Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #2401
    I havent got the trans off yet. the clutch is some mystery clutch that todd at TCD sold me, he wouldnt tell me what "stage" just thats its good for 500+ ft lbs was not given a part number and i've asked multiple times. All I know is the pressure plate was manufactured by sachs but had a clutchmasters sticker on it.
    7speedshop.com
    • TheTacoMan
      • Nov 2011
      • 2308
      #2402
      This makes me believe it is some mass produced clutch that is able to hold a decent amount of power but is a clutch made for another car making it cheap to make more of a profit margin. This is all speculation but what is there to hide where a part number would cause issues?
      • LowR3V'in
        • 4209
        #2403
        Is it segmented kevlar ?
        • jntar
          • 459
          #2404
          I had the exact same noise/issue with my m42 turbo car. Ended up being the flywheel. Bolts somehow came loose and needed to be retorqued. Be sure when you do that you use locktite/threadlock since removing them pulls off the OEM thread lock.
          M42 turbo build.
          http://www.r3vlimited.com/board/showthread.php?t=301330
          • LJ851
            • 7918
            #2405
            ^ Good one, loose flywheel could easily make that noise.
            Lorin
            The M30 is God's engine.
            • kamotors
              • Nov 2007
              • 7102
              #2406
              the noise goes away with rpm, a loose flywheel would get worse I'd assume.
              also no updates on this car, but I've got to say a 325IX is a BLAST to drive. you'd never know its AWD untill your really on the edge.
              The way the IX can slide roundabouts is unbelievable, I was questioning whether the AWD was working it was so easy to slide.
              7speedshop.com
              • jntar
                • 459
                #2407
                In my experience that noise is generally associated with a grenaded transmission or my latest experience loose flywheel bolts. My noise would go away with rpm.
                M42 turbo build.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #2408
                  Centrifugal force. As the flywheel travels faster, it tends to "straighten out".
                  john@m20guru.com
                  Links:
                  • animal
                    • Jan 2010
                    • 804
                    #2409
                    wow - $100? better get down on your knees and thank God. ahahaha nice score!
                    91 DS S52 Slicktop, 91 Calypso M42, 89 Royalblau M20, 84 Bahama Beige 323i, M535, Euro e24, ap1
                    www.RenownUSA.com
                    ig @RenownUSA / @rude.scott
                    • LJ851
                      • 7918
                      #2410
                      Also, at low speeds (idle) there is more time between power pulses and thus more unevenness and kickback causing more noise for a loose component.
                      Lorin
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #2411
                        You mean like my m20/g260 TOB does at less than 800 idle? lol
                        john@m20guru.com
                        Links:
                        • jntar
                          • 459
                          #2412
                          My g240 with a lightened m20 setup sounds like death as well lol! Always getting looks at stop lights.
                          M42 turbo build.
                          • LJ851
                            • 7918
                            #2413
                            You got that trans off yet?
                            Lorin
                            • Northern
                              • 5146
                              #2414
                              He's too busy wasting time on that H6 swapped GM8
                              Originally posted by priapism
                              Originally posted by shameson
                              • kamotors
                                • Nov 2007
                                • 7102
                                #2415
                                truth:( buuuuut i may get another E30 this week. so I'll have 5 car, 2 subies and 3 E30's lol
                                7speedshop.com
