As far as cluster
The coding plug is the little tab thing in the front of the cluster when you remove the cover. Yank it out and swap it, no need to change the entire gauge cluster as you will be doing an 885 swap soon lol!
Make sure you grab the harness back to the ecu just to keep things simple.
As for t-stats, the valve in the rear of the block is just a tstat for you heater core. Helps prevent scalding coolant from blowing all over your leg. If it's original, delete it. If not, I don't see the harm in keeping it.
As for the crank sensors. Some eta's have two crank sensors some don't. I've had one with two, and I've had one with only one. You will need the ecu to whichever one you have. It is also flywheel specific so you would need the dual mass flywheel, clutch, pp, and trow out bearing. Post up your ecu label and someone will be able to tell you which is which.
I can't tell you off the dome which crank sensor goes where but the front should have a mount for it. IIRC the rear was mounted on the bellhousing. Not sure so don't quote me! lol
This is why we suggest you should grab a gasket and head studs and go ahead and do the head swap. It's only 30mins to get it off with the engine in the car and you will spend only a few bucks 100-$300 max
-885 head with intake
-throttle
-idle valve
-MAF sensor
-ecu
-harness
I believe that's all you need to be golden and you can grab one from a member for the low man. Trust me, piecing together that eta is going to take more time than to swap the I head. You can take that harness and ecu back but if you must continue we understand.
Also, you can use all stock b27 parts with the 885 head to have the super low compression if you plan to go turbo you will be golden. it won't be r3v happy.
as far as motor swaps, I'm a fanatic of the M20 because of its simplicity and performance. that b27 block is bulletproof and the 885 is most def needed for boost because of it's larger valves and free-er flowing/larger ports(like mentioned)
All you need to do is grab a good piggy back and tune it for 10-17psi and you're a torque monster and launching like a bat outta hell.
M/s5x motor swaps can be a pain if not planned correctly. Lots of odds and ends to be sorted out and you's be surprised with how common the swaps are, how much info is left out. Don't plan on turbo'n a swap without getting yourself familiar with it first.
-throttle
-idle valve
-MAF sensor
-ecu
-harness
