Blunttech e12 LSx / t56 swap
    That would be the easiest...or to just run the stock bar. But I am thinking it might make the rear a bit loose. Maybe not sure....I'm not very up on chassis dynamics.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
      Sorry I don't have a suggestion regarding the sway bar...
      But I was curious to know: What are the spring rates for both front and rear springs?
      1989 US E30 Cammed S52
      Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
        Im not sure All I know is they are Spax. We just put them on Brandons e28 and they are low and firm. I like them, at least on the e28
        Some have said they are too soft though..
        sales@blunttech.com
        www.blunttech.com
        Like us on Facebook
          You will want a beefy sway bar in the rear for the LS power. Not sure on the options as I never mod the e28. But the whole point of the sway bars to to stiffen up the car for driving. With the V8 up front and all the power out back it would be a good idea.
          Granted when I autocross I unhook my rear sway to make sure I don't get a wheel lifting when I corner hard. Road use you will not be doing hairpin turns and worrying about lifting. You will want the most control with that happy back end.
          Poly sway bushings and a bigger sway front and rear would be a big help with this big car. Trust me, you WILL notice the sway being gone in the front...how do I know? My last e24 had blown out sway mount plates. Just kinda hung there. New rubber mounts and plates made a night and day change.
          So trust from my knowledge and first hand experience with a heavy BMW and a heavy engine up front. It is VERY sloppy and handles like crap.
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
            I did send Jake big sways for the car and he has them in the car. Just trying to figure out how he is going to mod the front bar to fit now. Thanks dude
            sales@blunttech.com
            www.blunttech.com
            Like us on Facebook
              What intake manni and throttle body are you running?
                Originally posted by achtung View Post
                what intake manni and throttle body are you running?
                ls6
                sales@blunttech.com
                www.blunttech.com
                Like us on Facebook
                  GTO oil pan?
                  Sorry for all the questions. I'm piecing together a lq9 setup right now.
                    GTO oil pan?
                    Yes GTO Pan I can answer all the easy ones lol Jake knows everything
                    sales@blunttech.com
                    www.blunttech.com
                    Like us on Facebook
                      I did not see that, I just scrolled up and saw the posting. Sorry for the tech vomit
                      Good info for someone that reads it at some later date or whatever.
                      Jake is very skilled and will have zero issues doing it right.
                      Current cars:
                      ~ '87 535
                      ~ '06 X5 4.8is
                        Man I missed a lot tonight....Wednesday is bowling night.
                        Yes Ls6 intake and stock TB (truck, ls1, ls6, all the same), cable driven
                        And yes GTO oil pan.
                        The sway bar is just about figured out. New mounts need to be tack welded and then when it is back on the ground I will make the end links.
                        Made the power steering/hydro boost lines, throttle cable, and shifter mech today after work. Just need to take the power steering lines back to be crimped down tomorrow.
                          No problem All info is good info. Im excited Jake thinks it may be done in a week. He will likely drive it a while and then Ill fly out and pick it up. Im going to rip up the back roads all the way home. I took a really sweet route out there through wisconsin backroads and up through the U.P.. . Virtually no cars and 80-90 MPH all the way on blown shocks and cut springs and worn bushings. Should be quite a change with all new everything. Its really surprising how nicely the car drove. It wasnt perfect but it wasnt bad
                          sales@blunttech.com
                          www.blunttech.com
                          Like us on Facebook
                            Jiminy Christmas!
                            I don't hang out on R3v for ten min and look what happens!
                            I'll call next time I'm in msp.
                            John
                            The Revolution will not be televised.
                              Originally posted by harv View Post
                              Jiminy Christmas!
                              John
                              keep trying John ... problem is you never give me much notice and I understand thats because of your schedule but we will connect sooner or later.
                              sales@blunttech.com
                              www.blunttech.com
                              Like us on Facebook
                                Originally posted by jakeb View Post
                                The e12 uses a mechanical speedometer where the t56 trans does not. I was going back and forth of either getting a electric to mechanical speedo driver or converting to an electric speedo.
                                Going with the electric speedo....better accuracy...and a odo that can't stop working because of old gears.
                                VDO speedo and e12 speedo/ VDO speedo has already been pulled out of its housing and the glass has been removed.
                                Remove both needles of the gauges
                                The needle on the e12 happens to be the same size shaft as on the new electric vdo
                                I will scan both faces into the computer and edit the e12 face to match the swing on the new vdo gauge.
                                I know Blunt is at vintagefest in Chicago...wish I was there as well but other commitments wouldn't allow this year.
                                Jake - Can you talk more about the cluster? This is the part the confuses me the most regarding this swap. How are all the other gauges and sensors going to be interfaced to the cluster?
