Stroker build.
  • z31maniac
    • 17566
    #46
    Get a better camera you whore.
    And get to work, I'm anxious to see this bitch built!
    www.gutenparts.com
    • Miasma
      • Apr 2007
      • 2009
      #47
      Picking up a M52 2.8l crank this weekend... Waiting on MJG to get more crank spacers together.
      I IZ COPY U DANNY
      • 416stroker
        • May 2008
        • 2448
        #48
        Let me know when you need prices on all your machine work.
        84 318I Delphin RIP
        87 325IS delphin 24v Sold
        89 325 Alpineweiss
        • Danny
          • 14216
          #49
          Fuck you. BB Storm ftw.
          Also updates are slow because I am poor.
          I IZ COPY U DANNY
          Kewl.
          Now.
          • z31maniac
            • 17566
            #50
            I know what you mean goodly sir.
            www.gutenparts.com
            • SpecM
              • Oct 2005
              • 4531
              #51
              Danny, elaborate on the notching of the block, piston skirts, and intermediate shaft to fit the crank...
              ...please?
              1989 cirrisblau-metallic 325i
              • Danny
                • 14216
                #52
                Well there is no notching of the block. Only shaving the counterweights of the crankshaft. And if I can't shve enough material safely, I'll have to notch the piston skirts. Excuse the spelling, this is from my phone.
                • 416stroker
                  • May 2008
                  • 2448
                  #53
                  Will do
                  84 318I Delphin RIP
                  89 325 Alpineweiss
                  • Danny
                    • 14216
                    #54
                    Thanks buddy.
                    Still would like to know if anyone has experience with VAC valve springs.
                    • digger
                      • Nov 2005
                      • 6116
                      #55
                      Thanks buddy.
                      I have been using them for 1.5 years.......quite a bit stiffer than stock/schrick or MM so only use them if you need them.
                      • Danny
                        • 14216
                        #56
                        Would they be okay with a 288 and HD rockers?
                          • 34839
                          #57
                          what's the PN? did ixer have those posted in his thread about valve springs? if they are similar to the ones he reccomended, use them. I don't know about too stiff being a problem (could be if your rockers are junk) but too soft definitely can be.
                          • Danny
                            • 14216
                            #58
                            I bought brakes.
                            • Danny
                              • 14216
                              #59
                              So I've been chatting with a few people about this and they said I can only do 7k rpm on stock rods? Opinions?
                                • 34839
                                #60
                                which ones? 135mm, 130mm, M52? in any case - yes, you can do that just fine. The only thing is your RR with 130mm rods will be quite low, the motor will make most of it's torque down low and fall off a bit up top. it might not be beneficial to rev that high.
