My E30M3 S14B23 -> S50B32 -> RB26DETT. We are alive!! p.28
  • litu
    • 849
    #286
    Originally posted by Mr. Horsepower
    Thanks! Great to have support from some people, since there is many haters on it already. But if you got haters you are doing something right they say.
    Yes, there is lots of cool Bmw to use whit turbo....But now days, i like these wiked project. Way different engines setup etc...
    This is yours project, f*** those who haters, these project is for you, not for other
    https://www.facebook.com/Cry_77_IX-110483784967661
    https://www.instagram.com/cry_77_ix/
    • Loupoz
      • Feb 2012
      • 166
      #287
      How much does the RB weigh? Same wait as on S50, more/less?
      My 325I Mtech1 S54 Build
      • Mr. Horsepower
        • 386
        #288
        Having had both engines on my engine stand, I think the RB is a bit heavier. The overall engine is bigger and have two snails, so it would make sense. However the gearbox have one less gear and sits very far back in the car.
        I will know this for sure when I put the car on the scale, since I have the prevous numbers. When I approved the car with S50 I had full interior, but now I have only the Pole Positions. I lost 60kg from the total weight when I did that interior thing. So I hope she will be light enough on the front axle to get it approved and road legal.
        1987 BMW E30 M3 RB26
        2016 VW Polo 1.2 TSI R-Line
        Originally posted by 5spoke
        Fucking norway and your sick clean ass e30's! Yes i am yelling!
        • The Dark Side of Will
          • Jun 2010
          • 2796
          #289
          Supplier didn't get you a RWD pan with your RWD gearbox? Ooops.
          • Mr. Horsepower
            • 386
            #290
            Don't want it, since the 26 oil pan is better. So I take the time to modify it.
            • 3vilE30
              • Jan 2013
              • 344
              #291
              RB26DETT with all accessories + fluids
              with trans is about ~ 320+kg
              You should weigh it for future reference :)
              • Mr. Horsepower
                • 386
                #292
                Got some stuff done today. Did cut of the diff housing and the driveshaft flange with a grinder, so it is ready to go to the machine shop to get it flatened out.
                Spare parts
                So afeter that was done, I continued to get things tidy. Took all the tools down from the board and cleaned them. Also gave the board a wipe or five. I know it is not the most fancy garage, but I get shit done here and have the space I need.
                Bolts and nuts that I remove frome the engine is sorted here, in marked bags.
                Random E30M3 parts in this shelf
                Random engine and engine bay parts
                My two exhaust systems is placed under the car for now, probably going to use the 3" version on this build. Just need to do some testing on different setups I guess.
                My BBS RC090 (Style5's) that is up for sale
                Random rear coilover shot
                Cheers
                • DER E30
                  • Sep 2013
                  • 2349
                  #293
                  Cool!!! SUbb'd!
                  -Christian
                  • E30_Pare
                    • 7801
                    #294
                    y not 4wd rb26 e30 m3? Can only imagine that epicness.
                    DREWLIENTE
                    1$ PShops PM me
                    • Mr. Horsepower
                      • 386
                      #295
                      Alrigt, the motor is now in posistion and is resting on some stands.
                      I want this engine to sit as far back as possible, so that left me no other option than to cut some out of the stock oilpan. This gave me about 5cm. So now I think I can fit a Skyline radiator where the radiator is supposed to be, and not on front of the front secton.
                      The steering colomn does hit something here. I had to remove the rear turbo elbow and one water pipe.
                      Here you can see that the oilpan is pretty much paralell with the crossmember, and does not sit any low eather. Very good.
                      Another great thing I noticed here is that this engine is much lower than the S50. You can't even see it when you are aiming across the engine bay, which equals lower centre of gravity.
                      When I placed the eninge so far back, the shifter does not hit the hole in the coupe. This is not a big problem, and the solution is already done in my head. It involves a small bit of cutting.
                      Coolant pipes need a bit of work. Also hope I can cut and weld a small pocket in the rocker cover to get a better fit.
                      And here is the overview. Because of the clearance under the turbos and exhaust I have decided to go for top mounted twins, and see of that will give me a better solution. It is possible to use low mount, but then I will need to use a pedalbox and I want to avoid that. Top mounted turbos looks pretty good as well.
                      • 3vilE30
                        • Jan 2013
                        • 344
                        #296
                        Any updates?
                        • kristov
                          • 222
                          #297
                          Originally posted by 3vilE30
                          Any updates?
                          Looking forward to the final result!
                          • Mr. Horsepower
                            • 386
                            #298
                            Received some parts, have not done anything i the garage though. The Norwegian DMV was ans inspected the car last week, and they was happy with how I wanted to do the different things.
                            At this point I'm still making plans, budget and buying parts that is needed.
                            What I have bought now is JUN oilpump, JUN baffle kit and Nissan N1 waterpump. I have also ordered the pedal box bracket from Garagistic.
                            • kristov
                              • 222
                              #299
                              Do they accept pedalbox?
                              • Mr. Horsepower
                                • 386
                                #300
                                Yes, hanging Wilwood or Tilton. Fluids need to be in the engine bay.
