2.8L M20 9.8:1 stroker build: my 323i reincarnated
  • BUDNUNTA
    • Apr 2005
    • 996
    #271
    Can't you buy a new or refurbished AFM and then have someone use a MOATES emulator and burn you a new dyno tuned optimised chip?
    We're out there in here.
    • digger
      • Nov 2005
      • 6198
      #272
      it cant be that hard to find a decent AFM, the alternative is quite a bit more involved than an AFM swap
      • Digitalwave
        is a poseur
        • 6299
        #273
        I just sold a fully refurbed AFM for $175. BavRest still does it, but it's half the price of an MS2.
        RISING EDGE
        • betz
          • May 2016
          • 317
          #274
          Got the wideband installed over the weekend. Wiring had some difficulty because it seemed the O2 sensor wasn't getting any 12V power. I ended up wiring the output of the fuel pump relay to the output of the O2 sensor relay, so that whenever the pump was running, the O2 sensor would be too. Which is fine. I'm just wondering if that means my O2 sensor was never getting power..... Actually I know it wasn't. Cus i wasn't getting any voltage to it measured with my multimeter. Not at the relay input or at the pin at the O2 sensor plug while the car was running. But I'm pretty sure it would still work because the 12V is just for the heater... but idk.
          Anyways, here's a readout of my car at various RPMs sitting in my driveway in neutral. Looks like I have a ways to go to perfection.
          O2 sensor is working overtime to correct. But it looks like it's doing a really good job at correcting. I think I will be messing with my fuel pressure and maybe the AFM a bit to try to get it better. Car seems to be driving well enough in the meantime.
          In other news, also put in the 750il master cylinder. Pedal feel is like a brick wall but it still takes quite a bit of effort to push the brakes. I'm thinking since my brake booster check valve is smaller that it could be reducing the amount of boost significantly. Will put a simple coupler in place of the check valve and see if that makes a difference. If it does, I'm off to find a bigger/ better flowing check valve. Or maybe just OEM.
          '86 Burgundrot 325 2.8 stroker.
          Other cars:
          2000 Porsche Boxster
          2006 Subaru Outback XT 5MT
          1972 Porsche 914
          • Andre3127
            • Dec 2017
            • 291
            #275
            AFM rebuild tutorial found on YouTube:
            Budget E30 Parts - Used and Reconditioned parts for your BMW
            • betz
              • May 2016
              • 317
              #276
              Finally took my car to the body shop. The radiator support had actually quite a bit of damage (somehow?) so I decided to do it right and replace it. The car still needs a few tweaks to get it perfect, they said I could bring it back if I noticed anything so I'll take them up on that offer. Right now the center piece that the kidney sit on is a little higher than the rest so the hood doesn't want to close when the kidney grill is in. But I have +1 grill! Haha.
              This pic I just have it set in there after closing the hood :/
              I decided to paint the fender myself which was kind of a bad move. Cus it was a total pain haha. The paint match I got is actually really really good however the shine is a little less than the rest of the car. I'll try more buffing but it might need another coat of clear.
              Other cars:
              1972 Porsche 914
              • wworm
                • Dec 2016
                • 1719
                #277
                I'd give it a few more coats of clear. You can kind of see the depth of the clear on the other panels. Factory clear coats tend to be thicker than most people think.
                Color match looks really good too.
                1984 Delphin 318i 2 door
                • betz
                  • May 2016
                  • 317
                  #278
                  Good call.
                  Other cars:
                  1972 Porsche 914
                  • wworm
                    • Dec 2016
                    • 1719
                    #279
                    eyy! that looks great! I have a spare lip that should fit that bumper if you need one.
                    • betz
                      • May 2016
                      • 317
                      #280
                      Thanks but I had bought a new one for my 323 that should fit fine. Although, have no idea what the correct hardware to mount it is since last time I clearly ordered the wrong stuff haha.
                      Edit: shoot it looks like the "e" one is actually different. Mine has the brake ducts in them
                      Other cars:
                      1972 Porsche 914
                      • mr.
                        • Jun 2013
                        • 513
                        #281
                        Burgundrot is my favorite color ever
                        • Aufbau Principle
                          • Jan 2013
                          • 121
                          #282
                          86+ early models and verts with diving boards have a different front valance and lip. More squared off in the front vs. the sloped in one on the 85 and earlier cars. You'll want to look for the '772' euro valance if you decide to fully convert the front.
                          This one's mine with the 772 valance and 'Jimmy Hill' lip:
                          I've got a set of those Melber weaves too, waiting for tires to go on, we'll have similar cars haha.
                          • wworm
                            • Dec 2016
                            • 1719
                            #283
                            Jimmy hill lip is the greatest lip of all time.
                            • betz
                              • May 2016
                              • 317
                              #284
                              Sweet ride. Pretty much where I'm trying to get my car, only... burgundy. Lol. And maybe some Mtech1 bits if the opportunity arises.
                              I actually have a euro valence (this one) but I don't even really know how to mount it to be honest.
                              The "Jimmy Hill" lip... is it this one?
                              Looks really nice.
                              Other cars:
                              1972 Porsche 914
                              • Aufbau Principle
                                • Jan 2013
                                • 121
                                #285
                                Looks really nice.
                                That's the lip. I got lucky and snatched mine up from a local, wasn't about to drop that kind of $$$$ for a lip on a daily driver. I believe there are a few fiberglass copies made and a few guys in Australia who can source them.
                                You need this valance to mount the 'facelift early model' lips: http://www.classiceuroparts.com/prod...ler-lip-apron/
                                I got an aftermarket one from German eBay instead of OE. Came bent up in the mail but straightened out OK.
                                The one you have is the 85 and below lip. It would let you run the 'Pfeba' lip. I had one before I found the Jimmy Hill. It's also a nice look:
