Another Not-an-E30 thread... The Worst Spec w201 16v, but I still have to save it
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5604
    #31
    Craftsthem
    • 2mAn
      Señior Mod
      • 21024
      #32
      Those fuel fittings always need crazy torque to seat the washers.
      Maybe I should grab the CraftsThem and drag it back out and hammer that sucker on, just like it was before ... lol
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5604
        #33
        I do those by hand. You can feel the washer collapse.
        Hang the pump in the hanger and then use 2 17mm wrenches to get that banjo tight
        • 2mAn
          Señior Mod
          • 21024
          #34
          I hate those copper washers, annoyingly the new pump had new washers, but they werent the right size, so my only option was to reuse and Im sure thats a big no-no...
          I will keep the car up on stands today while I tighten and see how many times I have to re-tighten them, but yea I might need new washers
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • roguetoaster
            Biggus Tippus
            • 7830
            #35
            IMO, reusing crush washers is fine, if you sand them flat.
            I really would encourage you to get some cheap hook/loop no hole sanding discs and keep them around for stuff like this. They also work really well for sanding stuff that's semi fixed, like battery cables.
            • varg
              Florida Turbo Man
              • May 2014
              • 3429
              #36
              Copper work hardens. When they've been crushed once they will be harder to "re-crush" and may not seal well. You can heat them with a torch to anneal them, copper is just easy that way. It's handy to have an assortment of copper and aluminum crush washers on hand when you own old cars...
              IG @turbovarg
              '91 318is, M20 turbo
              • 2mAn
                Señior Mod
                • 21024
                #37
                Had a small window to get under the car and cranked down on everything. Initial turn of the key didnt have fuel pissing. I got some fresh Chevron 91 octane & their Fuel Treatment. Will dump that in and see what happens when I turn the key.
                Guesses? More fuel pissing or fire it up MB reliability?
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • MrBurgundy
                  R3V Degenerate
                  • Mar 2012
                  • 5604
                  #38
                  Be ready to take the fuel dist off. When they sit to long, the plunger will stick and dump gas like crazy.
                  When you crank the car, take a 12mm wrench to the fuel line that goes to the distributor and crack it open. It should just weep out and not spray out. If nothing comes out, tap the line with the wrench because the flare might be seated still.
                  If you you're getting the fountain of fuel, you're gonna have to take the dist off and try to free up the plunger or worse, split the dist and reseal it.
                  • MrBurgundy
                    R3V Degenerate
                    • Mar 2012
                    • 5604
                    #39
                    Bro can you start this thing up already?
                    I need some excitement in my life
                    • 2mAn
                      Señior Mod
                      • 21024
                      #40
                      Thanks for the bump... heres where we're at: Fuel pump & fuel filter are installed (with no leaks) and working but still no start. I guess it’s time to move out from under the car and move under the hood. I’ve heard that I should check at the fuel injectors, but also heard I should check at the fuel distributor.
                      Open to suggestions on what y’all suggest​.
                      I should have finally the 16v motor ready to be shipped out this weekend and then the Benz is the only distraction besides the money thats burning a whole in my pocket.
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • MrBurgundy
                        R3V Degenerate
                        • Mar 2012
                        • 5604
                        #41
                        crank the car with one of the lines cracked on the distributor
                        lmk what it does
                        • 2mAn
                          Señior Mod
                          • 21024
                          #42
                          lmk what it does
                          Might have to get the 4year old involved. She should be able to turn a key LMAO
                          Stay tuned
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          • MrBurgundy
                            R3V Degenerate
                            • Mar 2012
                            • 5604
                            #43
                            That's what they're for
                            • roguetoaster
                              Biggus Tippus
                              • 7830
                              #44
                              Stay tuned
                              Okay Tony Angelo.
                              • DEV0 E30
                                • Oct 2004
                                • 8904
                                #45
                                Does it look like a need for speed car yet?
                                If not, why?
                                I need to live vicariously through your project cars because my progress is like going backwards now.
