Kamotors E30-Turbo to ITB M20
  • Bimmer_man
    • Jan 2013
    • 1477
    #2986
    Are you adding a turbo soon?
    Float like a cadillac sting like a Bimmer!:)
    • kamotors
      • Nov 2007
      • 7102
      #2987
      trying to get the car as good as it can be N/A first, then add boost. SO basically after this 150lbs is out I'll likely add boost.
      7speedshop.com
      • Bimmer_man
        • Jan 2013
        • 1477
        #2988
        Nice. Let me know where you get a manifold made I'm going to need one myself soon enough for my ix.
        • kamotors
          • Nov 2007
          • 7102
          #2989
          I may just sell the ITBs to fund the turbo setup
          7speedshop.com
          • kronus
            • Apr 2008
            • 13032
            #2990
            lexan windows
            cars beep boop
            • amcp
              • 489
              #2991
              you can lose 10lb moving the battery to the front right side tray under the hood. Same place BMW put it in the verts.
              • Bimmer_man
                • Jan 2013
                • 1477
                #2992
                Don't sell the itb set up man. Do that with the turbo. That would just be bad ass.
                • CorvallisBMW
                  Long Schlong Longhammer
                  • 13039
                  #2993
                  Li-ion racing battery, 17lbs: http://www.jegs.com/i/Braille+Auto/1...xFVRoCiSvw_wcB
                  • kamotors
                    • Nov 2007
                    • 7102
                    #2994
                    yes that is the exact battery I'm using a few posts up, but I paid less
                    7speedshop.com
                    • LJ851
                      • 7919
                      #2995
                      I see your light battery and raise you even more cranking amps @ a feathery 3.25 lbs.
                      This 12 volt LiFePO4 battery is the same size as the popular YTX-12 motorcycle battery, but it offers a full 720 cranking amps and weighs just 3.3 pounds.
                      Prob overkill for a M20, so you can go to the 20 cell model with 600 cranking amps @ 2.65 lbs for maximum effect.
                      Easily find what you are looking for with our main categories in alphabetical order.
                      Lorin
                      The M30 is God's engine.
                      • TheTacoMan
                        • Nov 2011
                        • 2308
                        #2996
                        https://www.pegasusautoracing.com/pr...sp?RecID=12589
                        We had those at the Motorcycle shop I used to work at, very light batteries. Work really well from what the racing guys told me.
                        • CorvallisBMW
                          • 13039
                          #2997
                          2.65lbs? Damn son...
                          • pandaboo911
                            • 2070
                            #2998
                            Cut out the spare tire well? Weld in flat piece of sheet metal
                            • IronFreak
                              • Dec 2012
                              • 3702
                              #2999
                              Originally posted by pandaboo911
                              cut out the spare tire well? Rivet in light gauge aluminum
                              ftfy
                              ;D
                              Instagram @rebellionforge
                              • CorvallisBMW
                                • 13039
                                #3000
                                Cut out the spare tire well? Rivet in thin sheet of CF
                                ftfy again
                                ;D
