Kamotors E30-Turbo to ITB M20
  • Sagaris
    • Sep 2009
    • 2243
    #286
    Originally posted by kamotors
    I 'm loving it, I can almost build 1 psi off the line from loading up the drive train with the gas pedal and brake pedal.
    ATF temps increase very quickly when doing that. You may consider getting a trans oil temp gauge if you get in the habit of launching like that.
    • kamotors
      • Nov 2007
      • 7102
      #287
      yup, and its a horrible habit, it just too much fun lol. Doing some work on the tranny this weekend. I've just been slowly changing the fluid out for synthetic but now I'm going drop the pan and do a full change with the filter and gasket. Still need lines for my cooler and will also install my gauge.I can easily tell when its too hot because my shifts slow down a bit or shift earlier than the 6200.Usually happens after 1-2 hours of spirited driving.
      7speedshop.com
      • kamotors
        • Nov 2007
        • 7102
        #288
        NEW videos
        7speedshop.com
        • Simon S
          • Oct 2004
          • 3758
          #289
          while I haven't yet posted in this thread..
          I sure as shit have been following it..
          -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
            • 37832
            #290
            Car sounds great from outside!
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • kamotors
              • Nov 2007
              • 7102
              #291
              The transmission is leaving too much to be desired for me. I'm doing a 5 speed swap in the summer. The Auto is just shifting worse and worse with the more power I throw at it. At 7psi its fine but at 9 it just cant shift quick enough to stay off of the limiter. It doesn't slip or anything just not really fun....
              7speedshop.com
              • whodwho
                • Jun 2008
                • 1547
                #292
                I was going to mention that it didn't sound like it was shifting all that crisp in the videos but didn't want to drag up the whole auto trans topic again. It will be a much more drivable car with a manual unless it was just going to be a drag car. :)
                My M20 Frankenbuild(s)
                4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                • kamotors
                  • Nov 2007
                  • 7102
                  #293
                  SO I guess the limit of the autotrans is somewhere around 7psi, because it was shifting real crisp and quick until I turned up the boost.
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    #294
                    So I got my 5 speed ordered up I just went with a g260. Found a great deal with low miles. still need all the other parts to swap it in.
                    7speedshop.com
                    • kronus
                      • Apr 2008
                      • 13032
                      #295
                      Nice.
                      cars beep boop
                      • Farbin Kaiber
                        Lil' Puppet
                        • 29502
                        #296
                        I've still got my eyes peeled for a parts car we can share...
                        • kamotors
                          • Nov 2007
                          • 7102
                          #297
                          cool, thanks a lot
                          7speedshop.com
                          • kamotors
                            • Nov 2007
                            • 7102
                            #298
                            ordered my spec stage 3 clutch.
                            anyone have a flywheel they would like to sell?
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              #299
                              SO here's what I have coming in the mail so far. If you have any parts that I need please let me know:)
                              Purchased
                              Used:G260 w/ 120k
                              New: Spec stage 3 clutch kit
                              Selector rod seal
                              Input shaft seal
                              Clutch hose+fitting
                              Slave cylinder
                              Master cylinder
                              Flywheel seal
                              Flywheel bolts
                              Pilot bearing
                              Pressure plate bolts
                              Spring or clutch release fork
                              some curil-t
                              and a set of inverted torx sockets.
                              7speedshop.com
                              • freeride53
                                • 11972
                                #300
                                Finally! Thing was/is on its last legs for sure.
                                1983 Peugeot 505 STI
                                1992 Volvo 240 Wagon
