88' Zinno M3 (Progress Thread)
  • rzerob
    • Jun 2013
    • 2315
    #331
    Originally posted by jhaurimn
    Thanks. I just ordered some.
    • jeenyus
      • Aug 2011
      • 2064
      #332
      finally made it all the way through this. excellent attention to detail. You should ditch that mechanical fan though.
      • jhaurimn
        • Nov 2012
        • 2224
        #333
        Aux fan doesnt work at the moment, so I need to sort that out first. Id like to ditch it, even though I bought a new fan clutch and fan blades :p
        Current:
        1989 325i
        1988 M3
        1987 325ic
        Past:
        2001 330ci
        2001 M3
        • thmpr464
          • May 2016
          • 93
          #334
          high chance it is the aux fan relay...cheap fix. It can easily be done by removing the front kidney grill.
          • The Dark Side of Will
            • Jun 2010
            • 2796
            #335
            Keep it. The engine driven fan moves *WAY* more air than any electric fan ever could.
            • jeenyus
              • Aug 2011
              • 2064
              #336
              Unless you're sitting in traffic and its contingent on your RPM. So let's say you idle at 900rpm, the fan is only moving as much as that rotation equals. When you're driving down the highway at 70mph your car might be running at 3k rpm, but you don't need it when going that fast cause you have 70 mph of wind blasting in the front of your radiator.
              Mechanical fan can maybe move more air, but it's not as efficient or as effective as an electrical fan in traffic. Why do you think mechanical fans are only on older cars?
                • Jun 2010
                • 2796
                #337
                Sitting in traffic is exactly when you need the fan to be moving as much air as the engine driven fan moves. BMW did a whole lot of validation testing (not as much on the older cars as newer, of course) that the engine driven fan would move enough air to keep the car from overheating in pretty much any conceivable conditions, including idling at 900 RPM in 100F ambient temps for extended periods.
                How much validation testing has an electric fan manufacturer done? Basically zero for any given application.
                This is why the entire industry has used fan clutches for decades.
                E46 M3's have engine driven fans
                An engine driven fan is actually way more efficient in traffic because it moves way more air per power input than an electric fan.
                An electric fan has stacked power conversion inefficiencies of both the alternator and fan motor, in addition to being smaller diameter than the mechanical fan, requiring it to turn faster to produce a given air flow. High RPM hurts fan efficiency.
                • jeenyus
                  • Aug 2011
                  • 2064
                  #338
                  It's an age old argument for sure. I didn't know that about the E46 having a mechanical fan. My Audi (2003) has a dual electrical fan so I assumed most would probably.
                  I don't mind the feeling of removing close to 10lbs of rotating mass though. There is something to be said about that albeit the electrical zap, but on my car it's only a 12v which is just replacing the aux fan anyway.
                  It's fair to say the debate will continue.
                  • jhaurimn
                    • Nov 2012
                    • 2224
                    #339
                    So I havent been doing much lately with the m3 but I have something worth posting now I guess :p Been busy gaining some experience detailing. Thankfully I had some e30s to practice on.
                    Anyways, onto my m3. I fixed the trunk alignment. Body shop had put a spacer in the wrong spot, so it was an easy fix.
                    after
                    When I had my muffler installed last, the shop did not have it out far enough. Its bugged me ever since, and you can see it in a lot of my past pictures. I got that fixed finally.
                    And the most exciting news :D
                    Evo 2 spoiler :D :D :D I figured it was worth a shot as I have been getting more comfortable with painting/wet sanding to try and paint it myself. So I had some zinno mixed into spray cans at napa and went for it. Heres how it looked after two days of curing.
                    After wetsanding with 400 (pretty aggressive, if I had less than 4 coats of clear I wouldnt have used it), 1000 and 2000.
                    And all polished up
                    Thankfully, color match is pretty much dead on. Still need to get rivets from steve tomorrow before I mount it properly.
                    Cars all put away for winter so there probably wont be much happening until Spring....or I might have one last surprise before then ;)
                    Current:
                    1989 325i
                    1988 M3
                    1987 325ic
                    Past:
                    2001 330ci
                    2001 M3
                    • TimeMachinE30
                      • Jun 2014
                      • 3749
                      #340
                      Super job painting. Great car.
                      ACS S3 Build / Dinan 5 E34
                      • jeenyus
                        • Aug 2011
                        • 2064
                        #341
                        Awesome job with the rattle can!
                        • AWDBOB
                          hooptie connoisseur
                          • Aug 2013
                          • 4493
                          #342
                          My buddy has a zinno '88 m3 rotting in his yard that he will not sell me no matter what I say, and your thread makes me that much more pissed off about it.
                          Thanks.
                          • jhaurimn
                            • Nov 2012
                            • 2224
                            #343
                            Thanks! Wet sanding is the key, and laying down enough clear.
                            Thanks.
                            You're welcome ;D
                            Current:
                            1989 325i
                            1988 M3
                            1987 325ic
                            Past:
                            2001 330ci
                            2001 M3
                            • jhaurimn
                              • Nov 2012
                              • 2224
                              #344
                              Current:
                              1989 325i
                              1988 M3
                              1987 325ic
                              Past:
                              2001 330ci
                              2001 M3
                              • Dirty_30_IS
                                • Jan 2016
                                • 179
                                #345
                                Someone parted out the heated washer nozzles from my car. (came on all us m3s) Since you can still buy the harness and nozzles new, I opted to put them back in. (~30 for the harness, ~50 for the two nozzles) I had new washer fluid hose sitting around and bought some clips and a t valve.
                                Where did you get the T-valve from? Mines cracked and doesn't disperse enough pressure for both nozzles.
                                sigpic1990 325IS,
                                2.7L bottom end, Shrick 272 Cam, and a heck of a lot of bald tires.
