Eta-to-M50: Build thread
    • 37829
    #226
    My water pump looks/feels to be in perfect condition with no shaft play or noise, and looks fairly new, so I can probably just put it right back in.
    As long as it's not a plastic impeller pump!
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • imsotyerred
      • Oct 2005
      • 2529
      #227
      Got the block painted tonight, went with DupliColor cast iron, it's a dark silver, almost nogaro, and a little bit metallic. It looks really good, just kinda looks dirty in the pics. But it looks amazing in person.
      same color I painted my Strut bar and Valve cover (M20)
      I'm even thinking of hitting my wheels with it...the grey I have now is too dark
      Project is looking great, Josh! can'[t wait to see more
      BRUTE
      • Jand3rson
        • 37587
        #228
        I'll get pics when it's finished sanding and ready to be painted.
        I hate bodywork, I swear I'm never doing my own again. I can do it just fine, I just hate it.
        • Jalves619
          • 596
          #229
          Are you still planning on slotting the firewall and using the stock booster? I was looking at my pedals yesterday and realized that the actual pedal pads are offset to the left of the arm slightly. I'm wondering if the RHD pedals are offset the other way and could be used to make up the difference in spacing.
          Since mine are plastic (1990 airbag equipped) I might just trim the original pedals and install some of those fancy quickshifting Fuh Raze pedal pads centered on the arm or even slightly offset to the right to make up for shifting the pedals over.
          It just seems like 3/4" would put my clutch pedal on top of my dead pedal.
            • 34839
            #230
            those plastic pedals scare me.
            not all airbag cars have plastic pedals FYI. my '91 doesn't and neither did the 318is parts car I got my clutch pedal from.
            • Jand3rson
              • 37587
              #231
              Nope, it's a metal one. That was one thing I was really hoping for when I pulled it!
              • shiboujin
                • Feb 2006
                • 2791
                #232
                thats what she said
                • Jand3rson
                  • 37587
                  #233
                  Pics of the shave progress. Almost done with it, primer is drying and then I'll go over the last of the low spots with another skim of glaze/spot filler, and then hit it with black filler primer before painting.
                  Driver side:
                  Passenger side:
                  I do love the primer stage, it makes it look so close to being done...
                  • ShowStopper
                    • Jan 2008
                    • 1845
                    #234
                    is that glazing putty??:crazy:
                    • Jand3rson
                      • 37587
                      #235
                      Yes. Did you seriously not see where I've said like 2-3 times prior that I'm using glaze/spot filler putty to fill the low spots?
                      • ShowStopper
                        • Jan 2008
                        • 1845
                        #236
                        i read but ur crazy for using it.
                        • Jand3rson
                          • 37587
                          #237
                          Why? This application is exactly what it's for. I used JB weld to seal the welds and all of the little pinholes, then sanded the surface. I'm using the glazing putty to fill and level the low spots, and then it will be primered and painted.
                          • ShowStopper
                            • Jan 2008
                            • 1845
                            #238
                            it will shrink and crack after awhile
                            • Jand3rson
                              • 37587
                              #239
                              I don't know what it did for you in the past, but I've used it before with nothing but good results. Thanks, tho.
                              • Greekstyles
                                • 215
                                #240
                                LOOKING SICK MAN!...
                                I didnt use one bit of body filler/jb weld/putty, all metal and just sanded and dollied out the crazy bumps. i even single staged the paint right out of a can. looks sick though!!
                                my wire tuck its kind of a stage one i would call it. i offer different stages to my customers (i have a shop in Bayshore Longisland NY) but im eventually going to redo the harness and motor with some frankenstein'edge..i kinda known for franken swaps haha. keep up the good work!
