e30mclow's e30 #14 - Now 1.5jz + 6 Speed
  • e30mclow
    • Jun 2010
    • 196
    #211
    Originally posted by moatilliatta
    That's a rad trip, I've always wanted to go to Targa Newfoundland.
    I know, the Targa would be amazing. For now I'll settle for Autocross on Bell Island. The thought of having to get a ferry to an island to rip at autocross all day is just brilliant.
    I didn't know stretched axle boots were a problem?
    Re the boots: It is a theory that only exists in my head.
    I've bought e30s with good, albeit old boots, only for them to fail shortly after I slam the car. It has happened every time.
    Seemingly with a low car, you're at the end of the splines, so when you add additional squat under power, I assume things are stretched moderately beyond their intended position.
    • s14brent
      • Mar 2014
      • 570
      #212
      that's pretty cool, never knew they had axle spacers like that available. I ordered a pair of spacers and bolts to throw in mine (cheap insurance).
      89 325i 4dr s52
      02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
      21' Toyota Tacoma TRD OR 4x4 6 speed Manual
      • Northern
        I like cupcakes & sh!tboxes
        • 5246
        #213
        Watch the potholes in NS on the way through lol.
        Hit one and you'll find yourself in the plot of Journey to the Center of the Earth.
        I saw those spacers as well but I also don't think there's an issue. I think I read somewhere that it was for a specific axle combo, but I could be full of shit.
        Originally posted by priapism
        Originally posted by shameson
        • DEV0 E30
          • Oct 2004
          • 8892
          #214
          I'm absolutely loving this thread.
          You have excellent taste in wheels too.
          • Mkcustoms88
            • Mar 2015
            • 56
            #215
            I also live in Halifax , Nova Scotia and your right, you can drive into a pot hole and walk out lol
            • e30mclow
              • Jun 2010
              • 196
              #216
              Some updates.
              It is now all back together and on the road.
              12K Front & 14K Rear
              With those in I reset the rear alignment and finally managed to achieve -0.3 to -0.5 degrees of camber, which should help tire wear and grip.
              I also replaced the now very tired Garagistic front sway links with far more robust Volvo C30 rears. This was a nice little discovery.
              The Moog items have grease fittings and are beefy as hell.
              With that, a little bit of testing was required with the 180TW tires that ultimately caused the rear end destruction last season.
              2nd & 3rd gear clutch kicks are no longer an issue
              Other than that, I'm now down to two cars from four, with the two e30s winning.
              I sold the Pajero Evo and 750i to make the big move easier, but there's no way I'm parting ways with these e30s!
              • 2mAn
                Señior Mod
                • 20817
                #217
                This is what Winning looks like
                Simon
                Current Cars:
                -1966 Lotus Elan
                -1986 German Car
                -2006 Volkswagen Jetta TDI
                Make R3V Great Again -2020
                • e30mclow
                  • Jun 2010
                  • 196
                  #218
                  No it isn't, this is:
                  FYI - a 4% slope is what's needed to drive from the trailer into the truck.
                  The clutch master took a crap before leaving so I had no choice but to squeeze the white car into the truck.
                  Having made it here, I beefed up the master setup as some flex was leading to misalignment wear on the Wilwood piston.
                  She's now golden and I have the first autocross event of the season this weekend
                  • Northern
                    • 5246
                    #219
                    NB moose sign???
                    • e30mclow
                      • Jun 2010
                      • 196
                      #220
                      Originally posted by Northern
                      NB moose sign???
                      Yes sir!
                      When it is fun run time at Autocross, I try to have fun
                      My grinding 2nd was my clutch stop having backed out a couple of turns :(
                      With those tires toast, it was back to the RSs. I also installed the CA Tuned SE/iS sideskirts & DTM Mirrors
                      I'm in the process of gathering diff rebuild parts as my input bearing is making a lot of noise.
                      I'll be adding a 3rd clutch plate, but in the meantime I may need to swap in a high ratio spare.
                      • It's Soda Not Pop
                        • Jan 2022
                        • 877
                        #221
                        Bro you have great taste in toys
                        88' Seta 2.7i Zinno
                        https://www.r3vlimited.com/board/for...430-my-88-seta
                        • e30mclow
                          • Jun 2010
                          • 196
                          #222
                          Almost a year since I've updated this.
                          Still a beast!
                          Photo dump:
                          My CD-009 lost 5th gear at the end of last summer, so I carried on without it until the snow started.
                          It turned out to be the dog ring or whatever it is called had snapped off of the input/5th gear shaft. To solve this, I bought a 370z shaft (different) from the dealer along with the updated CD-00A synchro. I then used and angle grinder to the get the bearing offset "correct" and was back in business.
                          A $350 surgical success versus finding a new trans.
                          Carnage:
                          This is where the 370z CD-00A shaft has more meat than the CD-009.
                          CD-009
                          Grinding
                          Back together
                          The engine got a basic refresh and some esthetic changes
                          OEM style Toyota logo, but with "single" instead of Twin Turbo
                          I went with a far less aggressive clutch as the Stage 4 item had a painful pressure plate to actuate in traffic.
                          Cheap 350z item off of Rock Auto for something like $250
                          I've been clutch kicking 3rd-4th with no complaints so far.
                          After 20 years of driving e30s sideways, I finally decided to install a hydro. The only reason I did, is because with the engine and trans out, it seemed like the time.
                          I wanted to keep things OEM-ish, so I chopped up the stock handbrake ratchet and made a quick and dirty bracket using a stick welder, as I was out of gas. The handle is off of an old jack. The master cylinder was laying around from a previous clutch setup.
                          Total cost, about $40 in fittings.
                          Works like a dream and keeps the ratchet for parking.
                          I will be arrested as it is addictive.
                          I finally made the step away from trying to make a 2 piece driveshaft work. It works great for a few months, then the joints and splines start to fail.
                          Magnum dong
                          A Toyota flange is the same PCD at the e30 diff, you just need to modify the seat by like 1-2mm so it centers within the e30 diff recess.
                          Beefy
                          The diff then complained in style...
                          I, a man without machines, then painfully resurfaced the damage
                          3 new plates and clutches, and it was back into the car.
                          As of this week it is back on the road and feeling better than ever.
                          I used the low offset GTAs in front to give allow for max angle on 205/45s, while the et15s in the rear can comfortably allow for the 225/45s.
                          • s14brent
                            • Mar 2014
                            • 570
                            #223
                            nice update! how do you like the 225's in the rear? I was thinking of doing the same soon (actually just noticed there aren't really a lot of "cheap 225/45/16 options stateside anymore). 205/45 rears aren't lasting long at all even with my lower hp setup at drift days and i'm trying my best not to go to 17s
                            89 325i 4dr s52
                            • e30mclow
                              • Jun 2010
                              • 196
                              #224
                              They are a step up in grip alright, but it is an expensive step.
                              There is no reasonably priced 225/45.
                              I'm wearing them pretty evenly, which is nice
                              I am opposed to going to a 17" wheel and going 245, just because of the visuals of 17s.
                              I ran these for a drift day and it was interesting lol
                              • e30mclow
                                • Jun 2010
                                • 196
                                #225
                                Maaaan I need to update this thread soon.
                                The 1jz developed crank walk, so I went 1.5jz with a 2jz bottom end. I then spun a bearing in that, rebuilt it, and have since gone E85.
                                I've also moved from Newfoundland, Canada, back to the US - Ohio!
                                Currently 3.0L bottom end, 1JZ non-vvti head, 650cc injectors, GTX-3576R, Link ECU and Flex Fuel.
                                Going to step up to 1000cc injectors shortly, after I finish my Bosch iBooster setup.
                                Also doing Porsche things
