #541
    been a while since i could make time to work on the e30. Here's a small update.
    SRS e30 to e46/325 caliper adapters w/matching e46/325i rotor combo
    SRS 318ti to e46 caliper adapters w/z4 3.0 rotors
    I knew there was a difference. I'm glad I placed that order. I also ordered new parking brake hardware for 318ti but I'm not 100% its actually going to fit on this setup (more on that later).
    cleaned up the spots with surface rust on the backing plates. unfortunately I had to sacrifice some new wheel bearings (meyle/made in china) to mock everything up. I just ordered some FAG bearings last night.
    I picked up some brembo ceramic pads for the mock up also. I'll probably run these on the main pair of calipers all said and done and swap over the old pair of brembos to the secondary calipers. Funny enough, my rear pads on the e30 have a ton of life still
    fancy brake pad packaging ^
    I'm unsure if the parking brake hardware will still be usable because I had to actually trim so much more on these dust plates vs on my e30. I will only know once its all swapped over - I did not order a new star adjuster or cable adjuster so I won't know until I have the parts off the e30.
    I mig welded the secondary caliper brackets on last night, but i'm not super happy with the results. I had to up the argon flow and up the stick out to get the back side of the bracket but i'm not super happy with the results. I'll take a look again after I break the setup down again. I'll have to pull the wheel bearings out again and back to paint. This whole section is taking way too long with my limited garage time. I however have been getting some tig time in and its slow progress but i'm enjoying that - even though it just makes me want more and more tools lol
    89 325i 4dr s52
    02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
    21' Toyota Tacoma TRD OR 4x4 6 speed Manual
    • s14brent
      • Mar 2014
      • 573
      #542
      Looks like I took 2 months off from working on the e30 but I finally started working on it this week! I think last month I had a buddy over and let him use my garage to install his cage kits in his NA Miata, and I got pretty burnt out after that full weekend. I'm actually leaning further away from wanting a cage now, I think a roll bar should be sufficient. Anyways, I got sick and tired of the exhaust leak/intermittent CEL due the leak being before the o2. Soo this was definitely the priority fix. Fingers crossed no issues tomorrow on first start up. It's long overdue.
      up on stands and wasted no time, pulled the header, and and studs in 45 min. Not too shabby.
      I think about half of the nuts came off normally, the other half I had to double nut off. I think* i got these studs/nuts from bimmerworld the first time around. I decided to go e90 studs like I did on my hellrot e36 m3 long time ago.
      god those look so cool. too bad I probably won't even gain a single horse. At least the quality is a huge upgrade vs the ebay long tube headers I had on there previously. These are the syncro design works e30/24v shorty headers that I bought last year?!. I really wish they went v-band vs the 3 bolt flanges. Those were a PITA. Also the header-back section is from their early run exhaust system which was mild steel only. I got lucky to get the front chopped section, it really did make this so much easier to diy. The full kit they offer now is stainless btw.
      I did not know there were so many different type of o2 bungs. Of course I only had the worst type on hand (stepped) so welding was a bit tricky since you're basically welding on the edge of the hole. (I should also note, I'm trying to stay on a strict budget to make a december drift event so I decided to tie in my existing exhaust system for now). I know the o2 bung welds aren't pretty but i'm positive it will be just fine. It's just capped off for now, but that's the second o2 bung on the exhaust for the wideband o2..yes I'm still planning on installing the LINK ecu. Even though my setup will be very.....stock-ish. The only good thing about that stepped bung was that it was mild-steel to mild steel weld. I'm not outfitted with 2.5" purge plugs or v-band plugs for shielding. I probably need $250-$400 of tools for future stainless work, so that's a good reason the new exhaust was off the table right now since all new stainless piping would have been around $250-350 and i'd want a new resonator, flex pipe, and muffler......it all adds up so quickly.
      2.5" evil energy mild steel v-band actually welded decently to clean material. The other side......not so great. old dirty material, with minimal prep due to time.....never a good combo.
      The exhaust is all bolted up now, but its a bit too late to fire it up in the neighborhood. I actually can't wait to not have any more leaks. I think the next priority job is finally doing the rear subframe/trailing arms and getting another alignment after that. I think* that's doable before DEC 07, but I know we're expecting rain, so that may throw a wrench in the timeline.
      89 325i 4dr s52
      • Northern
        I like cupcakes & sh!tboxes
        • 5284
        #543
        Hot take on backpurging stainless... not worth the argon unless it's upstream of a turbo.
        Welds will still be plenty strong for an exhaust system. Nobody is ever going to see the sugaring, and if a piece breaks off there's nothing downstream that it can damage anyway.
        Originally posted by priapism
        Originally posted by shameson
        • patrick88m3
          • Nov 2025
          • 54
          #544
          The SDW headers look nice. I wonder if they'd gain much over stock s52 manifolds.
          • s14brent
            • Mar 2014
            • 573
            #545
            ^this is true but if i go full stainless i feel like that is a commitment to staying NA that i'd rather not do at the moment..still have turbo dreams eventually. And i'd rather build a SS system for a turbo setup honestly. I'm getting kinda tired of re-doing things on the e30 so many times over, I am trying to mark off days in the next 2 weeks to start on the rear subframe & trailing arm swap.
            Meanwhile I started the car up......ended up moving the factory o2 sensor up onto the new bung and got the car up to temp 3x yesterday. There wasn't any hiccups or CEL's but there is a small misalignment of the v-band. I decided the right thing to do is to replace that part of the mid section + v-band (on the dirty material side). The whole point was to get rid of ALL exhaust leaks, so a 2.5"- 45 degree bend and another o2 bung+vband was quickly ordered. I can get that knocked out in the time frame I gave myself as long as its delivered on time.
            Rain is on the forecast from today until next Friday, so any painting will be impossible within this timeline. I'm going to just reassemble the trailing arms with new wheel bearings and hubs and just send it. However if you're a f1 fan, the weather will make for an interesting practice/qualifying for sure. est. high 40s/low 50s and wet on las vegas blvd sounds like a bad time.
            89 325i 4dr s52
            • Northern
              • 5284
              #546
              I mean, no reason why you can't reuse most of it either way (stainless or not, if it works it works.). If you're going to turbo it down the road, you should be able to reuse everything aft of the firewall. (Although maybe you move that vband forward for ground clearance if it becomes an issue)
              I MIGed my 304 exhaust with 308L wire when I did my swap, then did my downpipe again when I added the turbo. I bought the rapidspool manifold, so I didn't need to backpurge that, and my WG dump was also MIGed.
              I TIGed my new vband flange to that downpipe, and when I recirced the WG, but I didn't back purge any of that either.
              I also find Vbands always warp, especially the nice vibrant ones because there isn't a lot of extra meat to them. I try to clamp one flange to the other and leave them assembled/in the same orientation so when they warp, they warp together... Also had decent success with TIG not warping that one flange, and the cheapo HFS clamps from amazon seem to be a good cheap-good-more meat to resist warpage combo.
              • s14brent
                • Mar 2014
                • 573
                #547
                i mean....yes for sure.. pretty sure they will have similar gains probably comparable to turners "shorty" headers which has been documented for decades now for e36 m3's.. to sum it up...not as much top end gains vs long tube headers but mid range torque is usually the power range increase with the shorty design. Sadly most long tubes don't fit ideally in an e30 due to the subframe clearance so the best would be a custom made set or a modified existing set of long tubes or even a modified euro s50 oem set... the china long tubes are made of pretty thin material enough that you can dent it in for clearance, I'm actually surprised they lasted this long under the abuse it was under. The SDW "shorties" would fall in the happy medium I'd say, and for my driving style and long term goals, the mid range torque is actually more ideal for hot lapping and the quality of the header is a big upgrade from what i was running beforehand.
                89 325i 4dr s52
                • s14brent
                  • Mar 2014
                  • 573
                  #548
                  Well my current setup is 2.5", and if I went turbo I'd def want to go 3". I cant really move the v-band forward enough to make it worth while because its a 2-1 merged section so it would be slightly out of round anywhere in front of that o2 sensor location. I did actually look into this before hot glue gunning it all together.
                  So this is kinda....lulz.....but you totally reminded me...I actually have the mig setup to do SS if i wanted, even have a 55cf bottle helium trimix and should have a small spool of er308L/309L! I actually forgot about that. However, I really am preferring tig over mig now days, but i will dig out those spools and set them closer to the mig now that you reminded me.
                  as for v-band warpage.....strictly modified makes a very nice back purging cap/heat sink for v-bands but they're about $100 ea size but I will just be ordering an extra set of v-bands for the time being. I don't plan on doing a lot of them after this tbh!
                  I don't think HFS makes 2.5" v-band clamps for some reason. I see 1.75/2/3/3.5/4 offered, just my luck!
                  Thanks for all the feedback, its definitely been useful.
                  89 325i 4dr s52
                  • patrick88m3
                    • Nov 2025
                    • 54
                    #549
                    But the 180 dollar price tag on them speed daddy headers is tempting lmfao.
                    • s14brent
                      • Mar 2014
                      • 573
                      #550
                      so i ordered a 2pk of v-bands and these ones came with flat sealing surfaces vs the stepped ones.....so i had to order the same one initially.....weird. yeah the pipe looks like crap inside. part of the reason why i wanted to replace that whole section tbh.
                      cut up the 45 degree bend i ordered off amazon....new bandsaw jig works great.
                      I really am having a hard time working in my small space....i used my mig to tack up the new section in place. its a little bit more tucked up than the previous as well.
                      I realized later I should have used jackstands to help with the positioning.I really think radiused o2 sensors are the way to go. I have used the two worst style ones so far. I also used some spare fresh pipe bends I had laying around. I kind of wish the material matched, oh well....
                      skip to the next morning....exhaust all lines up perfectly and no leakage.v-band clamp can be rotated up further so it looks like better clearance this time around. feels good to have this step completed. Going to drop the rear section of the exhaust next and start prepping to drop out the rear subframe mid week. I've made an appointment for an alignment already so I have a deadline to reach. FUN!!
                      89 325i 4dr s52
                      • econti
                        • May 2014
                        • 1152
                        #551
                        Can we get a chip check
                        • Northern
                          • 5284
                          #552
                          Brings back memories of buying cheap vbands for various exhaust/downpipe stuff. Realized 3" is more of a range than an actual measurement and nothing every plays nicely together lol.
                          I still have a few of the non-stepped/non quick release ones somewhere that I should purge from my inventory...
                          • s14brent
                            • Mar 2014
                            • 573
                            #553
                            i'm only used to that term being used on poker/blackjack tables......pretty sure that's not what you meant here LOL
                            Funny enough, the actual clamps included with the cheap/flat v-bands are better than the ones that came on the stepped ones......not sure what the heck is up with that.
                            The cheap v-bands came with the clamp on the right which holds the bolt in place. the clamp on the left -the bolt falls out (and also takes up more physical space). Makes no sense to me as they are both made by evil energy or whatever.
                            i thought black friday sales would be minimal this year but the list keeps growing more expensive......so far i bought a bunch of welding consumables, another link pressure sensor and the 2m can extension cable.....a can-lambda mounting bracket, and have a growing cart on DW to at least relocate/change to a 10micron fuel filter setup. I still haven't placed the DW order yet because I'm not sure where I want to mount the fuel pressure sensor yet, but i'm thinking of just mounting both inside the trunk for future surge tank install....I would need to weld-in the rear strut tower reinforcements first though if that's the plan.
                            i lost track of time clearly.....powdercoating doesn't fit the time line unfortunately.....vht rollbar paint applied (over the eastwood rust encapsulator) on the trailing arms. My current reinforced trailing arms on the car was rattle canned 6 years ago and they held up decently (i think). I'm hoping to start assembling them by Wednesday..I'll start taking out the current setup hopefully on Tuesday!
                            89 325i 4dr s52
                            • Northern
                              • 5284
                              #554
                              I like the left side because you don't need to do a bunch of ratchet action to get the clamp off, Although if the angle of that tab is wrong I could see it pop off like you're saying.
                              Also means you can replace just the t-bolt if you ever destroy the threads (guilty of this... I covered one of my vibrant ones in welding spatter and wiped the threads off it when I ran the nut off the first time)
                              • s14brent
                                • Mar 2014
                                • 573
                                #555
                                well i finally started on the rear subframe swap. what a huge pain in the butt....
                                pulled the old setup out
                                fresh bearings....again....
                                parking brake hardware installed. i actually used one of the e46 springs (upper) because the one that came with 318ti hardware kit was small and fully coiled across making contact with the adjuster wheel.....weird.....but i dont like to play with springs with that much tension tbh...."you'll poke your eye out son!"
                                10x MH extended studs cleaned and reinstalled with the hub, loctite applied and double nutted to spec
                                assembled and looking pretty.
                                I got caught up in a little side questing.....replaced garagistic secondary diff mount bracket hardware. They included 5/16" bolts/nuts. I swapped them out for grade 8 m8's/flanged nuts and locking washers. Putting the fresh subframe assembly in was more of a PAIN than I remember.....I'm not sure why it was fighting me so hard this time around. fresh zimmerman rotors and brembo oe pads for the primary rear calipers. Reusing the BOSCH pads on the secondary calipers for now. I'm hoping to button this all up by Sunday.
                                reinstalled and looking good. Meanwhile, I need to bleed the brakes and fill the diff, bolt on the rear section of the exhaust and hope everything will be all good to go by tuesday (alignment appointment).
                                89 325i 4dr s52
