1) is your ICV, the rail next to the fuel rail is an air rail that feeds each of the trumpets on the engine side of the throttles. Allowing the car to idle as mentioned. You could add a port to the plenum to get air or you could even fit its own separate filter. as your running alpha N there is no MAF to get confused.
2) looks like the Vanos Solenoid / acuumulator
3) The lines. The third line will be for emissions. It goes a to a breather setup on the filler neck. There is normally a solenoid to allow the ecu to control when this line breathes back to the tank, alternatively you dump it in the bin and cap the line. I think its normally hooked up the the inlet. Anyway, not overly required.
