Prolonging the Procrastination...
  • parkerbink
    • Jun 2004
    • 10137
    #121
    Wow!
    • audiquattrot
      • May 2008
      • 3836
      #122
      Unbelievable build!!!!!
      www.instagram.com/snwmble
      #snwmble
      Current:
      '05 BMW M3 - Silver Grey/Imola Red
      '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
      '15 Mini Countryman - Blazing Red/Carbon Black
      Past:
      '01 Audi Allroad - Light Silver/Platinum Saber Black
      '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
      '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
      '90 BMW 325i - Schwarz/Tan sport *Sold*
      '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
      • Simon S
        • Oct 2004
        • 3758
        #123
        Originally posted by parkerbink
        Wow!
        yeah.. "Wow" is right..
        Man alive - your end-result work shore is purdy.
        -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
        • 85e325
          • May 2011
          • 551
          #124
          HOLY HELL. That is one monster m20, well done sir. What kind of numbers are you expecting??
          Justin Angelli
          1985 325e Gazellenbiege
            • 37828
            #125
            Looking GOOD my friend.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • Cronopoulos
              • Jul 2011
              • 2187
              #126
              Superb.
              Project log -- DIRTY 30
              2.7i * Megasquirt tuned * E85 powered
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                #127
                Wow, never seen a manual nutsert tool. I had a pneumatic nutsert gun I used to use back when I worked on a production line for a golf cart manufacturer.
                • Mtriple
                  • 3139
                  #128
                  Thanks, I think the fantasy is slowly becoming reality. ;)
                  Originally posted by 85e325
                  HOLY HELL. That is one monster M20, well done sir. What kind of numbers are you expecting??
                  Thanks, TCD claims 300rwhp with this setup.
                  Thanks Matt
                  I didnt realize there was a better tool, I should have guessed. I used this a TON on my S50 car and have used it 6 or 7 times already on this car. Seriously makes for a clean mounting point!
                  Ok, I ended up working on a bunch of the details this weekend. Things like the aftercooler plumbing, figiuring out the best circulation route, and mounting the pump. I also finished making all of my oil cooler lines.
                  016-1 by Bob Cooper, on Flickr
                  001-7 by Bob Cooper, on Flickr
                  001-6 by Bob Cooper, on Flickr
                  007-5 by Bob Cooper, on Flickr
                  008-6 by Bob Cooper, on Flickr
                  006-5 by Bob Cooper, on Flickr
                  Having the right tools makes all of the difference with AN fittings and braided line.
                  005-6 by Bob Cooper, on Flickr
                  Pump for aftercooler
                  002-9 by Bob Cooper, on Flickr
                  I need to sort the fuel lines on my next day off and I should be ready for first start. Getting close now...
                  • ak-
                    • 12422
                    #129
                    So awesome.
                    1991 325iS turbo
                    • Mtriple
                      • 3139
                      #130
                      Originally posted by ak-
                      So awesome.
                      Thanks!
                      I've been bogged down the last few days with a lot of the little details that take a lot of time. I started with the wiring under the hood. I made harnesses for the Spal fan, Aftercooler pump, and all of the gauge senders that I am currently using as well as what I anticpate I might use in the future. I also needed to extend the AFM harness to reach over to the passenger side of the bay.
                      Everything braided, loomed, and heat shrunk.
                      002-10 by Bob Cooper, on Flickr
                      The port on the left is the factory temp sender for the M cluster oil temp gauge. The unused blue port on the right is oil pressure which I will eventually get to.
                      011-1 by Bob Cooper, on Flickr
                      I also went through the factory harness that runs across the front of the car. Everything that I'm no longer using (A/C) was re-routed and tied up underneath and behind the front valence. I also wrapped the factory wiring in the traditional black cloth tape.
                      009-3 by Bob Cooper, on Flickr
                      This area is still a work in progress but the new harnesses that I made along with the o2 and wideband sensors come up to the battery tray along the firewall. They are close enough to the turbo that I decided to wrap everything in reflective heat resistant tape.
                      008-9 by Bob Cooper, on Flickr
                      I also figured out the feed/return on the fuel lines and finished mounting the BEGI and connecting everything. The BEGI RRFPR is only temporary as I would like to go to MS before the end of the summer.
                      008-7 by Bob Cooper, on Flickr
                      I added a VDO fuel pressure gauge.
                      006-6 by Bob Cooper, on Flickr
                      And with the fuel lines all connected I could finally mount the aftercooler and connect all of the fluid lines. I filled it with almost a gallon of distilled water, powered up the pump and bled the system. The pump is surprisingly quiet and will never be heard over the motor or fan.
                      005-7 by Bob Cooper, on Flickr
                      Drilled and tapped the intake cover for the wastegate signal line.
                      003-8 by Bob Cooper, on Flickr
                      And finally, with no leaks from the aftercooler I decided to throw the front valence on. It was a tighter fit than I anticipated with the oil cooler lines and heat exchangers. I need to trim the passenger side brake inlet duct and the lower valence trim.
                      004-7 by Bob Cooper, on Flickr
                      I need to hang the exhaust now but before I do that I need to address a bad shift selector seal. We tapped in a new one when the motor and tranny were out of the car. It didnt seat well going in and is now hanging up. I didnt realize it was a problem until everything was back in the car and I mounted up the shift linkage. The gear lever now stays on the 4th/5th and 1st/2nd gate and wont return to center on its own. I need to get up in the tranny tunnel and try and pull out the seal with a pick. Should be fun...
                      • parkerbink
                        • Jun 2004
                        • 10137
                        #131
                        OMFG!!!!!!!!!!!!!!!
                        So amazing!
                        Sorry about the shifter.
                        I just installed 2 SPALs on my Z amazing the differance they made.
                        • Mtriple
                          • 3139
                          #132
                          OMFG!!!!!!!!!!!!!!!
                          So amazing!
                          Thanks!
                          Yeah, I powered mine up last night and its crazy how much air it moves.
                          • 325ix
                            • Aug 2009
                            • 7783
                            #133
                            I like the braided wastegate line!
                            • TwoJ's
                              • Oct 2005
                              • 4908
                              #134
                              As always, excellent work man.
                              • Mtriple
                                • 3139
                                #135
                                The last week has been very unproductive. It's coming down to the wire now as the local euro car show I've been shooting for is next Saturday. I basically have a week.
                                Last Thursday I spent a few hours in the garage and one of the things that I wanted to accomplish was to prime the oil pump. Pulled the access cap and gear, hooked up a 1/4" socket to my drill and went at it. I was about 10 seconds into it and I looked down at the floor and there was oil pouring out on to the floor under the front of the motor. Long story short, when I reassembled the oil flilter/thermostat housing, I forgot the o-ring. Doh...
                                Ordered the parts from Blunt and then went out of town for the weekend to my in-laws place in the UP. No progress at all last weekend except the insane amount of wood that we cut, split, and stacked for the winter.
                                I was finally off on Wednesday and picked up a few items from blunt including the o-ring. I reassembled the oil filter housing and double checked/tightened all of my AN connections and proceeded to spin up the oil pump again to get oil flowing throughout the system.
                                002-11 by Bob Cooper, on Flickr
                                Success, until I took a close look at the oil cooler. This thing was installed briefly in my old S50 car back in 2004 and I pulled it out shortly thereafter because I was having some issues chasing down an oil leak. Anyway, its a Mocal that I bought from VAC 9 years ago and its toast. Its leaking just under the fitting.
                                005-8 by Bob Cooper, on Flickr
                                Best thing that happened on Wednesday was my wheels were finished at the powdercoater so I picked them up and took them over and had the tires mounted. Turbine covers are still out at paint, hopefully done on Monday or Tuesday next week.
                                008-8 by Bob Cooper, on Flickr
                                And had the strut bars done too. I wanted to have them done in AlpineII but the painter wanted like $300 which I thought was ridiculous. I tried to find a PC color that was close but got frustrated and just decided to go red for a little contrast.
                                010-3 by Bob Cooper, on Flickr
                                So Wednesday night I addressed the shift selector bushing and played around with taking some more play out of the UUC Evo3 SSK I installed last year. I added a shim to the front half of the carrier where the bitchclip is. It turned out well and I buttoned it up. I then cleaned up, painted, and reinstalled the heat shields in preperation to hang the exhaust.
                                Went out to the garage yesterday and hung the exhaust. I painted the all of the piping with high heat paint and masked off the cat and muffler.
                                007-7 by Bob Cooper, on Flickr
                                The install wasnt that wasy. The connection end of the cat was bent from shipping so I had to massage that back to normal with a pair of channel locks. Mounted enverything up underneath the car and when everything was right, put the clamps on.
                                018 by Bob Cooper, on Flickr
                                016-2 by Bob Cooper, on Flickr
                                013-2 by Bob Cooper, on Flickr
                                Oil cooler will be here Monday so I'm hoping to start it Monday night. I'm working tody and all weekend (three 12 hour shifts = 36 hours) so no chance other than a few hours when I get home to get a few little things done.
