88' Zinno M3 (Progress Thread)
  • jhaurimn
    • Nov 2012
    • 2224
    #316
    Originally posted by iXguido
    source for the parking brake boot?
    person named 'stitched' on here
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
    • av8drvr
      • 110
      #317
      leather looks great, would you mind sharing what glue/adhesive you used? I am having a hell of a time getting my new leather boot to adhere to the metal frame.
      • jhaurimn
        • Nov 2012
        • 2224
        #318
        I used this stuff. http://www.autozone.com/sealants-glu...ve/130215_0_0/
        Basically, get the frame set up in the boot where it will end up being. Spray a coat or two of the adhesive on the bracket where you will pinch the boot onto it. Get a bunch of binder clips like I did, and let it sit for 24 hours before removing the clips.
        Current:
        1989 325i
        1988 M3
        1987 325ic
        Past:
        2001 330ci
        2001 M3
        • jhaurimn
          • Nov 2012
          • 2224
          #319
          So I swapped my e38 16"s for my buddys stock 15"s....all I have to say is I am getting 15"s. The car drives so much nicer.
          Current:
          1989 325i
          1988 M3
          1987 325ic
          Past:
          2001 330ci
          2001 M3
          • Bimmer_man
            • Jan 2013
            • 1477
            #320
            Your m3 is as inspirational as always man. And yes run the 15s. Imo the m3 was built for the 15s so I say run those. Looks perfect.
            Float like a cadillac sting like a Bimmer!:)
            • jhaurimn
              • Nov 2012
              • 2224
              #321
              yay or nay (to center console vent thing)
              Current:
              1989 325i
              1988 M3
              1987 325ic
              Past:
              2001 330ci
              2001 M3
              • The Dark Side of Will
                • Jun 2010
                • 2796
                #322
                What does it vent from?
                Or is it purely cosmetic?
                • bradnic
                  • Jul 2012
                  • 3552
                  #323
                  Wow where did you find one of those? Always thought hey we're part of a retrofit AC kit?
                  Really don't see them as right / appropriate for an M3
                  HOWTOs:
                  DB vert plastic bumpers
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #324
                    No its ugly. Throw it away i'll pm you an address for the dump ;)
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • jhaurimn
                      • Nov 2012
                      • 2224
                      #325
                      Yup, part of a retrofit ac system for euro cars with no ac
                      Current:
                      1989 325i
                      1988 M3
                      1987 325ic
                      Past:
                      2001 330ci
                      2001 M3
                      • Bimmer_man
                        • Jan 2013
                        • 1477
                        #326
                        ThatOneEuroE30 could really use that unit haha.
                        • jhaurimn
                          • Nov 2012
                          • 2224
                          #327
                          I bought the aftermarket door seals sold here - http://www.r3vlimited.com/board/showthread.php?t=347247
                          To fix this
                          Now looks like this. Both seals fit great!
                          Also got a z3 shifter in now. No bending required, just put the lever in as I got it. Feels muuuuch better. I did replace the white plastic bushing.
                          Current:
                          1989 325i
                          1988 M3
                          1987 325ic
                          Past:
                          2001 330ci
                          2001 M3
                          • jhaurimn
                            • Nov 2012
                            • 2224
                            #328
                            I was missing the grommet for the front abs sensors/brake wear sensor
                            Oem is $16 each, so I bought ones off ebay (1" dia, 11/16" inner hole) that fit perfectly. $10 shipped for 6
                            I bought a bunch of plugs and wires to help refresh my harness near the headlights
                            Before pic. This was after removing the old harness tape. New plugs were on at this point and bad plug wires replaced.
                            After. (still need wiring for fogs and windshield washer level sensor)
                            Figured while I was doing unnecessary things, why not refinish the horns?
                            Someone parted out the heated washer nozzles from my car. (came on all us m3s) Since you can still buy the harness and nozzles new, I opted to put them back in. (~30 for the harness, ~50 for the two nozzles) I had new washer fluid hose sitting around and bought some clips and a t valve.
                            And some current pictures from a nice camera for once
                            Current:
                            1989 325i
                            1988 M3
                            1987 325ic
                            Past:
                            2001 330ci
                            2001 M3
                            • rzerob
                              • Jun 2013
                              • 2315
                              #329
                              Can you post the ebay link you bought the abs grommets from on here. I have been looking for a some myself.
                              • jhaurimn
                                • Nov 2012
                                • 2224
                                #330
                                Here you go: http://www.ebay.com/itm/251470674390...%3AMEBIDX%3AIT
                                Current:
                                1989 325i
                                1988 M3
                                1987 325ic
                                Past:
                                2001 330ci
                                2001 M3
