Strict budget, slow restoration. *Now with moar budget*
  • ck_taft325is
    • Sep 2007
    • 6880
    #286
    Originally posted by MR 325
    Love the wheels man, makes the car look totally different!
    Those tires will wear out quick though. :(
    Sadly, yes.
    Still none the less: AWESOME.
    Need a part? PM me.
    • turbospeeder
      • 48
      #287
      tons of pictures. thanks dude!!!!
      • Spiff325iS
        • Jun 2004
        • 1263
        #288
        This picture is awesome. Wheels are so shiny.
        The Red Dragon V.5 1991 318iS / 2013 F800GT
        "You gotta fix the nut behind the wheel before you fix the bolts on the car"
        • KennyT
          • 542
          #289
          Originally posted by Wh33lhop
          I hate going to alignment shops. When you turn every wrench on your car yourself the last thing you want to do is turn it over to some monkey and pay them a $69.99 flat rate just because you don't have a DSP600 at home.
          I ask the guy what he set the toe to and he tells me thirty. I ask him if he means thirty minutes? He looks at me funny and says "no, degrees." Really? You set my toe to THIRTY DEGREES? REALLY now. I know what he meant but I sort of have a disposition to hate these guys since I'm paying them $70 to do 20 minutes of work I could easily do myself.
          You got hosed $70 for an alignment!? My family's shop will align to your specs as long as you can explain why you want them so. All for a pair of $20s
          • ck_taft325is
            • Sep 2007
            • 6880
            #290
            If you where in the great Puget Sound region, Vic's will align your car in under 20 minutes for $22 bucks.
            Need a part? PM me.
            • bmwstephen
              • 2463
              #291
              i thought the rear wheels on our car are stationary and cannot be aligned
              • Cabriolet
                • 9620
                #292
                unless you buy the rear camber kit... if you do only get teh weld in type.
                Much wow
                I hate 4 doors
                • Wh33lhop
                  • 11705
                  #293
                  Please--don't remind me. I live in a small college town and don't really have a lot of options.
                  The alignment targets on the rear wheels are there to measure thrust angle, not because they were charging me to set the rear alignment too (although they did try and tell me that they should set the rear toe).
                  paint sucks
                  • kronus
                    • Apr 2008
                    • 13032
                    #294
                    You should have told them to go ahead and try :p
                    I look forward to getting an alignment, them claiming that they will align the rear, then them saying that it's nonadjustable when I ask about it, then explaining to them that it IS in fact adjustable now.
                    cars beep boop
                    • N2MYE30
                      • Oct 2007
                      • 5536
                      #295
                      Looking good. I might have missed it but are those 15x8s rapped around 225-50s?
                      COTM
                      • nouseforaname
                        • Jul 2009
                        • 322
                        #296
                        I like the stance.nice job.
                        • KennyT
                          • 542
                          #297
                          I've actually been there vacationing.
                          In order to actually measure anything other than front camber you need to have all four wheels. Toe is based off of the opposite front and respective rear in order to figure out vehicle square via laser/string. Rear camber is based off of the readings of the other 3 sensors as almost every alignment lift is not in plane with true level.
                          I've had to explain this several times to customers thinking they are being charged for a 'four wheel alignment' when we are only fixing toe.
                          Worst thing as a mechanic is telling someone the car they just bought was in an accident, and so far out of square it is dangerous. That has only happened twice.
                          • poopin04
                            • Jul 2010
                            • 1396
                            #298
                            WoW! I just spent my morning reading your build. Great stuff man, once again I can't wait for warmer weather. I have so much crap piled in my room to install.
                            Click here to leave me feedback on our transactions. :p
                            • chadthestampede
                              • Jul 2008
                              • 3601
                              #299
                              looks like 225-45 from the tire picture.
                              Originally posted by LJ851
                              Feedback
                              • Wh33lhop
                                • 11705
                                #300
                                15x8 +20, 225/45R15 Hankook RS3s. Awesome grip. Even with 3 1/2 people in the car (one 270lb guy) there is serious grip.
                                paint sucks
