Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #436
    whodwho megasquirt purchased and coming soon:)
    7speedshop.com
    • kamotors
      • Nov 2007
      • 7102
      #437
      because....
      7speedshop.com
      • Denny
        • Jan 2010
        • 822
        #438
        Originally posted by kamotors
        because....
        Very nice man, will you be making these and selling? I think Im going to require..lol...
        I finished tuning my SC tonight am losing the back end even with LSD and brand new 225's in the back...im getting 5PSI intercooled max as soon as 2000RPM so it allows me to run a good 27 degree timing at WOT....
        Even at low boost its amazing how strong its pulling! hell I think I could destroy my girlfriends 2012 WRX right now without adding the turbo.
        BTW if you want to go twincharge lets open a collaboration thread?....I will help you supercharge and you help me turbocharge :D plus we both are going MS!
        I have a few brackets being made to adapt the Gen5 M62 from a cobalt ss on the M20B25..
        Denny
        ___________
        1990 BMW red 325IC M30B35 all stock Girlfriends ride
        1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
        Blogs:
        http://bmw325e30.blogspot.com/ (restoration)
        http://bmw325e30turbo.blogspot.com (Twincharge M20)
        http://bmw325e30m62b44.blogspot.ca/
          • 37832
          #439
          I like where this is going.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • kamotors
            • Nov 2007
            • 7102
            #440
            got MS installed but cars idles low and runs rough and dies occasionally, think Its just a simple setting i need to adjust.
            problem that I don't know how to fix is that the AFR gauge in tuner studio isn't corresponding with my wideband gauge in the car. In TS it just sits at 10 but when I rev it I got it up to 12 even though my car is idling around 14AFR on my actual gauge.
            7speedshop.com
            • whodwho
              • Jun 2008
              • 1547
              #441
              PM'd :)
              My M20 Frankenbuild(s)
              4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
              • Sagaris
                • Sep 2009
                • 2243
                #442
                I will be interested to hear your comparison between W.A.R and MS2
                • kamotors
                  • Nov 2007
                  • 7102
                  #443
                  SO got my idle fixed and my wideband issue sorted. Running smooth! its a bit rich everywhere but my idle is very stable and the car no longer has weird stalling issues like it did with motronic.
                  7speedshop.com
                  • sayed ali
                    • 762
                    #444
                    Any videos of the car running?
                    M20B28 Turbo
                    My Build Thread
                    http://www.r3vlimited.com/board/showthread.php?t=255839
                    • kamotors
                      • Nov 2007
                      • 7102
                      #445
                      Loving megasquirt and the Help that Whodwho is giving me with tuning.Smoking tires and other cars all day:)
                      7speedshop.com
                      • kamotors
                        • Nov 2007
                        • 7102
                        #446
                        Forgot to mention when my car is cold my turbo will burn oil when going downhill.
                        the only thing I can think of is that since my oil is cold, slightly overfilled and turbo drain is on the front corner of my pan that is get a bit of backup due to slow oil and the drain being slightly below oil level going down hill
                        7speedshop.com
                        • kamotors
                          • Nov 2007
                          • 7102
                          #447
                          so 60lb deka fuel injectors are installed but I cant get the car to run right, I lowered required fuel to 3.5ms and it idles good just as soon as I touch the throttle it rich spikes and stutters.
                          7speedshop.com
                          • kamotors
                            • Nov 2007
                            • 7102
                            #448
                            the injector clips dont lock onto the dekas like stock did... it should be fine but I'm not 100% sure.
                            real rieger:) going to make a nice splitter/undertray
                            7speedshop.com
                            • kamotors
                              • Nov 2007
                              • 7102
                              #449
                              7speedshop.com
                              • Cronopoulos
                                • Jul 2011
                                • 2187
                                #450
                                Nice work!!!
                                Project log -- DIRTY 30
                                2.7i * Megasquirt tuned * E85 powered
