Idk you tell me! Haha turbo still need to pick up
My e30 Drift car and the road to a 600whp m20
Hi there!
cool build :)
since catuned wont answear my question, maybe you can. Can you tell me the difference of the catuned axels, and the stock ones ? i know the shafts them self is beter and stronger. But in my point of view the real weakspot is in the cv gages. Are those bigger? are the balls inside bigger ? do you still use the stock diff carrier, the one you fastn the cv joint too ?Comment
Idk why I'm having issues replying but the cv joints are upgraded. They retain stock diff axle carriers.Comment
Instagram @rebellionforgeComment
We try to keep it fancy around here.Comment
you could ponder converting to use a M52/S52 single coil instead of the E30 original coil. It may be more stable-Thank you!
Whelp problem we had on the dyno is my spark plug wires/coil would have a random misfire also my wg was not holding (hence the new forge) but at 16psi dropping down to 14 we managed 360whp and 360 tq. Ill be working on getting the new gate installed in the next month or so and some new numbers and graph. Also with the new head spool starts at 2500 by 3k it's 10psi
the M73 engine cars use 1x s52 coil pack to drive each M20 dizzy cap and rotor.OBD1 M54/M52TU swap as a M50b25
Severe lack of updates in here..............sigpic
My apologies, I do so much on fb/ig I forget. One more!
I need a lift....sigpic
