Andrew's 1989 325i Project
  • jaywood
    • Jul 2010
    • 4528
    #256
    As long as it's not sticking out (protruding) then I'd say you are fine to run it.
    • 5Toes
      • 9836
      #257
      Ill double check, I didnt want to pull it oput of the box because my hands are so oily.
      • Holland
        • Nov 2008
        • 7212
        #258
        You have to spray them with brake clean to get the chemical coating off of them anyway before running them, so it's fine if you touch them.
        Originally posted by DEV0 E30
        • 5Toes
          • 9836
          #259
          True..
          • KenC
            King of Kegstands
            • 14396
            #260
            All of that will come off with a good high speed stomp.
            Talk to John or James about bedding the new pads properly too.
            Originally posted by Gruelius
            • 5Toes
              • 9836
              #261
              I have read up lots on bedding pads. I have heard that bedding in OEM pads is not such a good idea.
              Akebonos is mixed opinions on bedding
              • AbsorbantNut
                Non faccio funzionare questa merda
                • Jun 2010
                • 2491
                #262
                You should have gotten some caliper rebuild kits too while your doing the brakes. They arent much $$ and are easy to do. Just fyi
                '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                • 5Toes
                  • 9836
                  #263
                  Well I looked into them, and it looked like they would be $80 for all 4, I cant afford that
                  • KenC
                    King of Kegstands
                    • 14396
                    #264
                    Word. I would do this actually. They're really cheap.
                    Are your fronts Ate or Girling?
                    • KenC
                      King of Kegstands
                      • 14396
                      #265
                      They're not that much. Maybe if you have Ate fronts and do the guide bushings also.
                      • AbsorbantNut
                        • Jun 2010
                        • 2491
                        #266
                        Where'd you get those numbers? I just looked into it and found a front set for 7 bucks, rear set for 7 bucks. So 14 dollars for the seals....
                        • 5Toes
                          • 9836
                          #267
                          What, I am mistaken then. Ill order them I guess.
                          My car is late model so isnt that Girling?
                          Blunt shows this for front - http://www.blunttech.com/ShopByVehic...0Front&mode=PA
                          And rear - http://www.blunttech.com/ShopByVehic...20Rear&mode=PA
                          And it said two per car, but I guess that is wrong
                          • AbsorbantNut
                            • Jun 2010
                            • 2491
                            #268
                            Lol, it happens.
                            Just go take a look at them on the car
                            And for the edited part of your post:
                            Go to autohausAZ.com, they are 7 bucks there.
                            • 5Toes
                              • 9836
                              #269
                              SO it is more than $14...
                              8.25 per side for rears.
                              $12 or so per side for fronts.
                              Ugh
                              • 5Toes
                                • 9836
                                #270
                                Okay, just saw your edit, will do.
                                Why does Pelican and Blunt say two per car, but the picture both shows two sets of the boot and seal???
                                Whats the deal
