E30 Mtech-2 - Alpin-weiss 2 - M50B25 - E30 M3 5LUG
  • roguetoaster
    Biggus Tippus
    • 7830
    #31
    Looks great! Nice work on repainting the pedals too since they always seem to get scuffed above the pads.
    • Mazi!
      • Nov 2009
      • 133
      #32
      The car had small case 4.44 diff so i bought 188mm 3.46 LSD and installed it with fresh Motul oil
      The new vs old small diff
      Now its manual and has LSD diff,, it just needs more powerful engine now!!
      Bought that bracket from Garagistic
      Thats to large
      Found that one at Costco,,, much better!
      Installed
      Modified the exhaust tips just for the look
      Ready for that summer :)
      BMW E30 M3 - S50B32
      www.e30.is
      • Mazi!
        • Nov 2009
        • 133
        #33
        I just bought that M50B25 vanos engine from E34 525IX
        going to refresh it a little before i install it
        BMW E30 M3 - S50B32
        www.e30.is
        • Mazi!
          • Nov 2009
          • 133
          #34
          Bought Recaro keiper seats
          They are great but i hate these gray doorpanels
          So i got black door panels :)
          BMW E30 M3 - S50B32
          www.e30.is
          • Mazi!
            • Nov 2009
            • 133
            #35
            Time for the M50 engine swap!
            I started on the wiring,, e30 C101 plug/pigtail on the engine loom side
            Had to remove loats of wires cause that wiring loom is from an slushmatic e34
            E30 C101 plug ready
            I used a brakebooster from Porsche 944
            944 booster VS orginal e30 booster
            Installed the brakebooster
            Changed the oilpan, pickup etc..
            Bought redlabel DME
            there is some stupid aftermarket chip in it,,, maybe its for higher revs or something.. meh lets give it a try
            That motor is old and driven 270.000km so i bougt alot of new stuff
            Valvecover gasket
            Valvecover nut gaskets
            Oil cap
            Fan belt
            Oilfilters
            Thermostat
            Vaterpump
            Seal for throttlebody
            Intake manifold seals
            Pilot bearing
            Crankshaft seal front
            Crankshaft seal rear
            Exhaust manifold seals
            Spark plugs
            Bosch oxygen sensor
            Fan belt tensioner
            fan belt wheels
            Oilfilter housing gasket
            Water height sensor
            Fan clutch
            Lower radiator hose
            Upper radiator hose
            Clips for fanshroud
            Brown cooling temp sensor
            radioator
            Exhaust manifold studs
            Exhaust manifold nuts
            waterpump pulley
            6pcs new ignition coils
            6pcs ignition coil extensions
            air Inntake hose for e36
            upper hose for idle valve
            lower hose for idle valve
            cap for coolant tank
            dipstick
            dipstick pipe
            Flywheel bolts
            Ireland Engineering poly engine mounts
            Ireland Engineering poly gearbox mounts
            6cyl instrument panel chip
            4pcs plastic covers for engine
            Thermostat housing
            valvecover nuts
            probably forgetting something..
            E34 oil pan install
            The valve cover is horrible so i got it powdercoated
            Valvecover on, new sparkplugs, new ignition coils, thermostat hosuing, waterpump, waterpump pulley etc…
            Disgusting rusted exhaust manifold so i bought equal length stainless headers
            Sandblasted the oil filter housing and added oil temp sensor for e30 m3 cluster
            New belt tensioner and other wheels
            Time to take that shitty M40 out
            I cleaned the engine bay
            M50 ready for install with gearbox
            Custom engine mounts
            Fan shroud
            New dipstick and dipstick pipe
            oil and antifreeze,, bought 20L of oil because im going to flush the engine 2 times.
            Down it goes
            Fanshroud, fanclutch, radiator, hoses ready
            The car runs now, but i need to finish some minor things in the enginebay and make some exhaust
            BMW E30 M3 - S50B32
            www.e30.is
            • Mazi!
              • Nov 2009
              • 133
              #36
              Bought new hoses for valve cover breather
              bought that cover
              Looks better!
              Now everything is almost ready in the enginebay area, i hate that ugly red air filter,, im going to replace it later for another one.
              6cyl chip for the cluster
              6cyl chip installed, Oil temp meter connected and speed signal to DME for vanos
              My Mtech1 steering wheel was looking bad so i took to a guy who fixed it with new leater! :D
              Also leather handbrake
              Then i got that package from Ukraine
              in the package where MHW style taillights
              Cleaned that well before fitting
              Now everything is ready but not the exhaust
              BMW E30 M3 - S50B32
              www.e30.is
              • QuiqueUy
                • Jul 2014
                • 127
                #37
                Your 316i is very much like mine , almost nothing from a 316 is left in there hahaha.
                V nice engine mounts , it seems you got better clearance from the front of the engine to the radiator tbh !
                Car needs to go a bit lower , but i guess streets are very bad haha
                btw , got the same equal length headers on my m52 .. only bad part is clearance with the engine mount for the front downpipe , but nothing that a custom exhaust can't do .
                keep the good updates!
                • 2mAn
                  Señior Mod
                  • 21010
                  #38
                  Quique when will we see a build thread on yours?
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • Mazi!
                    • Nov 2009
                    • 133
                    #39
                    You need to make a thread about your car! :)
                    but yes these custom engine mounts give more clearance between engine and radiator,, thats why i can run fan shroud and orginal fan clutch
                    i'll definitely lower it a bit more when i buy adjustable suspension, but still the roads are not that great here :/
                    BMW E30 M3 - S50B32
                    www.e30.is
                    • Jean
                      • 18228
                      #40
                      very nice build ! love to see more than just flashy wheels and steering wheel in the 'build" .
                      Cheers!
                      • Mazi!
                        • Nov 2009
                        • 133
                        #41
                        Time to make 3" stainless exhaust system!
                        New OEM exhaust hangers
                        New oxygen sensor from Bosch, stainless weld on nut for oxygen sensor, bolts and nuts
                        Stainless "Y" pipe 2x2.25" to single 3"
                        Laser cutted stainless flanges
                        Oxygensensor, stainless 3" V-band clamp and flanges
                        2.25" and 3" pipes from stainless
                        Vibrant 1047 muffler with 3" Inlet and 2x 3.5" outlet stainless
                        Vibrant 1142 stainless resonator 3" inlet and outlet
                        Nice stuff
                        Making that "Y" thing from the headers and down to 3"
                        "Y" pipe almost ready
                        "Y" pipe ready
                        Now its the rest
                        Almost there
                        Bought that airfilter since i hate that red ricer air filter
                        Much better
                        Exhaust finally done!
                        And its bolted in
                        Oxygen sensor
                        Here is a small video of the sound,, will make better video in the summer
                        BMW E30 M3 - S50B32
                        www.e30.is
                        • Northern
                          I like cupcakes & sh!tboxes
                          • 5283
                          #42
                          Same exhaust setup on my M52 car, just with stock OBD2 headers.
                          I found it a little loud for me, but damn it sounds good.
                          Originally posted by priapism
                          Originally posted by shameson
                          • Mazi!
                            • Nov 2009
                            • 133
                            #43
                            Nice
                            do you have a soundclip? :)
                            BMW E30 M3 - S50B32
                            www.e30.is
                            • Northern
                              • 5283
                              #44
                              Originally posted by Mazi!
                              Nice
                              I have two short ones, audio isn't great on either but they get the point across.
                              After turbo with external mic under the hood:
                              ​https://youtu.be/tJzrilZ7d7Q
                              • QuiqueUy
                                • Jul 2014
                                • 127
                                #45
                                I guess i'll have to make a thread of mine , i do have one on the bmwccu forum from uruguay , will have to transfer that to here :P
                                i'll do it more closer to last days of december then ! haha .
                                v nice , big fan of those ! i just run a pusher fan, it works great but i do have a bit of problems with the temp sensor for it haha.
                                yeah same , i wish i could go lower on my car , but it looks decent !
                                btw , v nice exhaust you got there ! keep updates coming !
