Turb'02-- Currently welding!
  • semaj4712
    • Mar 2012
    • 3069
    #31
    Whats the A/R on that turbo?
    29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
    72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
    Gewerkschaft der Polizei Sticker/Clings For Sale $8
    • AdOz
      • Jun 2015
      • 114
      #32
      Decided to make the tank fit in the spare well.
      It is protected here and can be mounted low enough to pipe in the original filler!
      Just meant chopping and welding the mounts
      TURB'02
      INSTAGRAM
      • AdOz
        • Jun 2015
        • 114
        #33
        It's a rare one this is the basic spec for it as described by compressor racing.
        Large alloy Holset compressor housing with 4inch inlet with MWE Map Width Enhanchment anti-surge ports, and 2.5in v-band outlet.
        Massive 76mm 7 blade compressor wheel (Same size as the 550bhp Garrett GT3076R) with 52mm inducer capable of 500bhp+.
        Oil cooled core with 360deg thrust bearing and heavy duty shaft.
        High flow 65mm turbine wheel with 52mm exducer (Alll GT/GTX28 series turbo have a 54mm turbine with 47mm exducer).
        Quick spool 7cm (a/r .49) turbine housing with T2/25/28 inlet flange, 2.5in v-band outlet flange, and integral wastegate.
        TURB'02
        INSTAGRAM
        • AdOz
          • Jun 2015
          • 114
          #34
          Mounted the tank on 5mm rubber pads stop vibration and allow expansion and movement
          The new feet are welded and secure
          New spout takes a 2 inch hose and pipe work will link up to the filler.
          The height of this is to prevent slosh back even though the tank is foam filled liquid will naturally try to fill the tube. It's cut out inside so will easy flow enough from a pump. The beveled end may be ott but it only took a minute so why not!
          TURB'02
          INSTAGRAM
          • varg
            Florida Turbo Man
            • May 2014
            • 3417
            #35
            Tigging everything up, looks nice! I need one of those in my life.
            IG @turbovarg
            '91 318is, M20 turbo
            • AdOz
              • Jun 2015
              • 114
              #36
              There is still so much I need even parts wise! Big delivery on Friday of repair panels etc. the shell needs a lot of work and I want to correct some of the shit water traps etc in the original design plus the arches to fit too!
              TURB'02
              INSTAGRAM
              • AdOz
                • Jun 2015
                • 114
                #37
                Parts day! It's nearly all OEM
                Rifle butts
                Wing mounts
                Rear subframe mounts
                Turbo body fixing kit
                Rear panel lower
                Floor pans
                Sills
                Was nice to see some of these stickers on them
                TURB'02
                INSTAGRAM
                • deutschman
                  • May 2008
                  • 5958
                  #38
                  nice. good looking welds.
                  • AdOz
                    • Jun 2015
                    • 114
                    #39
                    I can't take credit for the TIG work I wish I could but I've never tried and didn't fancy practicing on an expensive tank! But I was impressed with my friends work
                    TURB'02
                    INSTAGRAM
                    • AdOz
                      • Jun 2015
                      • 114
                      #40
                      After drilling and attack spot welds...
                      Old vs New
                      Going to need some work before refitting that one!
                      TURB'02
                      INSTAGRAM
                      • AdOz
                        • Jun 2015
                        • 114
                        #41
                        EDIT information found...
                        More progress to come soon.
                        TURB'02
                        INSTAGRAM
                        • AdOz
                          • Jun 2015
                          • 114
                          #42
                          M20 flywheel and starter! The clutch will be getting replaced with a Sachs 618 PP and 6 puck
                          TURB'02
                          INSTAGRAM
                          • AdOz
                            • Jun 2015
                            • 114
                            #43
                            Gave the flywheel a good clean up! Would you say this needs to be skimmed or is this normal wear? It feels flat so it's possibly only a few thous of marking tops
                            TURB'02
                            INSTAGRAM
                            • stanhayward
                              • Mar 2013
                              • 765
                              #44
                              Hmm I'm no expert but when I put my turbo engine back together I didn't have mine resurfaced, albeit it looked a little less marked up. How old is the flywheel? Mine had been resurface about 4000 miles previous though so if this is the original flywheel you might want to for peace of mind.
                              1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
                              1984 316 Coupe - The Base Model - Pain in the Ass
                              1988 750iL - The Daily Driver
                              ...And a couple others...
                              • ccsdo5
                                • Mar 2013
                                • 708
                                #45
                                If you're going to be putting a new clutch and pressure plate on it I would say go get it resurfaced.
                                -Dee
                                5-lugged turbo 318is Barn car
                                IG: @deebelmont
