I have an E 30.
  • moatilliatta
    • 6158
    #271
    Roughness average https://www.cometic.com/tech-support
    Seems like if one leaks it from original finish.
    There are a few 4 bar Porsche regulators left in stock, I seen some the other day while shopping for parts.
    But good to hear its running well. Any stand alone ECU in the future?
    Find and octane booster that works the "Best"? I've had a can of royal purple stuff in the trunk for the "Just in case" moment I get cruddy fuel.
    @Zakspeed_US
    • 2mAn
      Señior Mod
      • 21067
      #272
      I know that sssquids newer MAF conversions seem to be much better than the older MAF conversions that were sold, another alternative
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • moatilliatta
        • 6158
        #273
        Has only got a solid tune yet from the SSSquid maf conversion?
        @Zakspeed_US
        • It's Soda Not Pop
          • Jan 2022
          • 877
          #274
          I have one that I order at the end of last year. The MAF from SSSquid doesn't require a tune you can use an OE chip. You can also use any of their custom chips as well without a retune. I have Version 19 I believe with a 2.7i (Squid Stage 2.5) chip. The only issue I have is that every once in awhile it cuts out. But for just a brief moment and it's not to bad. I'm the bugs will be worked out as they go.
          88' Seta 2.7i Zinno
          https://www.r3vlimited.com/board/for...430-my-88-seta
          • Nader393
            • Dec 2015
            • 408
            #275
            I don't know why everyone is trying to improve on the AFM; I was down that road before, and I don't think the juice is worth the squeeze. I had the Miller MAF and didn't notice much improvement, and ditched it when it (the chip) gave me issues. I prefer the stock looking airbox as well.
            I do need to address the tuning. Need to dial back the ignition advance, and raise the idle a couple hundred RPM because that lightweight flywheel makes it stall easily. I could spend $400 for another chip, but might be better off with a Megasquirt ECU and live custom tuning on a dyno. Finding a shop to do that locally is another hassle. Any recommendations for the Seattle area?
            '91 325i
            • moatilliatta
              • 6158
              #276
              I wouldn’t limit your self to megasquirt. Maybe reach out to race shops / Tuners and see what they use and go that route. If nobody supports your system, it’s useless.
              @Zakspeed_US
              • It's Soda Not Pop
                • Jan 2022
                • 877
                #277
                Mine utilizes the factory box. Either way if I was going stand alone. I wouldn't worry about a maf at all.
                88' Seta 2.7i Zinno
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5284
                  #278
                  I think the MAF conversion (either sssquid, ba114, or DIY - not miller's dumpster fire) makes sense for anyone who needs to replace their AFM vs the cost to rebuild/buy new.
                  I think there's a gap between that and megasquirt, either the cost to get it tuned or the interest/ability to tune it yourself.
                  Originally posted by priapism
                  Originally posted by shameson
                  • Nader393
                    • Dec 2015
                    • 408
                    #279
                    Well, it's decided, I've booked dyno time at 22RPD. They look good on the internet and Instagram: https://22rpd.com/
                    I noticed this blog, which is reassuring: https://22rpd.com/blog/classic-with-...irt-mspnp-gen2
                    They're able to flash a custom chip while live tuning on the dyno. I think that's ideal for my purposes. I think this is the light at the end of the tunnel. Stay tuned... (see what I did there?)
                    '91 325i
                    • Nader393
                      • Dec 2015
                      • 408
                      #280
                      Just got my car back from a full day of dyno tuning at 22RPD. Any guesses on RWHP? Here's a refresher on what's in my engine:
                      2.9L M20 engine:
                      Block: M20 ETA block bored to 85mm by C&D Engine Performance
                      Pistons: 85mm Mahle Powerpak, 10:1 compression ratio
                      Rods: S52, balanced
                      Crank: M52B28 with Metric Mechanics pulley spacer
                      Fasteners: ARP head studs, ARP main bearing studs, ARP connecting rod bolts
                      Head: Supertech valves, Schrick performance springs, dual pattern cam (280/274), IE H.D. rockers, porting by C&D
                      Head gasket: Cometic MLS 86mm, .070” thick
                      Chip: 22RPD custom live dyno tune
                      Stock air intake box with K&N filter
                      Ireland Engineering heavy duty red spark plug wires
                      Bosch Type II 19lb fuel injectors
                      Malpassi adjustable fuel pressure regulator
                      New stock fuel pump
                      Racing Dynamics headers
                      Magnaflow 2:1 exhaust, no catalytic converter
                      '91 325i
                      • e30austin
                        • 15382
                        #281
                        i'm gonna say 175 at the wheels.
                        • Nader393
                          • Dec 2015
                          • 408
                          #282
                          Whoah! An hour after posting this, I got 183 PMs with earnest HP guesses, and 22 decent offers to buy the car outright.
                          Well, not that many... Actually, none at all. No guesses, no offers to buy. I was lying. Maybe if this was 2015 again. Or if I was on Facebook (or is it Instagram?) I dunno, I'm old.
                          But I'm not lying about this dyno graph of my PREVIOUS untuned 2.7 (or is it a 2.8?) engine, RWHP. This is the verified stroker engine I bought on Craigslist for <$3K (transmission and full exhaust included), and is what replaced the fake Metric Mechanic 2.9 that was actually a tired stock engine when I bought the car. All documented earlier in this thread. Knowing what I know now, I most certainly could have gotten more power out of this with live dyno tuning. I'm posting this as my previous baseline, back when after the first transplant I thought the car was spicier than ever. Like a 4-star spice rating for your Thai take-out. Again, this is the PREVIOUS engine, which dyno's out for RWHP slightly better than stock. (It felt extra fast because of the short 4.10 rear diff.) This is not the current engine.
                          '91 325i
                          • Nader393
                            • Dec 2015
                            • 408
                            #283
                            Hi Austin. Good to see you here. That's a reasonable guess. Let's hear what other have to say (if there are any others anymore).
                            '91 325i
                            • 2mAn
                              Señior Mod
                              • 21067
                              #284
                              2.8ish with 10:1 CR is good, but the cam seems a bit mild. proper tune and a wilder cam should be closer to 200whp... my guess is 190 Bob
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              • moatilliatta
                                • 6158
                                #285
                                22rpd always seems a bit high. 191 bob
                                But 170 on other dyno jets.
                                Thanks for being old and coming back.
                                @Zakspeed_US
