Project Unicorn - The Touring
  • twright
    • 707
    #31
    Originally posted by DEV0 E30
    It is pretty full. I had forgotten about the pump o-ring. I think tourings still have the access panel like most, but I've not checked since owning this. Another area to check and probably just replace to for sure. Thank you.
    I'm sure there is an access panel. I just don't know how to pull up the carpet to get to it.
    • Panici
      • Dec 2009
      • 2575
      #32
      Beautiful touring, the colour really makes it! Following for updates.
      How is the rust situation under the car? Reason I ask is that my EVAP line to the charcoal canister was rusted through. This was my main source of fuel smell when parked inside. It was still available new and pre-bent from BMW in 2018.
      FWIW I changed all the hardlines and soft lines, and haven't smelt fuel since. Still using the original EVAP canister and purge valve with my M52 swap and standalone ECU.
      • DEV0 E30
        • Oct 2004
        • 8904
        #33
        Thanks for the idea Panici, the car is rust free and very clean underneath.
        I've searched high and low but still haven't found the source - going to hopefully get the carpet up and check the top of the fuel tank this weekend.
        Maintenance parts have been slowly arriving for fuel lines, fuel filter, etc.
        I don't want to put to much money towards the M40b18 since I'd love it gone sooner rather than later...
        ... but figured I should erase the possibility that any of the rubber fuel injector o-rings or lines are the cause in the engine bay or elsewhere.
        I should be receiving more replacement parts by Friday, so I'm hoping I can find some time this weekend to search more for the leak and replace anything it could be.
        But what's this? Extra struts?
        And other stuff has arrived. Full Airlift 3P setup for E30s. Spare struts above are already being cut and airlift struts welded on.
        Tank and compressors arrive tomorrow. Hoping to fit it all in the spare tire well to not lose the practicality of this being a touring and all.
        Would love to get all of the suspension parts powder-coated and freshened up before they go on the car.
        Still need to get new hubs/bearings and trying to decide what else will happen at the same time... buggbrakes? no buggbrakes?
        • Panici
          • Dec 2009
          • 2575
          #34
          Ooo excited to see the airlift stuff go on!
          Always thought air suspension would be a good match to a touring.
          • Sledgehammer_01
            • Aug 2022
            • 67
            #35
            Sub'd love the Touring!
            Current Builds
            1989 S52 E30 Touring | The Grey Athletic Shoe
            1993 Toyota Landcruiser | The Trail Snail
            • DEV0 E30
              • Oct 2004
              • 8904
              #36
              Figured I'd post a few in this thread.
              I didn't update this main thread, but I did add a link in the first post:
              The car is receiving an N52 and 6 speed manual, along with a ton of random updates along the way, and after it's running right.
              I wouldn't be doing this swap if I didn't have help from some people making this possible, but I'm very excited to get it running.
              Air ride setup has taken a back seat until the car moves under it's own power. Front struts are welded and done.
              I've bought and sold some items to offset swap costs.
              Also decided to let go of my gorgeous BBS RS's from Paul at EWW to offset swap costs a little bit more.
              Still have the euroweaves that are on it and a spicy set of JDM wheels for this thing I'll rotate. Trying to not slip into wheel whoring tendencies.
              N52 Engine Swap Thread:
              https://www.r3vlimited.com/board/for...at-have-i-done​
              Headers are done, and at ceramic coating.
              Oil pan is nearly done from fabrication.
              Still constantly ordering parts.
              Progress has been happening, not as quickly as I was hoping, but life happens. Lots of other things made E30 lower priority from time to time.
              Since summer is here, I've moved things around to get the E30 in the garage, and made everything fit so a temporary workspace can happen as necessary.
              We almost bought a house with a 3 car garage with 10 foot ceilings... but the market here is nuts along with rates. Cheaper bills are a good thing for the next few years. Making do.
              I'm really trying to document the swap and make it easy for myself when I forget what goes where down the line, so I got these labels off of amazon, a white pack, and a multi-color pack, they say they are automotive grade, we shall see.
              I'm actually starting to understand the many different harnesses and modules which is neat.
              Helper, helping. She gets bored pretty quickly when she realizes the car isn't taking her somewhere, but that's ok.
              More N52 focused updates will happen in that thread:
              • 2mAn
                Señior Mod
                • 21061
                #37
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • DEV0 E30
                  • Oct 2004
                  • 8904
                  #38
                  Damn you. *Looks at signature links...*
                  Here ya go:
                  Progress? No, but by end of year I'll turn a wrench on it, that's what I'll promise. lol
                  • DEV0 E30
                    • Oct 2004
                    • 8904
                    #39
                    Not even bump worthy but I took out the engine, to actually start getting things moving forward. The car has been in a state of purgatory since moving and focusing on new house stuffs.
                    Unfortunately I ripped the rubber firewall material like a noob (I used to be able to pull engines like a pro, wtf happened?)
                    It wasn't perfect but now I may need to tear off the rest and replace it with something not OEM... because $500+ for a new one seems like a waste.
                    So now to attach flywheel, clutch, seals and stuffs in a bin, and buy lots of things I should have bought years ago.
                    Hoping to run by 2027 but actually have progress on a more consistent schedule starting in a month or so?
                    • JasonWilson48
                      Not my real name
                      • Jan 2025
                      • 257
                      #40
                      I'll do 2mAn 's job and start bumping project threads that I want to see updated. :)
                      89' Build
                      2009 Honda Element (Daily/Beater)
                      • 2mAn
                        Señior Mod
                        • 21061
                        #41
                        Thats right, R3V is a safe space to bully and harass people into working on their cars... or at least showing pics of their current state
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • MrBurgundy
                          R3V Degenerate
                          • Mar 2012
                          • 5609
                          #42
                          Originally posted by 2mAn
                          Thats right, R3V is a safe space to bully and harass people into working on their cars... or at least showing pics of their current GF
                          fixed
                          • 2mAn
                            Señior Mod
                            • 21061
                            #43
                            fixed
                            Lets be honest... we are either married with kids now, or havent had a girlfriend since high school (almost 20 years now)
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • MrBurgundy
                              R3V Degenerate
                              • Mar 2012
                              • 5609
                              #44
                              • DEV0 E30
                                • Oct 2004
                                • 8904
                                #45
                                Big moves...
                                I wiped some dust off it the other day.
                                Once my nights aren't dealing with a thing, things may move a bit more forward again.
