M20 B3x Naturally Aspirated Stroker build past, present and future
  • downforce22
    • Aug 2009
    • 3189
    #241
    didn't think you could go bigger than the s52 crank. Are you running the 135mm rods?
    The longest rods I've heard is the MM stroker kit which are like 137mm so this crank will really shorten that piston!
    • digger
      • Nov 2005
      • 5948
      #242
      135mm rods, which coincidentally is the same length rods that the donor engine had. This means the piston compression height is larger than my MM pistons which use a 138mm rod.
      • ForcedFirebird
        • Feb 2007
        • 8300
        #243
        Bang up!
        john@m20guru.com
        Links:
        • digger
          • Nov 2005
          • 5948
          #244
          The limitation on stroke is the clearance to the intermediate oil pump shaft. im getting a custom one made as even with slim rod shoulders of the Molnar rods it needs to neck down too much for my liking with crappy quality material (cast iron?) its made from becoming apparent when you start to cut into it
          • Nutzy
            • Sep 2011
            • 102
            #245
            Stellar work Digger! Looking forward to seeing the results. :)
            89 M50B28 turbo
            LINKY
            • digger
              • Nov 2005
              • 5948
              #246
              for reference this is the manifold sitting on a spare stock 885 head showing the change in port entry size, so port entry is not much bigger despite expected power about double stock b25. Equivalent to ~ D39-40mm
              • whitebulat22
                • Apr 2014
                • 330
                #247
                Originally posted by digger
                The harmonic lengths I obtained from pipemax are primarlily a function of the peak hp rpm so for an engine with peak hp in the 6250-6750rpm regardless of other specs the numbers are approx
                4th harmonic: 400-425mm
                3rd Harmonic: 800-850mm
                2nd Harmonic: 1600-1700mm
                Torque
                After seeing these results and part throttle goodness I definitely want that 2nd harmonic with my upcoming m20! Do you think a y pipe would act similarly? I have parts for either 3rd harmonic with factory h pipe precat or I can put my y pipe after the giant factory cat for 2nd.
                • MrBurgundy
                  • Mar 2012
                  • 5323
                  #248
                  The details in this thread..... Can't wait to get my stroked finished.
                  Sent from my iPad using Tapatalk
                  Current Collection: 1990 325is // 1987 325i Vert // 2003 525i 5spd // 1985 380SL // 1992 Ranger 5spd // 2005 Avalanche // 2024 Honda Grom SP // 2024 Yamaha XSR700 // 2024 Jeep Gladiator Rubicon
                  • digger
                    • Nov 2005
                    • 5948
                    #249
                    Yes, y pipe will be same, similar to h as well . I'd do y they flow better if you're happy to use a single pipe
                    • digger
                      • Nov 2005
                      • 5948
                      #250
                      I hear you, unfortunately I may never finish. Recent events have put a rather large obstacle in my way, such that it all seems so far away at this point.
                      • Bearmw
                        • 1323
                        #251
                        What happened?
                        • digger
                          • Nov 2005
                          • 5948
                          #252
                          was minding my own business then boom, someone crashed into me....its making me reassess my plans. we will see what happens
                          • Sh3rpak!ng
                            • Jan 2014
                            • 2667
                            #253
                            Oh no :( :( :( not the kind of update I ever want to see
                            Shadetree30
                            • 2mAn
                              SeƱior Mod
                              • 20181
                              #254
                              Yea I was just sending him a wCOTMderful message and got bad news instead :(
                              Simon
                              Current Cars:
                              -1966 Lotus Elan
                              -1986 German Car
                              -2006 Volkswagen Jetta TDI
                              Make R3V Great Again -2020
                              • digger
                                • Nov 2005
                                • 5948
                                #255
                                Car is totally fixable and I'm still driving as per normal but I'm questioning if it's all worth it
