E30 Mtech-2 - Alpin-weiss 2 - M50B25 - E30 M3 5LUG
  • Mazi!
    • Nov 2009
    • 133
    #46
    Originally posted by Northern
    I have two short ones, audio isn't great on either but they get the point across.
    After turbo with external mic under the hood:
    https://youtu.be/tJzrilZ7d7Q
    Nice!
    what turbine housing are you running on the S257 SX-E ?
    BMW E30 M3 - S50B32
    www.e30.is
    • Northern
      I like cupcakes & sh!tboxes
      • 5247
      #47
      Originally posted by Mazi!
      Nice!
      I'm using a T3 to 3" Vband 0.82 A/R housing from AGP Turbo. I already had bought the T3 manifold or else I would've used the normal Borg Warner 0.8x AR T4 housing.
      Might consider a smaller A/R if I had a low comp motor.
      Originally posted by priapism
      Originally posted by shameson
      • Mazi!
        • Nov 2009
        • 133
        #48
        I went to a test drive after the M50 swap and the differntial lock slipped in every turn....
        So i bougt a refreshment set from racingdiffs,, ordered the stage 1 kit with 40% lock
        Diff is out!
        Cleaned it
        Everything apart
        This is ready for blasting
        Lock dissasembled
        Here are the old LSD discs,, very worn and bad condition
        New discs
        Lock ready
        Painted the housing
        Stuff from blasting
        2layers of clearcoat
        Now its ready for install
        But im not going to install it now because upcoming is full 5Lug swap and a real 5lug swap! from E30 ///M3 not some e36 shit :D
        BMW E30 M3 - S50B32
        www.e30.is
        • Mazi!
          • Nov 2009
          • 133
          #49
          I just sold the borbet a wheels because im going to do a E30 M3 5lug swap $$$$$$$$$$$$$$$$$$$$$$$$$$$$ :bawl:
          it is currently sitting on some trash wheels
          Bought E30 M3 version of KW Variant 1
          Also
          E30 M3 rear hubs
          E30 M3 rear brake dust covers
          E30 M3 rear brake caliper brackets
          E30 M3 rear brake pads and sensor
          and some stuff for the handbrake
          95a poly bushing kit from Garagistic
          installed the diff bushing
          As can be seen i got loats of the parts that i need already but im still buying and searching for many other parts before i can finish that 5 lug swap.
          BMW E30 M3 - S50B32
          www.e30.is
          • moatilliatta
            • 6151
            #50
            Nice! minus the garagistic bushings.
            Make sure to put 12.9 hardware in those uprights.
            @Zakspeed_US
            • ZEKTI
              • May 2016
              • 218
              #51
              Fantastic thread! So cool that you're also building this in Iceland. Those KWs are amazing.
              OBD1 S52 E36 Compact
              84 318i M10 Zender
              • Mkcustoms88
                • Mar 2015
                • 56
                #52
                Beautiful build so far, looks like you have access to a garage when you need it makes things easier, keep up the great work
                • Mkcustoms88
                  • Mar 2015
                  • 56
                  #53
                  What’s the deal with the garagistic bushings if I may ask?
                  • Glaede
                    • Oct 2007
                    • 138
                    #54
                    That's an awesome upgrade! The proper way to do 5-lug! :-)
                    • Mazi!
                      • Nov 2009
                      • 133
                      #55
                      Got a little package from USA today
                      Used E30 M3 brakecalipers and brackets both sides at front.. had to buy them used because they are discontinued from BMW
                      they were very expensive and hard to find and definitely need a full rebuild and sandblasting
                      Still waiting for more parts :)
                      BMW E30 M3 - S50B32
                      www.e30.is
                      • Mazi!
                        • Nov 2009
                        • 133
                        #56
                        Package day today!!
                        E30 M3 ATE brake calipers both sides rear
                        E30 M3 Zimmermann rear brake discs
                        Brakepad wear sensor front
                        Hjólalegur b/m að aft. orginal
                        Handbrake shoes
                        Handbrake spring set
                        Handbrake tensioners
                        both handbrake cables
                        both rear swaybar end links
                        all rear axle boots
                        Brakepipe set
                        Blower motor
                        and this heavy package from USA with both rear control arms and axle shafts
                        Ireland Engineering brake hoses
                        now i got almost everything that i need for that 5lug swap
                        still need to buy
                        Brakepads front
                        brakediscs front
                        front wheelbearing
                        Dust shields at front.
                        BMW E30 M3 - S50B32
                        www.e30.is
                        • AWDBOB
                          hooptie connoisseur
                          • Aug 2013
                          • 4487
                          #57
                          Nice- that's a dreamboat setup. I had a setup almost completed but never followed through with installing it. With the E30M3 KW Coilovers available with ackerman arms, it makes the conversion quite tempting. The main obstacle are brakes and dust shields. Rear hubs are quite pricey, too, but are at least still available. I remember just a few years ago one could buy rebuilt M3 calipers on Rockauto for $40-50 a pop. Oh, how times have changed.
                          • Mazi!
                            • Nov 2009
                            • 133
                            #58
                            Just got some more stuff
                            e30 m3 front dust covers
                            e30 m3 front swaybar ends
                            e30 m3 front brake clips
                            e30 control arm brackets
                            and some bolts and stuff..
                            New pistons and rubbers for e30 m3 front calipers
                            Im going to sandblast the front brake calipers and paint them with that set,,, i got the idea from Sreten at m539 restorations on youtube
                            (silvergrey color)
                            Some more new stuff....
                            new speedsensor, speedsensor plug housing, swaybar stuff.
                            Bought the rear swaybar used (er smá ryðguð,, (its a little rusty im going to paint it) and e32 750 mastercylender
                            Front control arm bushings installed in brackets
                            new speedsensor installed
                            bought the speedsensor plug housing new because its cracked and old..
                            Cleaned the rear control arms before disassemble
                            Rear control arms disassembled
                            Dropped the subframe out,,, im not going to use anything on that picture (only the subframe itself)
                            Took the axle driveshafts apart, painted them and changed the grease and rubber boots
                            One side ready
                            BMW E30 M3 - S50B32
                            www.e30.is
                            • Mazi!
                              • Nov 2009
                              • 133
                              #59
                              Both axle driveshafts ready
                              Burning out the old subframe bushings
                              Ready for sandblasting
                              blasted
                              Garagistic reinforcement set
                              Subframe painted and ready
                              Ready for install
                              almost done at rear,,, KW Variant 1 and everything new!!
                              Front hubs and brake parts
                              E30 M3 front calipers blasted
                              Painted
                              and ready with new pistons, rubbers...
                              Ready at front
                              Installing e32 750 master cylender
                              e32 750 mastercylender installed
                              now its almost finished,, still have to bleed the brakes, and do some more small things,, AND find some 5x120 wheels...
                              BMW E30 M3 - S50B32
                              www.e30.is
                              • moatilliatta
                                • 6151
                                #60
                                Looking good! I came across these 5x120 wheels today :p
                                @Zakspeed_US
