ITB's on a 24v project, Dyno results Post 136!!!
  • ForcedFirebird
    • Feb 2007
    • 8300
    #76
    Originally posted by digger
    you get a better transition from round to oval with a longer manifold adapter. which is less likely to upset airflow especially given proximity to where fuel is injected
    how does the cross section vary compared to stock M50 manifold? ie what is the equivalent runner diameter for the plastic OEM at the start and end of runner and for this setup? also how does the length compare for both?
    Same as stock meeting the head (1078mm^2), 45mm round (1590mm^2) with a smooth taper in a ~150mm length
    Originally posted by Bimmerman325i
    Very curious, pending results. Is the test motor/intake/exhaust 100% stock for good benchmarking?
    How does idle control work with these?
    What are you doing for a plenum / airbox?
    -E36 guy, want a setup like this for Nasa TT build on S50.
    Air-boxes are in the plans, we have vacuum manifolds/blocks that allow the brake booster, IAC, FPR, and CCV to be utilized.
    john@m20guru.com
    Links:
    • digger
      • Nov 2005
      • 6195
      #77
      hey thanks i meant overall length but i can work it out
      150mm + 118mm + 40mm = 308mm which is pretty good. when you compare to the dbilas which is woefully short for a mild engine it should be alot nicer without any penalty
      have you ever cut up a OEM manifold to measure size at the start of the OEM runners to see how much taper they used?
      • ForcedFirebird
        • Feb 2007
        • 8300
        #78
        Have the whole thing bolted back on the car. Idles like a rock, but off idle and stabbing throttle bogs pretty bad. Was hoping to go to the dyno tomorrow, but will need to re-write all the maps to add fuel sooner. Rolling on the throttle, or once the fueling catches up, this thing is a rocket.
        john@m20guru.com
        Links:
        • ForcedFirebird
          • Feb 2007
          • 8300
          #79
          Stock m50 with muffler only. 200,961 miles to be exact. Have s50 cams and some other items we will be adding to the car.
          No, I have not cut a stock manifold. They fly off the shelf for OBD2 cars coming in for manifold swaps.
          We made them as long as the chassis would allow. The e30 24v swap kits will have to be 28mm shorter.
          john@m20guru.com
          Links:
          • rzerob
            • Jun 2013
            • 2315
            #80
            So you have to run a MAF delete to use this set up? What kind of engine management are you running/recommend?
            • ForcedFirebird
              • Feb 2007
              • 8300
              #81
              Using a stock ECU and tuning it around the MAF right now. An air-box could be made to use the stock MAF, we will be making them in the future.
              john@m20guru.com
              Links:
              • digger
                • Nov 2005
                • 6195
                #82
                i would think 10" to 12" from head to trumpet inlet will function well. the only question is if 45mm throttles requires a pretty heavily worked motor to get the best from. im interested to see results i suspect it will be fine since they are further upstream and the runners are long.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #83
                  Once the maps are adjusted to account for the rush of air lower in the RPM's, think the 45's will be fine. The parent company wanted to start with larger throttles, I wanted 45's as they are a good "middle-of-the-road" size. They should work well on a stock engine and have room to grow. So far, there has been ZERO interest on b25's, never mind stock anything- so all the more reason the test engine is nice to be a b25, as gains on a modified engine will be exponential.
                  john@m20guru.com
                  Links:
                  • digger
                    • Nov 2005
                    • 6195
                    #84
                    jenvey thought i should use 48 on my M20, what nonsense on anything that you want a good VE in the midrange from rather than a dyno queen.
                    you can make 500bhp with 50mm ones. sizing based on hp/cyl is a good guide as it gives velocity so 45's are good for 400bhp this gives plenty margin for M50/52 based engines.
                    ive chosen 42mm for my next build but not jenveys, couldn't be bothered figuring out linkage etc
                    • golde30
                      • 11464
                      #85
                      What's the size of euro s50 ITB for comparison?
                      IG: @Baye30
                      • Wanganstyle
                        • 2828
                        #86
                        S54 is 42.5mm if you want a comparison.
                        It's huge as its 42.5mm x 6
                        Euro s50b32 wont be much different; anything above 36mm would be adequate for a s52 NA.
                        A supra mk4 has a 60 mm throttle; it's ok for a 600rwhp. Cut that in half for a NA application and multiply by 6.
                        Sent from my SAMSUNG-SGH-I337 using Tapatalk
                        • NickL
                          • 562
                          #87
                          Excited to see results and what you guys have to offer for tuning. Ill be extremely interested to run these on my S52.
                          1987 325is - S52
                          • LJ851
                            • 7919
                            #88
                            Your head is up your ass again wangan.
                            You can't compare a single throttle body size to ITB. Only 1 cylinder pulls air at a time so an individual cylinder with it's own butterfly needs to be much larger than splitting a single TB six ways.
                            A S52 on 36mm ITB would be very choked.
                            Nice work FF, can't wait to see the results.
                            Lorin
                            The M30 is God's engine.
                            • Wanganstyle
                              • 2828
                              #89
                              Have you tried it?
                              How can one cylinder alone pull more than 36mm worth of throttle?
                              Prove to me why my your nose is up Paul burkes ass?
                              I don't modify engines; I run stock oem engines.
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #90
                                They like to over-size them. I wanted drivability as well. Jenvey linkage is all modular, so it was a matter of going through parts and seeing what fit, finding a throttle cable setup that matched the chassis, then it was a matter of the peripherals. Making this a bolt on took a lot of trial and error.
                                Area or flow doesn't work like that. A single 45mm throttle will flow ~210-ish CFM a single 65mm will flow ~440-ish. Even though the single throttle is sharing the flow, reversion and pulsing has to be taken into consideration.
                                EDIT: Single 65mm-75mm feeds LSx just fine.
                                john@m20guru.com
                                Links:
