I might actually want it back... I did like what Stuart's exhaust sounded like back when he first got the car without a gutted cat.
shEck3lls0's 318i Rallycross/ DD (slow) build
1989 Alpine 325is 2dr m50 swapped
Build Thread:
Current ongoing build. Check it out!
1991 318is 4dr rallycross
Rallycross Build Thread.
1991 Alpine 318is coupe - sold -
you bring me a stock one, I'll swap you. I've driven up to B-more enough this year, lol...
There is a small crack under the inlet pipe that you'd need to fix - should be a super-easy weld.Stage rally/rallycross e30 build/competition journal
Track/street e21 build
visit Condor Speed Shop
visit Motorsport Hardware
[FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTIComment
Josh. I may be down that way this weekend. I will contact you. I'm getting some other bits and pieces for my other car from Mike R. Not sure how close you are to him.sigpic
Build Thread:
1991 Alpine 318is coupe - soldComment
IDK....I'm about 10 minutes from Yoshi, if you know where he lives. I'll be at work all day Saturday though (or at least til 4ish), home SUnday and Monday.Stage rally/rallycross e30 build/competition journal
lol....well, 318i bits won't do me much good at this point since no more M10 in my car, and no more 318i suspension or brakes....Stage rally/rallycross e30 build/competition journal
Finished getting my mudflaps on. Look pretty good, though I wish they were red. Might try plastidipping them.
Also put a cool new sticker on. ;) Thanks to Levent.
I kind of want to spice up the car a little bit with some vinyl or something (or maybe some sponsor stickers *hint*hint*). Or maybe some spray cans. We'll see what the future beholds.
In other things I noticed that I am getting a good amount of oil leakage around the oil pan, so this weekend I will be pulling the oil pan off and putting my new gasket on and inspect the bottom end since I've been having to add oil to it more frequently.sigpic
Build Thread:
screw new gasket. Get Permatex Gray and use that instead. I just replaced my brand-new oil pan gasket (OEM) that was leaky with PT Gray....no more leak....ever.Stage rally/rallycross e30 build/competition journal
Spencer-
I have about 12 cans (maybe more) of mixed dark red metallic spray paint. All of it is new and unused. Might that be of use?Comment
And do you still need a G260? I sent you a text about it. I think...Comment
As far as not using paper/cork gaksets for oil pans, I used "The Right Stuff" on my oil pan gasket. It was recommended to me by quite a few people & has been holding up great to boost ;)
'73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]Comment
^^ Right stuff is pretty similar to Permatex Gray functionally. As far as I can tell, the main difference is that Right Stuff can be torqued to spec immediately, but with Ultra Gray you let it set for an hour hand-tight and then torque to spec. I think they pretty much have the same sealing properties and blow-through resistance (though I could be wrong). Ultra Gray actually has a higher continuous temperature rating as well.
I've used both, and the end result material seems to have the same amount of elasticity and stiffness for both. Right stuff is for when you need to seal it immediately (like fixing it at the track during a race), and Ultra Gray is when you have time.
Right Stuff costs about 5x as much too :)Stage rally/rallycross e30 build/competition journal
What about ultra black? I have 2 tubes of that. Wonder if that would work just as well? I think I have some ultra blue laying around somewhere too.sigpic
Build Thread:
Build Thread:
