►►►Tales from IronFreak and his shop shenanigans◄◄◄
  • IronFreak
    • Dec 2012
    • 3702
    #721
    Originally posted by ak-
    I wish I was able to run an intercooler with a core that thick under a stock core support.
    Yeah there is no way it would fit, I have maybe 3/16" between the rad and intercooler right now. I slotted the intercooler tabs to allow for some adjustment.
    Just weld on the desired in/outlets. You'll be so much happier. There isn't anything on an intercooler that promotes a warranty that someone with your talent can't fix with a welder.
    I agree and that's the plan, I want to move them up directly under the bumper support tube to eliminate some plumbing and clean things up.
    Instagram @rebellionforge
    • eduTechnic
      • Dec 2012
      • 400
      #722
      I love the dual-purpose mount tubing. Everything looks really great. I wonder if adding add some threads/brackets to mount some separate shrouds for the IC and oil cooler/radiator and guide the upper shroud air down at the rad/oil cooler.
      Just a shroud example. Been kicking around some ideas in my head to run a big IC but not kill flow to the rad.
      Turbo M50 4 Door Build thread here 4 Sale thread
      • IronFreak
        • Dec 2012
        • 3702
        #723
        That's exactly my plan actually. once I get everything mounted I'll open up the valance and make some aluminum shrouds to direct airflow.
        • eduTechnic
          • Dec 2012
          • 400
          #724
          Killer. I like how that shroud extends the frontal surface area a bit. Looks great in blaaaaaaaack.
          • DER E30
            • Sep 2013
            • 2349
            #725
            Stealthy
            -Christian
            • IronFreak
              • Dec 2012
              • 3702
              #726
              Got a bit more finished last night.
              Front is all welded up. I need some hardware to to finish mounting the oil cooler otherwise its all done.
              Final resting place for the oil cooler. stoked how well it all fits. line will clear the hood as well.
              Started mounting the expansion tank too
              you guys think it would be ok to run that tank through the dishwasher to clean it out really good, or have any other suggestions?
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                #727
                I dont see why not. Or just fill up a 5 gallon bucket with dawn and hot water and let it sit over night and rinse it out the next day.
                1991 318i 4dr slick top
                Mtech 2 turbo restoration
                • gotaloveRWD
                  • Jul 2011
                  • 708
                  #728
                  I thought new ones weren't that much?
                  Never mind just looked them up and it's twice as much as I thought
                  About 100$
                  IG- nv_e30
                  • IronFreak
                    • Dec 2012
                    • 3702
                    #729
                    Do you have the sensor for that tank? I'm not going to wire it but obviously I need it for the tank to function properly.
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      #730
                      New ones are 104 bucks i sold it to him for 20.
                      I do not. It came with out iirc you can use the sensor from early model.
                      • IronFreak
                        • Dec 2012
                        • 3702
                        #731
                        OE is $80-114 depending on where you buy it. I am hemorrhaging money on this build, I'm utilizing whatever I can and will go back later on some of the cosmetic stuff.
                        • IronFreak
                          • Dec 2012
                          • 3702
                          #732
                          Ok, e36 should be the same I'll see if there is one in the yard.
                          • IronFreak
                            • Dec 2012
                            • 3702
                            #733
                            hey.......
                            • lambo
                              Captain Scene Points
                              • 10953
                              #734
                              neat
                              • kingston
                                • Jun 2010
                                • 2669
                                #735
                                Looking great, Ross!!
                                Originally posted by LJ851
                                kingston is the play by play announcer for this thread.
                                ‘Tis by the grace of God that my cars run!
                                Originally posted by unloadedak
                                #teamross
                                Siobhan's Build Thread - UPDATED!
