my new nurburgring whip
  • Eric
    • 5142
    #301
    It sucks that the only updates I have for my lovely E30 is vids of the E28 doing what the E30 should be doing! None the less, I had a fun time today out at the auto-x, and again got the class win & top PAX time!!!
    Here is a super trendy instagram photo of the E30 as it hibernates this summer.
    • downforce22
      • Aug 2009
      • 3192
      #302
      we need another canyon run video eric!!
      • lambo
        Captain Scene Points
        • 10953
        #303
        That's backwards...it should be hibernating in the winter :(
        • Eric
          • 5142
          #304
          You Sir found the sarcasm hidden within the sentence. +5 internets.
          • Eric
            • 5142
            #305
            Today I picked up the tires. I had them balanced on the Hunter Roadforce machine, and they took very little weight for such a big tire!
            As soon as I got home, I was able to steal a bit of time in the garage, and test fit these monsters on the car.
            a "bit" of trimming is going to be needed.
            clearance on the inside of the wheel well is a bit tight! This is the backside of the wheel well by the muffler section.
            This is the clearance between the wheel and the trailing arm
            Since the E30 is still broken, I've been taking the E28 out to the local BMWCCA auto-x. The way the point system works for classing, the M5 is at the very very very top of DS, so I've been doing pretty good in that class. Plus because of the handicap they give DS for the overal PAX score, I've been winning that too! To be honest, this is the first time I've won at any type of competitive venue... pretty cool feeling! :up:
            • obrian
              • Sep 2011
              • 232
              #306
              Wow, wow, wow. Thats sick!
              • Massimo
                • Jan 2008
                • 3207
                #307
                one of the local guys here who runs 245/45/16 under those flares, they seem just as wider as yours though.
                • Robotin
                  • Jun 2011
                  • 4471
                  #308
                  duude! u are booking it! good job! want to do an auto-x soon so bad!
                  1989 325i SETA stroker [delphin] R3V'd 8/31/2011
                  1989 325ix [zinnoberrot] $OLD
                  1970 2002 [Nevada]
                  Originally posted by Herr Faust Schinken
                  guy must have slid into something that doesn't look like a car vs car hit
                  Originally posted by ak-
                  Must of slid into Rob
                  • Lof8
                    • Oct 2006
                    • 2827
                    #309
                    That wheel and tire combo looks awesome! Very beastly!
                    S50'd
                    Originally posted by TDE30
                    What is this faggy shit I have happened upon?
                    I can always live in a M3. Can't M3 a house.
                    • silence
                      • Jun 2007
                      • 1824
                      #310
                      Looking good!
                      Those are some tight fitting wheels, the inside clearance might need to be enlarged a bit if you want to avoid rubbing.
                      •• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
                      •• Rear Subframe Bushings • RTABs • Facebook ••
                      • lambo
                        • 10953
                        #311
                        You are a madman.
                        • DEV0 E30
                          • Oct 2004
                          • 8893
                          #312
                          Holy sexual post Eric!
                          Those look uhmazing.
                          • Lof8
                            • Oct 2006
                            • 2827
                            #313
                            What is the width of those lips and final width? It's such a gorgeous track wheel setup!
                            S50'd
                            • Jean
                              • 18228
                              #314
                              Very cool!
                              • Eric
                                • 5142
                                #315
                                17x10.5 up front (7.5" barrel + .5" center + 2.5" lip) et 26 offset. +20mm VAC spacers to clear the willwoods.
                                and 17x11 rears (7.5" barrel + .5" center + 3" lip) et19 offset. +10mm to clear the willwoods & the trailing arms & the backside of the bodywork.
                                Thanks for all the nice comments guys, I hope this next wave up upgrades really brings the car together!
                                This is tempting too...
                                http://www.ebay.co.uk/itm/Bmw-E36-M3...#ht_500wt_1204
