Its been a little while...
  • nefarious7907
    • Jan 2005
    • 1170
    In fact the last time I remember posting Jordan was still around.
    1984 BMW 325e
    My List of Mods:
    Supension
    -BF Goodrich Traction T/A's 195/60/14
    -Bilstein Sport shocks
    -H&R Sport Springs - front 182/rear 343 lbs/ 1.3 inches lower
    -Turner Motorsports Rear Shock reinforcement plates
    -BMP Design Peformance Rear Shock Mounts
    -BMP Design Urethane Sway Bar Bushings F&R
    -M3 Offset Control Arm Bushings
    -M3 14.5mm Rear Sway Bar
    Performance
    -BMP Design Cold Air Intake w/ K&N Filter
    -ANSA Cat Back Exhaust
    -MSD Blaster 2 Coil
    -Ireland Engineering 8mm Spark Plug Wires
    -AC belt removed
    -Taylor Ground Wires
    -Bosch Platinum +2 spark plugs
    -Braided Steel Fuel Lines
    -Redline Fluids
    -Port Matched Exhaust
    -Pro Formance Chip
    Brakes
    -Brembo Drilled and Slotted Zinc Washed Front Rotors
    -Hawk Performance Ceramic Brake Pads
    -DupliColor Black Painted Calipers
    -ATE Super Blue Brake Fluid
    -Speed Bleeders
    -Korman Stainless Steel Brake Lines
    Interior
    -Koala Motorsport Door Reinforcement plates
    -M-Tech Pedals
    -Lighted Window switches
    -Black Suede Covered Rear Shelf
    -UUC Ver. 3 Clutch Stop
    Electronics
    -Hella H4 headlight conversion
    -PIAA Super Plasma bulbs
    http://www.cardomain.com/ride/657387
  • Van Westervelt
    • 9365
    Post more often! :) Clean car, nice eta too, not many people take that much pride in them. Its nice to see. Oh yeah, are you missing a fender?
    • Ray Smoodiver
      • Jun 2004
      • 8809
      That is not the gold car I remember.
      • chuckybob
        • Aug 2004
        • 952
        freaking clean. nice mod list too. how much did you dump in to that?
        : : 1984 318i : : PNW E30 Crew : : Sold!!
        Now becoming the R3vlimited Pro3 car
        http://www.r3vlimited.com/board/showthread.php?t=93780
        • BMDub
          • Sep 2006
          • 122
          very clean eta, keep up the good work
          • moatilliatta
            • 6155
            original bronze car?
            @Zakspeed_US
            • DEV0 E30
              • Oct 2004
              • 8903
              Someone destroy your fender and driver side grill?
              • nefarious7907
                • Jan 2005
                • 1170
                Sort of, I just hung the battered fender it on a few weeks ago but I seem to have misplaced the hardware to fasten it all the way down so its holding on for dear life by the top bolts. I have a new fender but I would rather fix my rear suspension that have the fender painted. but it will get painted sooner or later
                Yes
                Yes, the one time I park close to a store, that does not have cameras on the parking lot, someone swipes the whole side of my car. Their car was white too :(
                Thanks
                Thanks, Too much :) I have a few grand into it now, and I am going to start the rebuild of the entire rear suspension and shifter in 2-4 weeks.
                I am going to putting in an M-Roadster shifter and replacing every nut and bolt in the sheet metal shift console
                My shopping list for the rear suspension and brakes:
                AKG Derlin Subframe Bushings
                AKG/IE Trailing Arm Bushings
                Turner/Zimmerman Cross Drilled rear rotors
                Hawk HPS rear brake pads
                Rebuilt Axles
                New Seals for the diff
                New rear wheel bearings
                and a bunch of OEM nuts,bolts and brackets
                Good times
                Thanks again everyone for the positve replies
                • nefarious7907
                  • Jan 2005
                  • 1170
                  The maintence list is way more impressive :)
                  I dont even have half of it on my cardomain page, I would like to think that I bought more than just a pair of seats and shell but I am going to end up replacing almost everything else.
                  A windshield and black lockstrips are soon to come. As well as getting all of my stereo stuff installed.
                  • nefarious7907
                    • Jan 2005
                    • 1170
                    Interior upgrades are going to consist of
                    Sparco 345 steering wheel
                    Leather shift boot
                    BMW Sport leather shift knob
                    E30 M3 ebrake boot
                    E46 ebrake handle
                    Autopower Roll Cage
                    Scroth Harnesses
                    Parker Performance Ash Tray Gauge Pod
                    Stewart Warner Volt and Oil Pressure gauges
                    • Digitalwave
                      is a poseur
                      • 6299
                      The hood on the paint looks extremely hazy. I love that brake setup though.
                      RISING EDGE
                      • nefarious7907
                        • Jan 2005
                        • 1170
                        It is hazy, the trunk lid is fubar or I would take a pic from the back. Someone tried to pry my trunk lid open and ....... lets just say that is not pretty.
                        • Digitalwave
                          is a poseur
                          • 6299
                          That really sucks man, were they just trying to break into your car? In my parts they just smash whatever window works best for them...
                          RISING EDGE
                          • nefarious7907
                            • Jan 2005
                            • 1170
                            Yeah they did get into my car but I had just sold my headunit that same day, My dash only had one crack in it, and I think they got mad and hit my dash a couple of times and then punched my surround for the radio. My passenger side door was wide open, but my other door was locked still as well as my trunk, my trunk lid doesnt close all the way and it kinda leaks on the passenger side where they pried on it. It makes me mad, but they caught the guys who did it breaking into someone elses car because the detective dusted my pass door for prints which were obvious because I had just washed my car and they matched prints for someone who got caught a week later. Justice wasnt served though because I didnt get shit from my insurance company and my car a year and a half later is still fubared
                            • rede30
                              • 4697
                              sweet
