Emma Watson and 2 E34's (Low Mount Turbo M50 Project)
  • Dj Buttchug
    • Jun 2010
    • 7673
    #256
    stupid chit has happened. 200k+ original engine. valve seals/guides leaking burning 2+ qts of oil every 3k miles. Started smoking on hard accel and engine braking. Time to see whats up.
    stupid angle
    on the ground
    10/10 ebay raceland headers for .224 hp gain
    dirty
    gross build up
    too many parts & vanos stuff
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • LowR3V'in
      • 4209
      #257
      Dang.
      200k isn't really that much do m50s have oil burning problems at that age?
      • Dj Buttchug
        • Jun 2010
        • 7673
        #258
        Not sure. mine does though. its most likely from PO not changing the oil on time and it destroys everything
        Ig:ryno_pzk
        • AbsorbantNut
          Non faccio funzionare questa merda
          • Jun 2010
          • 2491
          #259
          No emma for 12 days :/
          '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
          • Navarone
            • Jun 2014
            • 935
            #260
            No fap February?
            • Dj Buttchug
              • Jun 2010
              • 7673
              #261
              minimal fappage :(
              more progress today
              block surface and piston tops are free of carbon buildup and ready for the new gasket.
              There was another thread on the subject of pinging. I always had detonation under load at freeway speeds and Im starting to believe carbon build up was the reason. Each piston had nearly a 16th of a inch of buildup. Enough to completely fill the valve cuts and then some. Also the bottom of the head/ valves and remainder of the combustion chamber had tons of it.
              I bet it raised the compression enough to cause issues.
              Head is out getting the works. Probably going to need guides now. $$$
              pics
              The timing chain guides are fcked so theres another 60 bucks added to the project. Total so far is
              $550 completely revamp head including ported intake and exhaust side. (just in case boost)
              $60 timing guides
              $150 ARP head studs (just in case boost)
              $90 HG kit and gaskets
              Ig:ryno_pzk
              • Dj Buttchug
                • Jun 2010
                • 7673
                #262
                ARP studs in. head will be done tomorrow
                Ig:ryno_pzk
                • AbsorbantNut
                  • Jun 2010
                  • 2491
                  #263
                  So with all this preparation for boost........i'm hoping there will be boost:devil:
                  • LJ851
                    • 7919
                    #264
                    Lorin
                    The M30 is God's engine.
                    • lambo
                      Captain Scene Points
                      • 10953
                      #265
                      Gonna need a source on this figure.
                      • mrcheezle19
                        • Apr 2012
                        • 1451
                        #266
                        Let's get this thread back on track with more emma.
                        Dude this is r3v. 20 bucks gets you a used timing belt or a low mileage head gasket
                        • Good & Tight
                          • Apr 2004
                          • 2057
                          #267
                          Nice clean up work on that engine. Did you mention Booooooost...!
                          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                          ____________________________
                          E-mail Panayiotisx2@gmail.com
                          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                          • AbsorbantNut
                            • Jun 2010
                            • 2491
                            #268
                            gonna need a source on this figure.
                            rt
                            • 2mAn
                              SeƱior Mod
                              • 20729
                              #269
                              dude, while you were out playing with your car, you lost your girl to Prince Harry
                              Simon
                              Current Cars:
                              -1966 Lotus Elan
                              -1986 German Car
                              -2006 Volkswagen Jetta TDI
                              Make R3V Great Again -2020
                              • LJ851
                                • 7919
                                #270
                                Yeah, they're big. Deal with it.
                                Lorin
