88' Zinno M3 (Progress Thread)
  • econti
    • May 2014
    • 1150
    #361
    Beautiful house and area and also car!
    • e30austin
      • 15382
      #362
      Originally posted by jhaurimn
      Seriously. I hadn't looked through this thread or any of the photos in a long time, and going through the thread its been quite the transformation. More than I even remember.
      Good to also see some older names (relative to when I joined at least) still on here, hope all is well man.
      That's usually how it goes. Really a good looking little car you have.
      Thank you - all is fine here, nothing new, just hoarding away. lol
      • 2mAn
        Señior Mod
        • 20975
        #363
        LMK when you are ready to take more pics ;)
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • jhaurimn
          • Nov 2012
          • 2224
          #364
          Yeah.....about that.....
          Current:
          1989 325i
          1988 M3
          1987 325ic
          Past:
          2001 330ci
          2001 M3
          • jhaurimn
            • Nov 2012
            • 2224
            #365
            Well.....been awhile since I had any updates on the car. This one isnt a pleasant one, but we will get it taken care of.
            Car had a aftermarket windshield that was installed very poorly. I finally got around (after 5 years of having the windshield) to getting the old one removed and prep for the new one. There was the tiniest spot of rust peeking out from under the rubber seal near the cowl that I was concerned about.... silly me.
            In this picture you can see the little spot that I could see initially. Tiny hole next to drain.
            ​​​​​​​Probably the worst of it was up here
            As you can see, due to the shit install done likely from the shit bodyshop who did a mediocre respray in the past, we got more rust than expected. And in some unusual spots.
            But we cant change the past, and can only move forward. There was only one hole from my iniital inspection that can be welded shut (near drain hole on pass side), and the rest appears to be surface rust. I will be grinding everything down this weekend to get a better idea of what we are dealing with. I think I will be able to get away without having to cut anything out and patch repair it....but I wont know until I get everything down to metal. If all goes well, will get small hole filled, por15, primer, then paint. (will leave strip of primer exposed for the new adhesive to grab onto)
            Current:
            1989 325i
            1988 M3
            1987 325ic
            Past:
            2001 330ci
            2001 M3
            • 2mAn
              Señior Mod
              • 20975
              #366
              Hope its not too bad! Glad to see an update after a year!
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • jhaurimn
                • Nov 2012
                • 2224
                #367
                thanks bud, look forward watching your mr2 build :)
                Current:
                1989 325i
                1988 M3
                1987 325ic
                Past:
                2001 330ci
                2001 M3
                • AWDBOB
                  hooptie connoisseur
                  • Aug 2013
                  • 4493
                  #368
                  ugh I have this looming in my future- glad to see this thing still getting love
                  • econti
                    • May 2014
                    • 1150
                    #369
                    With a bit of gentle wire wheel it'll probably turn out to be pretty OK underneath
                    • jhaurimn
                      • Nov 2012
                      • 2224
                      #370
                      I didnt waste any time getting to work. After grinding off all the adhesive, I was met with mainly surface rust and nothing more. I have the one spot near the drain hole to weld shut, but everything else was ground down to the point that I feel confident it will not get any worse.
                      These pictures are after I applied por15 metal prep, which turns the rust darker. So it looks a bit worse in these pictures than it really is.
                      And after por15 is applied.
                      I have a buddy with a welder who will help me weld the hole next weekend. So I will grind down that section of por15, weld, reapply por15, then will primer and paint everything before putting the new windshield back on.
                      Current:
                      1989 325i
                      1988 M3
                      1987 325ic
                      Past:
                      2001 330ci
                      2001 M3
                      • jhaurimn
                        • Nov 2012
                        • 2224
                        #371
                        Good news, was able to fill the one rust hole in the cowl. Was a bit tricky as the metal is thin.
                        After the hole was fixed, I re-por15'd the fixed spot and a spot i had to grind off for a ground for the welder
                        Taking NO chances with overspray lol
                        Aaaand after. Only one spot with the new paint will end up being visible outside of the windshield gasket (which was the one spot I could see before as well). Will be very hard to notice if you dont know its there. Primer was left exposed as I saw this done with CurrusDei's restoration from a high end body shop. Figured they knew what they were doing, so opted to go that route.
                        Working on getting the sunroof panel straightened out before the windshield is put in. If this doesnt work, I will try a heat gun.
                        Current:
                        1989 325i
                        1988 M3
                        1987 325ic
                        Past:
                        2001 330ci
                        2001 M3
                        • e30austin
                          • 15382
                          #372
                          good on you for tackling that job. does not look fun.
                          A
                          • 2mAn
                            Señior Mod
                            • 20975
                            #373
                            Im glad it wasnt too bad to address.
                            Rewarding the diving in method of fixing the problem!
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • 968Reckless
                              • May 2013
                              • 1095
                              #374
                              hope the original lock strip and gasket are going back in. If you planning on going with new stuff RIP to you lol .
                              /// MTech Belts ///
                              S52 BUILD
                              M3 VERT BUILD
                              • jhaurimn
                                • Nov 2012
                                • 2224
                                #375
                                I have a brand new windshield, and new gaskets. Installer has done m3 windshields before, what issues did you run into?
                                Current:
                                1989 325i
                                1988 M3
                                1987 325ic
                                Past:
                                2001 330ci
                                2001 M3
