Back in Black (now with s50 and bags)
    I'm so close guys just need some wiring help.
    I don't have anything from my harness to connect to my starter solenoid relay (male fitting on starter). So what exactly do I do?
    Instagram: @dillonmakar
    Build thread HERE
      subbed for the answer!
      .................................................. ...................sigpic
      .................................................. ............................. ......M50B25 3.1L stroker
        Still haven't gotten it to start.
        I have spark and fuel is going into the rail but the injectors aren't firing. I'm assuming it is something electrical because there is no way all six of my injectors are bad.
        Build thread HERE
          Are you using an E34 or E36 harness? On my E34 harness I had the same issue because the injector power cable is run to some post on the bottom of the thing that holds the 3 relays. Moved that to the power post in the bay and it fired right up.
            nice. Can't wait to see the end result
            95 7.1L 16V E36 M3
            Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
            LIKE my Facebook Page! CLICK HERE
              Pretty sure it's an e36 harness. I do have an extra cable that runs down near the starter. Is that the same one you are talking about? I checked to see if it was a hot wire though and it wasn't.
              Build thread HERE
                your fuel line are on backwards.
                I do this everytime i put a 24Valve into a car. its tradition now. With the exception of when i put my S50 into my car, i managed to get it right.
                1985 325e M50TU(Sold)
                1991 318is Slicktop (Sold)
                1990 325is Brilliantrot S50/5 Lug Swapped.
                1992 525i Manual shitbox Winter Beater
                  Yeah I had them backwards at first but I fixed them and they injectors still aren't firing.
                  Build thread HERE
                    Damn it. Sounds exactly like what happened to me and it was that power wire. Check the wires coming back from the injector harness then because they have their own like power wire. Like I said on the E34 harness, there was a little read wire with a connector on it that bolted to the under side of the deal that holds the 3 relays.
                    Other than that, I can't really speculate as I never wired a harness adapter. I cheated and bought a treehouse adapter.
                    You know what you need to do is stare at the car quietly for like 5-10 minutes. Let all frustration go. Go to Chipotle, get your delicious burrito and sit down and just think quietly. Give it a couple minutes and it will come to you. You will feel like a total idiot though because it's going to be something so small..
                      haha best advice I've got.
                      But a slight update. I have signal 12v going to the injectors so I'm getting signal. I tried to test the injectors by using a battery and i still couldn't get the injectors to fire.
                      I'm starting to think my injectors are bad but I just can't bring myself to believe that somebody sold me bad injectors.
                      Build thread HERE
                        I also feel like the likelihood of all 6 being bad is pretty slim. And yeah I didn't realize you had power at them. Good luck man.
                          Well, tested all 6 of them and even had a mechanic come double check and we couldn't get them to open. I guess some how all 6 are bad which is really odd...time to buy some new ones.
                          Build thread HERE
                            oh and here is a little tease of what is coming
                              IT RUNS!!!!!!
                              Full update coming soon
                              Build thread HERE
                                IT RUNS!!!!!!
                                Was it the injectors?
                                Congrats!
