Robbies alpine sedan 5cyl swap
  • ogbimmer
    • Jul 2010
    • 936
    Oh and the power comes from the head breathing better with a chip you should be able to rev to 7k
    " WHY DO YOU NEED 300HP TO DO THE SPEED LIMIT?"
    • mRodiek
      • 597
      I dont think you can just swap the heads, you need different pistons as well, the i combustion chamber is different than the eta.
      The Best stroker guide I have found in one location:
      Originally posted by e30lov
      sweet a mk4 jetta, haven't seen one of them for about 14 seconds
      Adventures of an E30
      • Pantless Spency
        It's McRib time!!!
        • Feb 2011
        • 7283
        wow i really like your volvo!!!
        based off that i think this build thread will go well :)
        good luck to you sir.
        • ogbimmer
          • Jul 2010
          • 936
          efffff volvospeed!!!! I cant read anymore pages without becoming a member haha. nice job with the changing a head gasket on the side of the road and the e85 stuff :)
          • mdlimy
            • Aug 2011
            • 289
            http://strictlyeta.net/technical/328i_3.html
            hmmm could have sworn you could just swap heads and it would be ok but just a lower compression. ill have to do some more research, maybe someone will chime in.
            thank you =] this build will be much more performance orientated and i dont think i will be going so much for the stretch/poke stance, but still will have good fitment, i just want some meaty tires to hook up.
            yea i figured
            thanks man, i know these cars like the back of my hand, volvo actually engineered them very well.
            I am putting my motor in a buddys car tommorow, then next weekend my manual swap goes in someone elses car, lucky to get some side work out of selling my parts, just wish i had more time.
            • mdlimy
              • Aug 2011
              • 289
              ok here is what i found on strictlyeta under the 2.8 stroker page
              "However, the stock 325e pistons will not work with the 325i head because of the different design; the 325i has a domed cylinder chamber to match the domed pistons while the eta has a flat cylinder chamber to match the flat pistons. Throw the flat 325e pistons into a 325i head and you have a mismatch that causes a lower compression ratio, and this for this procedure, lowering is a bad thing. So that leaves you with 3 choices: "
              So it sounds like leaving the pistons alone is what you want to do to keep the compression low if you want to boost it, so sounds like i should be fine leaving the whole bottom end alone and just swapping an i head.
              • Erik
                • Oct 2005
                • 5370
                You should hate that steering wheel too... and send it to me. ;) I would love to take those tan seats off your hands as well! :D Lol Car looks nice! Your Volvo was awesome. I love me some Alphards.
                -Erik
                Originally posted by 87e30
                • mdlimy
                  • Aug 2011
                  • 289
                  the seats and wheel were a couple of the sellings points for me ;)
                  i will miss the volvo alot, luckily i am selling almost all the parts to locals in the pnw so i will see parts of my car at the volvo meets/shows and the alphards might be going on my buddies e39....
                  • ogbimmer
                    • Jul 2010
                    • 936
                    yeah man! I would boost that engine while you build another one!. e30s are really fun cars with anything above 200hp, and if you boost about 15psi you should be in the 300 range.
                    plenty of people just get Arp head studs and a good tune and roll with it
                    • mdlimy
                      • Aug 2011
                      • 289
                      true, depending on the turbo, but i dont have the time or money right now to do anything, my plan is to get it driving, get it all cleaned up and just work on painting odds and ends and making it looks great, then coilovers and wheels then the vems install then turbo the eta with an i head and roll it and in the mean time either build an m20, m30 or m5x, have yet to decide.
                      • ogbimmer
                        • Jul 2010
                        • 936
                        Just let me know if you need any parts! I have alot of stuff lol
                        • F34R
                          sLaughter
                          • 12376
                          You really notice some extra power when dropping the i head on the eta bottom end? i know it drops compression to about 8.3:1 but allows for revving, where is the extra power coming from if there is such a loss in static compression ratio? you make me want to do an i head swap sooner than expected, i figured it would be pointless to do without boost bc of the low compression...
                          Upgraded fuel management/electrical system, BIGGER intake manifold. I am not 100% on what makes more in the head spec wise. All I know is the eta makes 121 and the b25 makes 179. Worth every bit to swap though =)
                          Instagram: @BWeissLeather
                          Current cars:
                          ~ '87 325 M30B35 swap
                          ~ '87 535
                          ~ 01 540 Msport 6spd
                          ~ '06 X5 4.8is
                          • Wh33lhop
                            • 11705
                            b25s are rated at 168 at the crank actually. The extra power comes from the extra breathing ability from the valvetrain in the i head and the rest of the intake tract. Loss of compression is not exactly ideal, but it is better than a stock b27.
                            paint sucks
                            • mdlimy
                              • Aug 2011
                              • 289
                              good to know guys, thanks. i will be doing an i head swap fairly soon just to make the car a bit more enjoyable, im sure i could make some decent na numbers once the vems is installed, atleast better than stock.
                              Made a bit of progress today, went to the junkyard, they only had one 325 and it was an e so i grabbed the throttle body i needed. The whole harness, ecu and guage cluster was gone so i still need to grab all that. I called around the only other 3 yards and none of them have any I's =[
                              I grabbed the rear heater hoses and that little valve setup from the 325e at the yard, i still use that even with the I tstat right?
                              so i still need
                              -I tstat
                              -eta harness and ecu and coding plug
                              -waterpump pully
                              -need to pick up the headers
                              also need to mount the alternator and ps pump, not sure if i have all the parts to mount them, it sucks because ive never worked on these before and i recieved the car with no motor in it and a trunk of parts lol.
                              yanked the motor back out and dropped the trans, damn these 260s are light!
                              sorry for the wierd color pics, for some reason my phone decided to not be normal lol.
                              managed to get the motor and trans mated and back in it goes
                              • mdlimy
                                • Aug 2011
                                • 289
                                og, pm me if you have any of the stuff im looking for if you have anything you think might be of interest to me ;)
