TURBO install begins
  • ANDRÜ
    • 1020
    Well, I had enough with the performance (or lack of) of my 325e, something had to be done. Sure N/A is nice, but a full build of the engine wasnt feasable. I dont have the time, money, or expertise to do this. I decided the only way is forced induction. The replacement for displacement.
    The last pic of the stock engine. Very gross.
    Ripped into the front end, and it began. I had to remove the washer fluid tank in order to relocate the coolant take, which would be dangerously close to the downpipe once its installed.
    The stock exhaust manifolds where a bitch to remove, but after torching the nuts, it came out. For some, I had to remove the stud b/c the nuts where horribly stuck, even after the torch.
    The 524td was ported to match my exhasut ports before I got it, so that was a bonus. Mocked up, not tightened.
    And finally, the turbo. Its a smaller turbo, I figured since my engine cant rev past 5500 or so, a small turbo is ideal for fast spool, with little top end, because I have no top end.
    Im planning on removing the AC components, theres alot of crap in the way, especially a thick tube that runs right infront of the turbo.
    Garrett Airesearch
    Tail replica 46mm wastegate
    524td manifold (Thanks chris)
    8:1 Powerdyne FMU
    Bosch BOV
    Stock motronics, stock internals
    Im planning on running no more than 8psi, maybe more with stonger headbolts.
    I have a small side mount intercooler, but hopefully should have a front mount soon.
    Ill be updating as soon as I make more progress.
  • E30 Wagen
    haha, a turbo eta. This should be interesting - and I mean that in a good way actually because I want to see how it fairs.
    • ANDRÜ
      • 1020
      Yea, doing it to a 325i would be better, but w/e. Its been done before to etas, but not nearly as often as "i"s
      • Bimmerboy91
        • Feb 2007
        • 622
        you know thats like the same thing i was saying. the stock power is nice. but it feels like it could do more. and i still dont know about an engine swap:crazy: . but its an almost ez 230 240 horses. how much did this turbo cost you? did it come as a kit?
        • E30 Reaktionär
          Site Manager
          • 14451
          Do keep us updated on the progress.
          1992 BMW 325iC
          1978 Chevrolet Monte Carlo
          • PeaveyBassist
            • Sep 2004
            • 3511
            Easy 240hp on an eta? Thats over 100hp over stock.
            Will
            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
            Welcome e30 (brilliantrot '90 325is) 12/23/06
            DaveCN = Old Man
            My signature picture was taken by ME! Not by anyone else!
            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
            • backtrail69
              • Jul 2005
              • 4471
              Easy isn't the right word...its takes alot of planning and time to setup a reliable and good running turbo setup. AND money...
              :: PNW Crew ::
              '87 325 4dr, '74 2002
              • ANDRÜ
                • 1020
                No, its not a kit. I wont break the pricing down, but Iv spent less than $500 on whats listed above. I still need charge pipes, oil, and vacuum lines.
                • E30Driv3R
                  • May 2004
                  • 1169
                  hey man keep us updated ive wanted to know how much power you could get out of an turboed eta
                  Good luck with the project!
                  Dan Zickel
                  1995 M3, 1991 318iS, 1987 325iS
                  • golfdmb18
                    • Dec 2005
                    • 886
                    lower compression FTW....have fun
                    • ToplessE30
                      • 4791
                      Sounds cool. Does anyone know of a fully detailed turbo installation/writeup? I've looked over on e30tech, but I everyone's got a turbo, so searching yields shit.
                      Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
                      • Bimmerboy91
                        • Feb 2007
                        • 622
                        I ment ez in the way of how much an engine swap engine hp would give you right away. doesnt sound that bad, less than 500. yea im lookin for a turbo thats pretty cheap that would give power when i wanted it and to be a daily driver. do keep us updated and maybe at the end you can give me a place and a total price. best of luck on your project
                        • Bimmernaut
                          • Jan 2007
                          • 82
                          low compression eta...i dig. R3v first?
                          --Jon
                          "Faster, Faster!...until the thrill of speed surpasses the fear of death."--Robert Craig
                          1986 Bronzit 325
                          1988 Zinno 325Ix--parts
                          1990 RX7
                          1980 Honda Cb750, dunstall tank+fairing, Clubman
                          1974 Norton Commando ,cafe Resto.
                          • Digitalwave
                            is a poseur
                            • 6299
                            I can just imagine the powerband of a turbo eta
                            RISING EDGE
                            • euroshark
                              • Apr 2006
                              • 3491
                              Correct me if I'm wrong, but weren't etas 8.8:1 or 9:1 compression? I think it might make 80 - 100hp more than stock with 8psi, and more if he swaps to an I head later.
