A look at things to come
It is the best solution, I just had access to a welder and got it done. I was too impatient. haha. And I love your attention to detail. It all looks really good. I wish I hadn't been so impatient. lolzComment
my master all painted and done...
Fly just chilling ( rust is gone)
Clutch n' shit chilling
lots of work to be done tomorrow :)Comment
intake boot valve, fly bolts, fly spacer, oil pan plug
cut all brackets off in engine bay, will probably remove ABS, more insulation tomorrow
I stripped 1 brake line, so Im going to get brake line tools as wellComment
bondo on most seemd
got primer and ordered the paint for engine bay, its white but not glossyComment
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Its not like a flat or gloss paint, its a rough paint...I could not seem to decide on a spary paint so i got this
Im promise Im not posting to post, added loop connectors and wired alternator
added the safety valve for coolant, which Janderson will be doing, As I instructed him...
took e34 wire holder off, and wrapped the harness with tape, will use cloth tape on it tomorrow.
Bondo on, sanding tomorrow, primer tomorrow. Pleased its been 60 degrees outsideLast edited by Matt-B; 03-06-2011, 09:01 PM.Comment
Matt why did you paint the master cyl? If you get so much as one drop of brake fluid on it that stuff will just melt off
It would probably look just as nice if you cleaned it up a bit.Last edited by Wishno87; 03-06-2011, 08:59 PM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
