91' 318is S52 Swap "The Beast"
  • craiggroves91
    • Oct 2009
    • 3024
    #616
    Originally posted by 328ijunkie
    Needs a tune ;)
    I've honestly been wanting to have you tune for me but don't I have the funds atm...what are you charging?
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
    • craiggroves91
      • Oct 2009
      • 3024
      #617
      Sucks minus took a dump and now all my pictures are missing :(
      1989 BMW 325i SOLD
      • craiggroves91
        • Oct 2009
        • 3024
        #618
        I got Black and yellow plates a while ago. I dig em
        DO NOT USE E36 MISHIMOTO RADIATORS. I went through two during a 4 year period. They leak at the rows on both sides due to poor engineering and I have heard of people having the same problem. Use a Z3M radiator instead!
        Replaced the VC gasket yesterday since it was leaking. Hard to tell so soon but it might still be leaking...not sure why. Could be a warped Valve cover
        Finally got my Momo race wheel on. It's small, but I enjoy it.
        Tried getting my strut housings ready for the GC conversion kit. I bought them already welded up, but I needed to do some grinding
        Having a hell of a time trying to figure out what shocks to run with shortened strut housings and 550 front and 700 rear springs.
        1989 BMW 325i SOLD
        • 2mAn
          SeƱior Mod
          • 20185
          #619
          Originally posted by craiggroves91
          Replaced the VC gasket yesterday since it was leaking. Hard to tell so soon but it mights still be leaking...not sure why. Could be a warped Valve cover
          I just replaced mine and its still leaking too. Thought I could blame it on being a VictorReinz, but now Im wondering if the plastic cover got warped. Ive been lagging on installing my OBD1 metal cover on. I have a Goetze gasket for it too, so I should probably ramp that up...
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          -2006 Volkswagen Jetta TDI
          Make R3V Great Again -2020
          • craiggroves91
            • Oct 2009
            • 3024
            #620
            I replaced mine with Elring hoping it was VictorReinz's fault as well. I may try to tighten the nuts in a different pattern to see if that helps. Next step would be an OBD1 cover...Not sure how much those run for.
            1989 BMW 325i SOLD
            • 2mAn
              SeƱior Mod
              • 20185
              #621
              I replace mine with Elring hoping it was VictorReinz's fault as well. I may try to tighten them the nuts in a different pattern to see if that helps. Next step would be an OBD1 cover...Not sure how much those run for.
              Sorry, just checked. My OBD1 is also an elring, but I have a VR right now on the OBD2 valvecover. I plan to do another round of tightening them down also because the tech who was allowing me to do the VCG at his shop told me it didnt need to be torqued down very much.
              edit: How many miles have you put on your swap so far?
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              • craiggroves91
                • Oct 2009
                • 3024
                #622
                Yeah, they only require 89 inch-lb or 10 NM I think it is. I'm not sure how much that really is without a torque wrench that goes that low.
                EDIT: I'm reading that it's best to just bottom out the nuts. So just tighten until they stop turning and stop.. Not what I did.
                My odometer doesn't work, so a rough estimate would be maybe 20-25k. I don't have to drive very far for work or school.
                1989 BMW 325i SOLD
                • kronus
                  • Apr 2008
                  • 13014
                  #623
                  did either of you put rtv down on the vanos seam and the half-moons at the back of the valve cover while putting on the gasket? cause you're supposed to...
                  cars beep boop
                  • craiggroves91
                    • Oct 2009
                    • 3024
                    #624
                    Yes, I did. I incorrectly tightened them. I redid it yesterday and bottomed them out in the right pattern. So we will see if that works.
                    Sent from my SM-N920V using Tapatalk
                    1989 BMW 325i SOLD
                    • 2mAn
                      SeƱior Mod
                      • 20185
                      #625
                      I did too
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      • kronus
                        • Apr 2008
                        • 13014
                        #626
                        weird.
                        cars beep boop
                        • 2mAn
                          SeƱior Mod
                          • 20185
                          #627
                          I didnt tighten them down all the way, so I'll be doing that
                          Simon
                          Current Cars:
                          -1966 Lotus Elan
                          -1986 German Car
                          • craiggroves91
                            • Oct 2009
                            • 3024
                            #628
                            Can someone direct me to where I can find coilover sleeves and adjusters for the front strut housings?
                            Ground control won't sell me any separately.
                            1989 BMW 325i SOLD
                            • varg
                              • May 2014
                              • 3305
                              #629
                              I got mine on ebay, it was like $60 for a "coilover kit" for a Honda, that came with 4 useless springs and 4 adjuster sleeves (jam nut not pinch bolt type, but they work fine). Cut them down and make them fit.
                              Bummer about the radiator. I was searching for info about those Mishimoto radiators, since they look so trick and seemed to be high quality when I had handled them. I kept hearing about people having the same issues. I'm going to go with the Z3M rad based on it.
                              IG @turbovarg
                              '91 318is, M20 turbo
                              [CoTM: 4-18]
                              '93 RX-7 FD3S
                              • craiggroves91
                                • Oct 2009
                                • 3024
                                #630
                                Thanks! I was just looking into those, but how do I know if they'll be the proper diameter? They aren't listing any specs anywhere haha Do certain Hondas hace 51mm strut housings as well?
                                Yeah, the only good thing about mishimoto is their warranty and even then you have to pay shipping for the new radiator. Z3M is a much better option! It has been performing just as well as the mishimoto did.
                                1989 BMW 325i SOLD
