Kamotors E30-Turbo to ITB M20
  • TheTacoMan
    • Nov 2011
    • 2308
    #1531
    You got that done wicked quick, but no go fast blue timing belt? ;)
    • kamotors
      • Nov 2007
      • 7102
      #1532
      blue timing belt=pain to install. OEM for now, just got to hope it all works normal and its good for bimmerfest, new splitter material looks great, just need to cut and design some new brackets.
      7speedshop.com
        • 37832
        #1533
        That was fast. Nice work! New coolant tank is a nice touch too.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • kamotors
          • Nov 2007
          • 7102
          #1534
          Finally finished, it came out a lot better than before so it wasnt a total waste of time.
          one thin I noticed is that the difference in stud length is pretty significant. my old studs actually hit the valve cover in a spot and require me to dremel the vc a bit to fit. the new studs are perfect.
          My old studs were from nomade30 on E30tech not sure why they were so different. Also the new ARP kit came with washers which are much larger O.D than the stock ones which is nice.
          difference in size
          thread length difference
          but its all pretty and scrubbed with a tooth brush.
          7speedshop.com
          • Bimmer_man
            • Jan 2013
            • 1477
            #1535
            Nice man happy to see that car back on the road.
            Float like a cadillac sting like a Bimmer!:)
            • amcink
              • 788
              #1536
              Nice Ready for Bimmerfest!!!!
              • TrentW
                • 2815
                #1537
                So are the blue Gates belts hard to get on the sprocket?
                • TheTacoMan
                  • Nov 2011
                  • 2308
                  #1538
                  Twas a pain to get on.
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    #1539
                    If that's the case, then the adjustable timing gear plus blue belt will be even worse. Adjustable gears and stock belt is a tight fit already. Curious to see how those pan out.
                    john@m20guru.com
                    Links:
                      • 37832
                      #1540
                      We've installed one on a customer's engine and had no issues.
                      Couple more being installed in the next few days.
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • kamotors
                        • Nov 2007
                        • 7102
                        #1541
                        it was with an adjustable cam gear so maybe that was the reason it was such a tight fit.Its not actually hard, just compared to how easy a contitech installs I didnt want to deal with again.
                        7speedshop.com
                        • sayed ali
                          • 762
                          #1542
                          I'm very interested in that radiator cover! can you share some help about it ?
                          M20B28 Turbo
                          My Build Thread
                          http://www.r3vlimited.com/board/showthread.php?t=255839
                          • 325ix
                            • Aug 2009
                            • 7783
                            #1543
                            I was just looking at that! I really like the way it looks
                            • kamotors
                              • Nov 2007
                              • 7102
                              #1544
                              those are the CF covers I used to make and sell but no one was interested so I stopped.
                              Also put some miles on the E30 without issue today so looks like the bimmerfest trip is good to go.
                              7speedshop.com
                              • foltzs13
                                • Sep 2013
                                • 3
                                #1545
                                Your car is a true inspiration. I'll be at Cars and Coffee tomorrow and at LVMS and hope to see your car. Good luck with the drive down and let me know if you need anything once you get down here i.e. tools, garage, a place to crash.
