A look at things to come
  • accident
    • 7303
    #406
    no.
    Moral of this story?
    • Jand3rson
      • 37587
      #407
      Originally posted by LJ851
      Can this go back to a build thread about Matts car?
      You shut your whore mouth.
      • ahriley91
        • Jan 2010
        • 451
        #408
        I love r3v.
        http://www.r3vlimited.com/board/showthread.php?t=162444
        • Matt-B
          The Waffler
          • 3856
          #409
          booster
          coolant safety valve
          passenger side
          driver side
          • White325is
            • Oct 2006
            • 5947
            #410
            That bondos going to crack. You should of used some kitty hair first. Then used a filler that flexes.
            I give it a month max.
            • DTM190
              • Nov 2008
              • 1107
              #411
              I have noticed in numerous threads people post pics of bondo over paint. Is it not common place for you US based guys to strip the area being filled back to bare metal?
              Originally posted by der affe
              first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
              if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
              • mikeedler
                • 6707
                #412
                ^ no, no need to. why do you think that bondo is going to crack so fast.
                just read your complete thread from beg. to end. seems like it is going to be like a nice car when done.
                oh, BTW, not a single euro car ever received that coolant valve, not a bad idea but I really think there is zero risk of your heater core blowing up. I am sure it was just a scare in the 90s of BMW getting sued by someone in the U.S. if it would happen.
                • funcrew
                  • Jun 2007
                  • 1223
                  #413
                  Modern, flexible body fillers do not require bare metal - they are designed to adhere to existing paint, and are typically used that way. BTW "Bondo" brand does not qualify as modern or even OK.
                  "If the sky were to fall tomorrow, the tall would die first."
                  -Dr. Paul Forrester
                  Do I LOOK like I need a psychological evaluation???
                  • george graves
                    • 20003
                    #414
                    Is this build thread going all pear shaped?
                    Originally posted by Matt-B
                    • dirtysix
                      • 806
                      #415
                      Meh. I've no problem with bog over prepped paint, so long as the paint's sound.
                      It'll crack unless those body panels are fully welded though (my guess is they're not) especially on a flexie old e30.
                      • Matt-B
                        The Waffler
                        • 3856
                        #416
                        I dont know what kitty hair is, and where to get flex filler, Im not to worried, kinda winging it here.
                        • ck_taft325is
                          • Sep 2007
                          • 6880
                          #417
                          At least take the bondo'd areas down to straight metal. No paint 3" in either direction, bondo, Evercoat, done.
                          Need a part? PM me.
                          • Matt-B
                            The Waffler
                            • 3856
                            #418
                            yea i did, those pics are before more sanding , i was only trying to fill tiny holes and dimples from cutting off brackets
                            • ck_taft325is
                              • Sep 2007
                              • 6880
                              #419
                              Kitty hair is a fiberglass product, by the way. Flex agent is usually sold at most body stores if you have any close. It's worth it in the long run BUT, if you don't mind doing it all again, get some work done and get that bitch on the road, man ;)
                              Need a part? PM me.
                              • Matt-B
                                The Waffler
                                • 3856
                                #420
                                yea, should be mating trans to motor this evening, just changed my trans input shaft seal, need to see if my starter clears
