A look at things to come
passenger side is shaved and awaiting primer, bondo worked fine.
finishing drivers side tomorrowComment
Its not like a flat or gloss paint, its a rough paint...I could not seem to decide on a spary paint so i got this
Im promise Im not posting to post, added loop connectors and wired alternator
added the safety valve for coolant, which Janderson will be doing, As I instructed him...
took e34 wire holder off, and wrapped the harness with tape, will use cloth tape on it tomorrow.
Bondo on, sanding tomorrow, primer tomorrow. Pleased its been 60 degrees outside
And yes, you do post just to post. You have 3,800 posts since June 09. AND I already deleted 3 thousand posts about a year ago.Comment
it's just a check valve, installed as part of a recall, that keeps hot coolant from spraying on your legs if the heater core bursts.Comment
Curt cam over when wishno was doing his swap, and he was like "your going to use the safety coolant valve right?"Comment
but, I digress...Comment
that's basically it. you might not like matt but making fun of him for reccomending the check valve makes you sound like an ass.Comment
